1 Reply Latest reply on Apr 29, 2010 7:35 PM by David_F57
    Air download files from server
    GeorgeWS
      I have an Air app that should display a DataGrid with a list of files that can be downloaded from my web server. It works perfect as a Flex program. I get 2 errors that I list at the bottom. I have a downloadFile.as file in a com folder
      <mx:Script>
      <![CDATA[
      import mx.collections.ArrayCollection;
      import mx.rpc.events.ResultEvent;
      import mx.controls.Alert;
      import mx.events.ListEvent;
      Bindable] public var directoryDS:ArrayCollection;
      Bindable] public var serviceURL:String;
      Bindable] public var fileIndex:Number;
      public function initApp():void
      serviceURL =
      "http://www.youngsmarket.com/directory.cfm"; //Set the URL to the httpservice
      directoryDS =
      new ArrayCollection([]); // This is where the results of the httpservice will end up.
      fileIndex = -1;
      directory_srv.send();
      // Taking the data returned from the httpservice and creating FileDownload objects to populate the directoryDS array collection.
      private function setDataSource(evtObj:Object):void
      var fileDL:DownloadFile;
      var collection:ArrayCollection = evtObj.directory.file as ArrayCollection; // pass httpservice result into a local scope
      var i:int;
      //loop over results and create a new DownloadFile object and add it to the directoryDS ArrayCollection
      for (i=0;i < collection.length; i++)
      fileDL =
      new DownloadFile();
      fileDL._file = collection.getItemAt(i).name;
      fileDL._url =
      "http://www.youngsmarket.com/myFiles/"; // Change this to match your Files directory path.
      fileDL._size = collection.getItemAt(i).size;
      directoryDS.addItem(fileDL);
      </mx:Script>
      <mx:HTTPService
      id="directory_srv" url="{serviceURL}" result="setDataSource(event.result)"/>
      <mx:DataGrid
      dataProvider="{directoryDS}" id="filesDG" doubleClickEnabled="true" itemDoubleClick="downloadFile()" change="setFileIndex(event.target.selectedIndex);"
      width="
      100%" height="100%" borderStyle="none" themeColor="#73B9B9">
      <mx:columns>
      <mx:DataGridColumn dataField="_file" headerText="File" minWidth="150" />
      <mx:DataGridColumn dataField="_size" headerText="Size" minWidth="100" />
      </mx:columns>
      </mx:DataGrid>
      Error on this line:   var fileDL:DownloadFile;
      the error is:   Type not found or is not compile time constant: DownloadFile
      the next error is this line:    fileDL = new DownloadFile();
      the error is:     call to a possibly undefined method DownloadFile
