0 Replies Latest reply on Apr 29, 2010 8:38 AM by Paul Reilly
    [svn:fx-trunk] 15812: * Package and class level javadoc for the flash.css,
    Paul Reilly Level 1
      Revision: 15812
      Revision: 15812
      Author:   preilly@adobe.com
      Date:     2010-04-29 08:36:42 -0700 (Thu, 29 Apr 2010)
      Log Message:
      • Package and class level javadoc for the flash.css,
        flash.swf.tools.as3, and flash.svg packages.  Removed some dead
        code, too.
      QE notes:
      Doc notes:
      Bugs:
      Reviewer: Corey (post commit)
      Tests run: checkintests
      Is noteworthy for integration: NO
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flash/css/Descriptor.java
          flex/sdk/trunk/modules/compiler/src/java/flash/css/FontFaceRule.java
          flex/sdk/trunk/modules/compiler/src/java/flash/css/LocalSource.java
          flex/sdk/trunk/modules/compiler/src/java/flash/css/Rule.java
          flex/sdk/trunk/modules/compiler/src/java/flash/css/StyleCondition.java
          flex/sdk/trunk/modules/compiler/src/java/flash/css/StyleDeclaration.java
          flex/sdk/trunk/modules/compiler/src/java/flash/css/StyleDocumentHandler.java
          flex/sdk/trunk/modules/compiler/src/java/flash/css/StyleParser.java
          flex/sdk/trunk/modules/compiler/src/java/flash/css/StyleParserErrorTranslator.java
          flex/sdk/trunk/modules/compiler/src/java/flash/css/StyleProperty.java
          flex/sdk/trunk/modules/compiler/src/java/flash/css/StyleRule.java
          flex/sdk/trunk/modules/compiler/src/java/flash/css/StyleSelector.java
          flex/sdk/trunk/modules/compiler/src/java/flash/css/StyleSheet.java
          flex/sdk/trunk/modules/compiler/src/java/flash/css/URLSource.java
          flex/sdk/trunk/modules/compiler/src/java/flash/svg/SpriteTranscoder.java
          flex/sdk/trunk/modules/compiler/src/java/flash/swf/tools/as3/EvaluatorAdapter.java
          flex/sdk/trunk/modules/compiler/src/java/flash/swf/tools/as3/PrettyPrinter.java
      Added Paths:
          flex/sdk/trunk/modules/compiler/src/java/flash/svg/package.html
          flex/sdk/trunk/modules/compiler/src/java/flash/swf/tools/as3/package.html
      Removed Paths:
          flex/sdk/trunk/modules/compiler/src/java/flash/css/RuleList.java
          flex/sdk/trunk/modules/compiler/src/java/flash/svg/SVG.java
