1 Reply Latest reply on Sep 14, 2007 1:28 PM by kglad
    Call AS from HTML
      Is there a way to use an external AS file from HTML? I know I can do basic stuff with asfunction, but I don't know if what I want to do is possible with dynamic text...
      I have two dynamic text boxes on my scene. I want to load text into one (a sub-menu, if you will) and program the text from said external file to load text into the second text box.
      e.g. I have a "lookup scene" where users can click either "By Department" or "By Name". Let's say they click "By Department", that would then load the departments in the first text box (A_txt) from an external HTML. The next thing I want done is have it so if the user clicks on "Administration", it would then load into the second text box (B_txt) on the scene. I don't know how to reference one dynamic text box from another.
      Does this make sense? Am I going about it the wrong way entirely?
        • 1. Re: Call AS from HTML
          it doens't make sense to talk about executing an as file from anywhere. an as file must be compiled into a swf and then it has executable code.
          if you want textfield substrings to be clickable and cause the execution of as, you must use an html-enabled textfield and the asfunction. you can use this to determine which text file to load and display in the 2nd textfield.
