10 Replies Latest reply on May 6, 2010 6:35 AM by kenji776
    Simply not smart enough to write this
    kenji776 Level 1
      Hey All,
      You know when you want to do something, and you realize you simply do not have the brain power to pull it off? I am there, but I think maybe a little bit of help might get me over the really hard part.
      GOAL: Pull scheme data from our Salesforce.com instance (a massive CRM platform, basically just a fancy relational database system). Find all related objects, parse the data, and feed it into the JIT javascript visulization framework (http://thejit.org/). I want to use CF to pull the data, parse it, and feed it to JIT, however the format JIT requires is hard for me to write programatically.
      Here is an example of the what the final result will look like, instead of numbers each node would be an object name.
      http://thejit.org/Jit/Examples/Spacetree/example2.html
      Here is the data that powers that thing.
      http://pastebin.com/n2Sv64M6
      It's just JSON, but the nesting get's really brutal.
      So far I have the code in place to get the data I want, and break it into chunks, but I can't think of an eloquent way to create the required JSON. Here is what I have so far.
      http://portal.fpitesters.com/sfmap.cfm
      Here is the code for that tool.
      <cfsetting requesttimeout="5000">
      <cfif isdefined("form.Flush")>
           <cfcache action="flush" >
      </cfif>
      <form name="FlushForm" method="post">
           <input name="Flush" value="Recalculate Relationships (Will Take a Long Time)" type="submit" />
      </form>
      <cfcache action="optimal">
      <cfoutput>
           These results where cached at #TimeFormat(Now())#.
           <cfset GlobalObject = server.OSF.describeGlobal()>
           <cfloop from="1" to="#arraylen(GlobalObject.Results)#" index="ObjectIndex">
                <cfset Object = server.OSF.describeObject(GlobalObject.Results[ObjectIndex])>
                <cfset ObjectInfo = Object.RawSoap>
                <cfset returnStruct = structnew()>
                <cfset RelationShips[GlobalObject.Results[ObjectIndex]] = arraynew(1)>
                <cfset numRefFields = 0>
                <cfloop
                     From="1"
                     To="#arraylen(ObjectInfo.Envelope.Body.describeSobjectResponse.result.fields)#"
                     Index="i">
                     <cfset ObjectFieldReference = ObjectInfo.Envelope.Body.describeSobjectResponse.result.fields[i]>
                     <cfif ObjectFieldReference.type.xmltext eq "reference">
                          <cfset numRefFields = numRefFields + 1>
                          <cfset RelationShips[GlobalObject.Results[ObjectIndex]][numRefFields] = structnew()>
                          <cfset RelationShips[GlobalObject.Results[ObjectIndex]][numRefFields].name=ObjectFieldReference.name.xmltext>
                          <cfset RelationShips[GlobalObject.Results[ObjectIndex]][numRefFields].label=ObjectFieldReference.label.xmltext>
                          <cfset RelationShips[GlobalObject.Results[ObjectIndex]][numRefFields].refto=ObjectFieldReference.referenceto.xmltext>
                     </cfif>
                </cfloop>
                <a name="#GlobalObject.Results[ObjectIndex]#">RelationsShips in #GlobalObject.Results[ObjectIndex]#</a>
                <ol>
                     <cfloop from="1" to="#arraylen(RelationShips[GlobalObject.Results[ObjectIndex]])#" index="relationshipFieldIndex">
                          <li>  #RelationShips[GlobalObject.Results[ObjectIndex]][relationshipFieldIndex].name# to <a href="###RelationShips[GlobalObject.Results[ObjectIndex]][relationshipFieldIndex].refto#">#RelationShips[GlobalObject.Results[ObjectIndex]][relationshipFieldIndex].refto#</a></li>
                     </cfloop>
                </ol>
           </cfloop>
      </cfoutput>
      So instead of creating that simple dumb list, I ned to create the JSON, but how? I just can't wrap my brain around it for some reason. Any help, sample code, anything would be of use. Thank you.
        • 1. Re: Simply not smart enough to write this
          Adam Cameron. Level 5
          You know you can convert CF data structures to JSON with a single function call, right?
          http://help.adobe.com/en_US/ColdFusion/9.0/CFMLRef/WSc3ff6d0ea77859461172e0811cbec22c24-79 fa.html
          Adam
          • 2. Re: Simply not smart enough to write this
            kenji776 Level 1
            I am familiar with that function. Maybe I'm overcomplicating things, but I don't think thats going to give the data in quite the structure I need. Worth a shot though. I'll try it out.
