4 Replies Latest reply on Apr 29, 2010 9:49 PM by toft
    VDividedBox - maximize one or the other child
    toft
      I want to use a VDividedBox in a project and would like to be able to alternate maximizing the child components by code. I have tried setting the children`s percentHeight to 0 / 100 but it doesnt work properly.
      Is there an easy way to do this ?
      PS: Its not an alternativ to use another component in this case.
        • 1. Re: VDividedBox - maximize one or the other child
          David_F57 Level 5
          hi,
          You can move the divider by its co-ordinates
          protected function button1_clickHandler(event:MouseEvent):void
          var dv:BoxDivider = vdb.getDividerAt(0);
          dv.y = 100;
          vdb is the dividebox.
          So to make container 1 taller you simply increase the y value of the first divider
          You may need a little 'fancy' arithmatic code if you are playing with percentages but this should get you started
          David.
          • 2. Re: VDividedBox - maximize one or the other child
            toft Level 1
            excellent !! Just what I needed...
            Thanks David
            • 3. Re: VDividedBox - maximize one or the other child
              David_F57 Level 5
              hi
              had time to do a quick example
                 xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
              <fx:Script>
              <![CDATA[
              import mx.containers.DividedBox;
              import mx.containers.dividedBoxClasses.BoxDivider;
              dv.y = 0;
              protected function button2_clickHandler(event:MouseEvent):void
              dv.y = vdb.height - dv.height;
              </fx:Script>
              <mx:VDividedBox id="vdb" width="306" height="500" horizontalCenter="0" verticalCenter="0">
              <mx:Panel id="pnl1" width="250" height="200" layout="absolute" title="Panel 1"/>
              <mx:Panel id="pnl2" width="250" height="200" layout="absolute" title="Panel 2"/>
              </mx:VDividedBox>
              <s:Button x="549" y="44" label="Button" click="button1_clickHandler(event)"/>
              <s:Button x="636" y="44" label="Button" click="button2_clickHandler(event)"/>
              </s:Application>
              • 4. Re: VDividedBox - maximize one or the other child
                toft Level 1
                Even better...
                Thanks David, I really appreciate your input !!
