2 Replies Latest reply on May 1, 2010 7:53 AM by Gabrinskie
    How insert a "cancel button" (back button)
    Gabrinskie Level 1
      hi,
      I have in sequence two dynamic list/form
      list_1 > form_1 > list_2 > form_2
      I need to insert a cancel (or back) button in list_2 to go back in form_1
      This button must be the same provided by ADDT in form_1 or form_2
      thanks for your help (I hope)
      Gabrinskie
        • 1. Re: How insert a "cancel button" (back button)
          Albert S. Level 3
          One way to do it is on list_2 add a Custom Transaction
          Developer Toolbox->Server Behaviors->Forms->Advanced->Custom Transaction
          Specify your DB
          Select Starter Transaction ->Form Variable -> Name it KT_Back1
          "When Finished" -> Select desired page. form_2
          Make sure other tabs are blank->Hit Ok
          Now add the button to list_2
          <input type="submit" name="KT_Back1" value="<?php echo NXT_getResource("Cancel_FB"); ?>" onclick="return UNI_navigateCancel(event, 'includes/nxt/back.php')" />
          NOTE:
          if your includes folder is not structured how you see in the UNI_navigateCancel function then you will need to fix that.
          • 2. Re: How insert a "cancel button" (back button)
            Gabrinskie Level 1
            Hi Albert,
            thanks for your quick response.
            I followed your suggestion. Everything seems to work.