            • 3. Re: Simply not smart enough to write this
              JSON is JSON: it's a notation used to represent the structure of data, not a data structure unto itself.  It's up to you to structure the source data appropriately.
              You seem to have a lot of code already for something that's not working, and trying to get all that working will probably do your head in (a case in point: I'm not even prepared to look at that much code when someone is asking for help on these forums).  Can I recommend you ignore you actual data whilst you get this working, and just do a proof of concept work: use minimalist mock data to come up with a small working sample.  Once you get that formatted correctly, start thinking about expanding it to meet your needs; making sure the end result stays valid at intermediary stages.  Don't try to solve the whole thing at once.
              Adam
              • 4. Re: Simply not smart enough to write this
                kenji776 Level 1
                You were right, it's definitly getting me close. You can see what I'm getting here.
                http://portal.fpitesters.com/test.cfm
                however compare the generated JSON
                http://pastebin.com/zV7f0vNp
                to the provided JSON
                What is the deal with the differences? His doesn't have quotes, mine does, his has brackets for empty data, I had to manually type them in. His first node comes right after the inital { where as mine opens with { [. Am I going to have to do a bunch of manual cleanup, or am I just approaching this the wrong way? Here is my updated code.
                <!--- With lots of objects this can take a while ---->
                <cfoutput>
                     <!--- Get a list of all the objects in Salesforce, delivered as a structure with an array inside (success and results keys) --->
                     <!--- Create an array to hold all the object data to be converted to JSON later --->
                     <cfset ObjectsArray = arraynew(1)>
                     <!--- Loop over the first 10 objects (just to make it faster for testing --->
                     <cfloop from="1" to="10" index="ObjectIndex">
                          <!--- Get a listing of all the fields for this object. --->
                          <!--- Grab the raw SOAP returned by the call --->
                          <!--- Create a new entry in the object array. Create keys the id, name, data and children --->
                          <cfset ObjectsArray[ObjectIndex] = structnew()>
                          <cfset ObjectsArray[ObjectIndex].id = GlobalObject.Results[ObjectIndex]>
                          <cfset ObjectsArray[ObjectIndex].name = GlobalObject.Results[ObjectIndex]>
                          <cfset ObjectsArray[ObjectIndex].data = "{}">
                          <cfset ObjectsArray[ObjectIndex].children = arraynew(1)>
                          <!--- a simple counter to track how many reference fields we find. there are lots of other kinds of fields we don't care about --->
                          <!--- Loop over all the fields found in the SOAP data --->
                          <cfloop
                               From="1"
                               Index="i">
                               <!--- Create a simple reference to this data --->
                               <!--- If the field type we are on is a reference type (a relationship to another object, then we need to further evaluate --->
                                    <!--- we found another ref field, so increase our counter --->
                                    <!--- Create a structure to hold the data for this child node --->
                                    <cfset ObjectsArray[ObjectIndex].children[numRefFields] = structnew()>
                                    <!--- populate the name, id, data, and children of this node. We shouldn't need to populate the children, because anything
                                           references in this node, should have a node somewhere else. We just link to that other node, creating a nice recursive loop --->
                                    <cfset ObjectsArray[ObjectIndex].children[numRefFields].name = ObjectFieldReference.referenceto.xmltext>
                                    <cfset ObjectsArray[ObjectIndex].children[numRefFields].id = ObjectFieldReference.referenceto.xmltext>
                                    <cfset ObjectsArray[ObjectIndex].children[numRefFields].data = ObjectFieldReference.label.xmltext>
                                    <cfset ObjectsArray[ObjectIndex].children[numRefFields].children = "[]">
                               </cfif>
                          </cfloop>
                     </cfloop>
                </cfoutput>
                <cfdump var="#ObjectsArray#">
                <cfdump var="#SerializeJSON(ObjectsArray)#">
                • 5. Re: Simply not smart enough to write this
                  That second link was just a temporary one, which has since expired.
                  Can't you just paste this stuff into the body of your response?
                  Adam
                  • 6. Re: Simply not smart enough to write this
                    kenji776 Level 1
                    Sorry I didn't see your response post at first. You are right, I should start with a smaller data set, but it feels like with this project a small test case wouldn't really be translateable into an automatic version. My whole issue here is trying to create an automatic parser, I could hand write the JSON sure, but that doesn't get me much closer to my goaI. know JSON is just a data format, but I thought there were like... a lot of rules to follow as to how it was structured, it bothers me that it varies so widley between who writes it. Seriously though, thank you for your input. I would have been trying to create my own JSON builder had you not mentioned the serialize function. I knew it was there, but didn't for some reason think it would be flexible enough. It is however, getting me close i think. I might have to do some after the fact parsing, depening how picky JIT is, but it's better than nothing by a long shot.
