1 Reply Latest reply on Apr 30, 2010 5:02 AM by David_F57
    Effect in the custom component
    Marant2000
      I have following application that works fine:
      <s:Application (...)>
           <fx:Declarations>
                <s:BlurFilter id="bOn" blurX="8" blurY="8"/>
           </fx:Declarations>
           <mx:Image source="@Embeded('test.png')" filters="{[bOn]}"/>
      </s:Applications>
      If I create custom component and put image and filter inside I get run time error "Parameter 0 is of the incorrect type. Should be type Filter".
      Modified code for application:
           <comp:MyComponent/>
      </s:Applications>
      and for custom component:
      <s:HGroup (...)>
           <fx:Declarations>
           </fx:Declarations>
      </s:HGroup>
      What is the reason?
      Regards,
      Marcin
        • 1. Re: Effect in the custom component
          David_F57 Level 5
          hi,
          if you assign the filter in the mxml you don't set it as an array of filters just a list, as per the code below which works fine.
          David.
          <s:Group xmlns:fx="http://ns.adobe.com/mxml/2009"
          xmlns:mx="library://ns.adobe.com/flex/mx" width="400" height="300">
          <fx:Declarations>
          </fx:Declarations>
          <mx:Image id="img" source="@Embed('pizzas.jpg')" filters="{bOn}"/>
          </s:Group>
