3 Replies Latest reply on May 11, 2010 2:35 AM by michhanlon
    Why does the nav bar move in a browser??
    michhanlon
      Please help!  In dreamweaver the nav bar looks perfect and is over the top of the blue line under the picture header but when I put it in a browser, it moves as you can see from my link!!
      test site
      Please can anyone tell me why??  I have a feeling it will be a CSS positioning thing but I am very very new to this so do not know how to rectify!
      Thanks if you can help!
        • 1. Re: Why does the nav bar move in a browser??
          John Waller Adobe Community Professional & MVP
          Since you're using <p> tags to create whitespace in the header (better to use CSS with an absolutely positioned div inside a relatively positioned div), remove the height attribute from this rule
          .twoColElsLtHdr #header {
          background-color: #FFF;
          background-image: url(images/header2.jpg);
          background-repeat: no-repeat;
          background-position: center;
          font-size: 12px;
          padding-top: 5;
          padding-right: 5;
          padding-bottom: 5;
          padding-left: 5;
          height: 205px;
          • 2. Re: Why does the nav bar move in a browser??
            osgood_ Level 8
            Look this is not a good solution, it just hacks around the issue.
            Add this to the css style:
            #header p {
            padding: 60px 0 0 0;
            margin: 0;
            Then you need to go into code view and change these code lines:
            <div id="container">
              <div id="header"><br >
                <p align="right"><br >Complete Energy Certificates Ltd </p>
                <p align="right">&nbsp;<br><br >
                </p>
                <div align="center">
            To this:
              <div id="header">
            <p align="right">Complete Energy Certificates Ltd </p>
                <div align="center" style="margin-top: 71px;">
            Now let me explain. You're trying to position elements using <br> tags which will not work. The solution I provided is a sticking plaster one and may fail in some browsers because it still relies on guess work.
            A far better option would be to rebuild that top section of your page into a solid structure.
            A <div> which contains the grass bank and sky image but NOT the blue line that your navigation sits on. You can set this <divs> height to the height of the image and then include your text 'Complete Energy Certificates Ltd' within it.
            Like:
            <div id="header">
            <p>Complete Energy Certificates Ltd</p>
            </div><!-- we close the header -->
            Now set some css:
            font-size: 12px;
            height: 205px; /* make the height the same as that of the background image */
            Move your 'Complete Energy Certificates Ltd' text into position by setting some top
            and right padding on the paragraph tag:
            .twoColElsLtHdr #header p {
            margin: 0;
            padding: 60px 10px 0 0;/*top,right,bottom,left*/
            text-align: right;
            Next introduce a navigation <div> right after the 'header' <div> and put all the table code relating to yuor menu in it:
            <div id="header">
            <div id="navigation">
            <!-- all table code for navigation goes here -->
            </div><!-- we close the navigation -->
            Style your naviagtion <div> to have a blue background that matches the menu images:
            #navigation {
            background-color: #XXX;
            Think of contruction as simple building blocks.
            • 3. Re: Why does the nav bar move in a browser??
              michhanlon Level 1
              thank you both for your help.
              I think i have sort of done it now.  i will have to go and finish learning about css me thinks, before I take on another job!!
              thanks again