                    • 7. Re: Simply not smart enough to write this
                      kenji776 Level 1
                      Ah, again sorry, we seem to be writting our posts at the same time.
                      http://pastebin.com/0XPzWDHr
                      Try that link. Thats what my formatted JSON ends up looking like.
                      There, sorry, just didn't want to be making huge posts.
                      My JSON
                              "ID": "Account",
                              "DATA": "{}",
                              "CHILDREN": [
                                      "ID": "Account",
                                      "DATA": "Master Record ID",
                                      "CHILDREN": "[]",
                                      "NAME": "Account"
                                      "ID": "RecordType",
                                      "DATA": "Record Type ID",
                                      "CHILDREN": "[]",
                                      "NAME": "RecordType"
                                      "ID": "Account",
                                      "DATA": "Parent Account ID",
                                      "CHILDREN": "[]",
                                      "NAME": "Account"
                                      "ID": "User",
                                      "DATA": "Owner ID",
                                      "CHILDREN": "[]",
                                      "NAME": "User"
                                      "ID": "User",
                                      "DATA": "Created By ID",
                                      "CHILDREN": "[]",
                                      "NAME": "User"
                                      "ID": "User",
                                      "DATA": "Last Modified By ID",
                                      "CHILDREN": "[]",
                                      "NAME": "User"
                                      "ID": "Contact",
                                      "DATA": "Billing Contact",
                                      "CHILDREN": "[]",
                                      "NAME": "Contact"
                                      "ID": "Contact",
                                      "DATA": "Primary Org Contact",
                                      "CHILDREN": "[]",
                                      "NAME": "Contact"
                                      "ID": "Contact",
                                      "DATA": "Primary Household Contact",
                                      "CHILDREN": "[]",
                                      "NAME": "Contact"
                              "NAME": "Account"
                              "ID": "AccountContactRole",
                              "DATA": "{}",
                              "CHILDREN": [
                                      "ID": "Account",
                                      "DATA": "Account ID",
                                      "CHILDREN": "[]",
                                      "NAME": "Account"
                                      "ID": "Contact",
                                      "DATA": "Contact ID",
                                      "CHILDREN": "[]",
                                      "NAME": "Contact"
                                      "ID": "User",
                                      "CHILDREN": "[]",
                                      "NAME": "User"
                                      "ID": "User",
                                      "CHILDREN": "[]",
                                      "NAME": "User"
                              "NAME": "AccountContactRole"
                              "ID": "AccountHistory",
                              "DATA": "{}",
                              "CHILDREN": [
                                      "ID": "Account",
                                      "CHILDREN": "[]",
                                      "NAME": "Account"
                                      "ID": "SelfServiceUser",
                                      "CHILDREN": "[]",
                                      "NAME": "SelfServiceUser"
                              "NAME": "AccountHistory"
                              "ID": "AccountPartner",
                              "DATA": "{}",
                              "CHILDREN": [
                                      "ID": "Account",
                                      "CHILDREN": "[]",
                                      "NAME": "Account"
                                      "ID": "Account",
                                      "CHILDREN": "[]",
                                      "NAME": "Account"
                                      "ID": "Opportunity",
                                      "DATA": "Bid ID",
                                      "CHILDREN": "[]",
                                      "NAME": "Opportunity"
                                      "ID": "User",
                                      "CHILDREN": "[]",
                                      "NAME": "User"
                                      "ID": "User",
                                      "CHILDREN": "[]",
                                      "NAME": "User"
                              "NAME": "AccountPartner"
                              "ID": "AccountShare",
                              "DATA": "{}",
                              "CHILDREN": [
                                      "ID": "Account",
                                      "CHILDREN": "[]",
                                      "NAME": "Account"
                                      "ID": "Group",
                                      "DATA": "User\/Group ID",
                                      "CHILDREN": "[]",
                                      "NAME": "Group"
                                      "ID": "User",
                                      "CHILDREN": "[]",
                                      "NAME": "User"
                              "NAME": "AccountShare"
                              "ID": "ActivityHistory",
                              "DATA": "{}",
                              "CHILDREN": [
                                      "ID": "Account",
                                      "CHILDREN": "[]",
                                      "NAME": "Account"
                                      "ID": "Contact",
                                      "DATA": "Contact\/Lead ID",
                                      "CHILDREN": "[]",
                                      "NAME": "Contact"
                                      "ID": "Admin_Projects__c",
                                      "DATA": "Bid\/Account ID",
                                      "CHILDREN": "[]",
                                      "NAME": "Admin_Projects__c"
                                      "ID": "User",
                                      "DATA": "Assigned To ID",
                                      "CHILDREN": "[]",
                                      "NAME": "User"
                                      "ID": "User",
                                      "CHILDREN": "[]",
                                      "NAME": "User"
                                      "ID": "User",
                                      "CHILDREN": "[]",
                                      "NAME": "User"
                              "NAME": "ActivityHistory"
                              "ID": "AdditionalNumber",
                              "DATA": "{}",
                              "CHILDREN": [
                                      "ID": "CallCenter",
                                      "DATA": "Call Center ID",
                                      "CHILDREN": "[]",
                                      "NAME": "CallCenter"
                                      "ID": "User",
                                      "CHILDREN": "[]",
                                      "NAME": "User"
                                      "ID": "User",
                                      "CHILDREN": "[]",
                                      "NAME": "User"
                              "NAME": "AdditionalNumber"
                              "DATA": "{}",
                              "CHILDREN": [
                                      "ID": "Group",
                                      "DATA": "Owner ID",
                                      "CHILDREN": "[]",
                                      "NAME": "Group"
                                      "ID": "User",
                                      "CHILDREN": "[]",
                                      "NAME": "User"
                                      "ID": "User",
                                      "CHILDREN": "[]",
                                      "NAME": "User"
                                      "ID": "User",
                                      "DATA": "Project Lead",
                                      "CHILDREN": "[]",
                                      "NAME": "User"
                              "ID": "ApexClass",
                              "DATA": "{}",
                              "CHILDREN": [
                                      "ID": "User",
                                      "CHILDREN": "[]",
                                      "NAME": "User"
