5 Replies Latest reply on Apr 29, 2010 10:50 AM by osgood_
    Using CSS and Layouts
    Traveling Person Level 1
      Below is the source code of something that I want to understand if it can it be done. The green box is centered, which is what I want. I now want to place the grey box anywhere within the green box and have it stay where I move it with respect to the boundries of the green box. What code changes/parameters do I need to make to make it happen?
      <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
      <html xmlns="http://www.w3.org/1999/xhtml">
      <head>
      <meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
      <title>Untitled Document</title>
      <style type="text/css">
      body {
      background-color: #FFFF99;
      #apDiv1 {
      position:relative;
      width:900px;
      height:600px;
      z-index:1;
      background-color: #99FF99;
      margin-right: auto;
      margin-left: auto;
      #apDiv2 {
      position:relative;
      width:200px;
      height:115px;
      z-index:1;
      background-color: #999999;
      </style>
      function MM_reloadPage(init) {  //reloads the window if Nav4 resized
        if (init==true) with (navigator) {if ((appName=="Netscape")&&(parseInt(appVersion)==4)) {
          document.MM_pgW=innerWidth; document.MM_pgH=innerHeight; onresize=MM_reloadPage; }}
        else if (innerWidth!=document.MM_pgW || innerHeight!=document.MM_pgH) location.reload();
      MM_reloadPage(true);
      </script>
      </head>
      <body>
      <div id="apDiv1">
        <div id="apDiv2"></div>
      </div>
      </body>
      </html>
        • 1. Re: Using CSS and Layouts
          osgood_ Level 8
          You would change the properties of the apDiv2:
          #apDiv2 {
          position: absolute;
          top: 100px;
          left: 100px;
          width:200px;
          height:115px;
          z-index:1;
          Not sure what you are doing but building a complete website like this is not correct. You can use this technic sparingly.
          A better way would be to use the margin property to position the <div>:
          #apDiv2 {
          margin-top: 100px;
          margin-left: 100px;
          width:200px;
          height:115px;
          z-index:1;
          But I'm not sure what your end goal is.
          If you use the margin technic then you also need to add - padding-top: 1px; - to the apDiv1 css otherwise the top-margin will collapse.
          • 2. Re: Using CSS and Layouts
            I now want to place the grey box anywhere within the green box and have it stay where I move it ...
            Just so we're clear on this point, DW is not a drag & drop app.  For best results, you must abandon any notions you may have about using DW like a desktop publisher such as MS Word.  It doesn't work that way.
            Nancy O.
            Alt-Web Design & Publishing
            Web | Graphics | Print | Media  Specialists
            http://alt-web.com/
            http://twitter.com/altweb
            http://alt-web.blogspot.com
            • 3. Re: Using CSS and Layouts
              If one cannot use layouts, what is the purpose? They look like a great tool for laying out a web page.
              • 4. Re: Using CSS and Layouts
                A nice idea that fails to produce good code or good cross browser results.
                Read why below:
                http://apptools.com/examples/pagelayout101.php
                Nancy O.
                http://alt-web.com/
                • 5. Re: Using CSS and Layouts
                  osgood_ Level 8
                  Layouts?
                  Absolutely positioned <divs> (as in my first example) should not be used frequently in a web page construction because they have limited flexibility given you set the position absolutely and they will not interact with any other element on your page. As a result of this you could end up with a completely scrambled mess, where elements overlap, maybe not in the browser you are viewing in but in other peoples browsers who are potentailly using a completely different set up to yours. Therefore you must build flexibility into the construction to accommodate a wide range of different browser variations.
                  Method 2 which uses margins to position what is know as a 'static' <div> is far better as this will ineract with other elements on the page.
                  Basically a good solid construction is one of a series of static <div> boxes which are positioned (if needs be) by using margin, padding, floating using css.
