1 Reply Latest reply on Sep 20, 2007 12:47 PM by LoanXEngine
    CF8, SSL, cfhttp and clientCert issue
    LoanXEngine Level 1
      I was excited to see that CF8 allowed you to pass a clientCert in cfhttp. Conveniently, I needed to do this to integrate with a credit company.
      But it doesn't appear to work. In fact, cfhttp is 'undefined' when using it with clientCert.
      I have installed the special Cert file manually.
      To manually import a certificate:
      Go to a page on the SSL server in question.
      Double-click the lock icon.
      Click the Details tab.
      Click Copy To File.
      Select the base64 option and save the file.
      Copy the CER file into C:\CFusionMX7\runtime\jre\lib\security (or whichever JRE ColdFusion is using).
      Run the following command in the same directory (keytool.exe is located in C:\CFusionMX7\runtime\jre\bin):
      keytool -import -keystore cacerts -alias giveUniqueName -file filename.cer
      When I run it without passing the clientCert, I get a cfhttp response from the webserver (403)... and error, but at least I get something.
      When I add in the clientCert, cfhttp doesn't appear to work and I get a cfhttp is undefined error.
      Does this feature actually work? Anyone have any suggestions??