                                      "ID": "User",
                                      "CHILDREN": "[]",
                                      "NAME": "User"
                              "NAME": "ApexClass"
                              "ID": "ApexTrigger",
                              "DATA": "{}",
                              "CHILDREN": [
                                      "ID": "User",
                                      "CHILDREN": "[]",
                                      "NAME": "User"
                                      "ID": "User",
                                      "CHILDREN": "[]",
                                      "NAME": "User"
                              "NAME": "ApexTrigger"
                      Their JSON (a small sample anyway)
                          data: {
                          children: [
                                  data: {
                                  children: [
                                          data: {
                                          children: [
                                                  data: {
                                                  children: [
                                                          data: {
                                                          children: [
                                                  data: {
                                                  children: [
                                                          data: {
                                                          children: [
                                                          data: {
                                                          children: [
                                                          data: {
                                                          children: [
                                                          data: {
                                                          children: [
                                                  data: {
                                                  children: [
                                                          data: {
                                                          children: [
                                                  data: {
                                                  children: [
                                                          data: {
                                                          children: [
                                                          data: {
                                                          children: [
                                                          data: {
                                                          children: [
                                                          data: {
                                                          children: [
                                                  data: {
                                                  children: [
                                                          data: {
                                                          children: [
                                                          data: {
                                                          children: [
                                          data: {
                                          children: [
                                                  data: {
                                                  children: [
                                                          data: {
                                                          children: [
                                  data: {
                                  children: [
                                          data: {
                                          children: [
                                                  data: {
                                                  children: [
                                                          data: {
                                                          children: [
                                                          data: {
                                                          children: [
                                                  data: {
                                                  children: [
                                                          data: {
                                                          children: [
                                                  data: {
                                                  children: [
                                                          data: {
                                                          children: [
                                                          data: {
                                                          children: [
                                                          data: {
                                                          children: [
                                                          data: {
                                                          children: [
                                          data: {
                                          children: [
                                                  data: {
                                                  children: [
                                                          data: {
                                                          children: [
                                                          data: {
                                                          children: [
                                                          data: {
                                                          children: [
                                                  data: {
                                                  children: [
                                                          data: {
                                                          children: [
                                                  data: {
                                                  children: [
                                                          data: {
                                                          children: [
                                                          data: {
                                                          children: [
                                                          data: {
                                                          children: [
                                                  data: {
                                                  children: [
                                                          data: {
                                                          children: [
                                                          data: {
                                                          children: [
                                                          data: {
                                                          children: [
                                                          data: {
                                                          children: [
                                                          data: {
                                                          children: [
                                                  data: {
                                                  children: [
                                                          data: {
                                                          children: [
                                                          data: {
                                                          children: [
                                                          data: {
                                                          children: [
                                          data: {
                                          children: [
                                                  data: {
                                                  children: [
                                                          data: {
                                                          children: [
                                                          data: {
                                                          children: [
                                                          data: {
                                                          children: [
                                                          data: {
                                                          children: [
                                                          data: {
                                                          children: [
                                  data: {
                                  children: [
                                          data: {
                                          children: [
                      • 8. Re: Simply not smart enough to write this
                        kenji776 Level 1
                        Well I am very close, my demo loads, but I'd just displays the same children over and over again. I'm sure its a structural problem in my JSON, but I can't exactly figure out. It seems I need to nest the children further, but I'm not sure why or how much further until it becomes infinitly recursive like I want.
