3 Replies Latest reply on Apr 30, 2010 5:46 AM by stormshark
    two web services in a pdf form
    stormshark
      I m designing a process which has two web services (adobe livecycle workbench) I can get respond from each of them but that means I have two xmls.
      The problem starts from here .I need one document put into pdf however I have two Documents, one from each web service
      ı just need to equal two xml to one xml that case I can have one document to put into renderPDFfrom process
      what should I do ?
      should I put another process to combine xml or is there any methods to combine xml
      I m waiting for your answers
      thanks for helping
        • 1. Re: two web services in a pdf form
          Jasmin Charbonneau Level 4
          You can use xpath to set xml nodes. For example if you have the following structures:
          <RootA>
               <Parent1>
                         <Child1/>
                         <Child2/>
                         <Child3/>
             </Parent1>
          </RootA>
          <RootB>
               <Parent1>
                         <Child1/>
                         <Child2/>
                         <Child3/>
             </Parent1>
          </RootB>
          <Main>
          <Node1/>
              <Child1/>
              <Child2/>
          <Node1/>
          </Main
          You could store them in xmlvar1,xmlvar2 and mainxml, then you could combine them into one using xPath with something similar to
          /process_data/mainxml/Main/Node1/Child1 = /process_data/xmlvar1/RootA
          /process_data/mainxml/Main/Node1/Child2 = /process_data/xmlvar1/RootB
          Jasmin
          • 2. Re: two web services in a pdf form
            stormshark Level 1
            thank you very much Jasmin your answer is brilliant but in my case When I put  "Main" between Node1 and mainxml  (not really "Main" in my case form1) it doesnt work correctly  /process_data/mainxml/Main/Node1/Child
            this is my code and also another problem
            /process_data/wstranslatesum/Page1/tablo1   =      /process_data/wsresponse2/Envelope/Body/HelloWorldResponse/HelloWorldResult/diffgram/NewD ataSet
            /process_data/wstranslatesum/Page2/Sonuc    = /process_data/wsresponse/Envelope/Body/getMaxWaitingProcessStepsResponse/getMaxWaitingPro cessStepsResult/diffgram/NewDataSet
            when I use above example only
            above part works   they are on the other page
            when I use the below
            /process_data/wstranslatesum/Page2/tablo1   =      /process_data/wsresponse2/Envelope/Body/HelloWorldResponse/HelloWorldResult/diffgram/NewD ataSet
            it works perfectly   (did you notice that they are on the same page)
            so what is the problem I know you are Expert
            can youy recommend any resource which has real case example
            thank you so much
            Sincerely ,
            Joseph
            • 3. Re: two web services in a pdf form
              stormshark Level 1
              I solved the problem. the problem is I missed the hierarchy . the second table was not under the second subform that s why it didn t work
              anyway thanks a lot