                        I know this isn't really a CF problem anymore, but the support group for this framework blows, and you guys are the smartest coders I know
                        Any help is appreciated, thanks.
                        Here is a link to the demo
                        http://portal.fpitesters.com/sfmap/example2.html
                        Here is the JSON that mostly works.
                            data: {
                            children: [
                                    data: {
                                    children: [
                                    data: {
                                    children: [
                                    data: {
                                    children: [
                                    data: {
                                    children: [
                                    data: {
                                    children: [
                                    data: {
                                    children: [
                                    data: {
                                    children: [
                                    data: {
                                    children: [
                                    data: {
                                    children: [
                            data: {
                            children: [
                                    data: {
                                    children: [
                                    data: {
                                    children: [
                                    data: {
                                    children: [
                                    data: {
                                    children: [
                            data: {
                            children: [
                                    data: {
                                    children: [
                                    data: {
                                    children: [
                            data: {
                            children: [
                                    data: {
                                    children: [
                                    data: {
                                    children: [
                                    data: {
                                    children: [
                                    data: {
                                    children: [
                                    data: {
                                    children: [
                            data: {
                            children: [
                                    data: {
                                    children: [
                                    data: {
                                    children: [
                                    data: {
                                    children: [
                            data: {
                            children: [
                                    data: {
                                    children: [
                                    data: {
                                    children: [
                                    data: {
                                    children: [
                                    data: {
                                    children: [
                                    data: {
                                    children: [
                                    data: {
                                    children: [
                            data: {
                            children: [
                                    data: {
                                    children: [
                                    data: {
                                    children: [
                                    data: {
                                    children: [
                            data: {
                            children: [
                                    data: {
                                    children: [
                                    data: {
                                    children: [
                                    data: {
                                    children: [
                                    data: {
                                    children: [
                            data: {
                            children: [
                                    data: {
                                    children: [
                                    data: {
                                    children: [
                            data: {
                            children: [
                                    data: {
                                    children: [
                                    data: {
                                    children: [
                            data: {
                            children: [
                                    data: {
                                    children: [
                                    data: {
                                    children: [
                                    data: {
                                    children: [
                                    data: {
                                    children: [
                            data: {
                            children: [
                                    data: {
                                    children: [
                                    data: {
                                    children: [
                                    data: {
                                    children: [
                                    data: {
                                    children: [
                                    data: {
                                    children: [
                            data: {
                            children: [
                                    data: {
                                    children: [
                                    data: {
                                    children: [
                            data: {
                            children: [
                                    data: {
                                    children: [
                                    data: {
                                    children: [
                                    data: {
                                    children: [
                                    data: {
                                    children: [
                        • 9. Re: Simply not smart enough to write this
                          Right.  Busy w/end, sorry.
                          The problem is that the top level of the data structure they want is a struct, and you're creating an array.  In JSON notation {} denotes a struct, [] denotes an array.
                          Also their structure is hierarchical, however I see nothing in your code (like a recursive call) which would effect a hierarchy.  You're just creating a flat array.
                          Adam
                          • 10. Re: Simply not smart enough to write this
                            kenji776 Level 1
                            Hey Adam,
                            Thanks for the help. Looking at this framework closer, I don't think it's going to do what I want it to to. I noticed when it hits the end of the heirachy, it just resets to the same root node that you started from. I needed it to load the root node that has the same name/id as the node you just clicked on, hence creating a recursive type hierarchy. I got the JSON pretty much figured out, but even then it doesn't perform as desired. I think my next best bet is to create some kind of simple AJAX based crawler. The visualizations in this are nice, but I don't think it works like I want it to. If you think I'm wrong, certainly let me know, but otherwise I'm going to start working on rolling my own basic visualizer system.
