4 Replies Latest reply on Aug 24, 2011 4:44 AM by David_Powers
    ANN: Upgrade Lorem and More for Dreamweaver CS5
    David_Powers Adobe Community Professional
      My Lorem and More extension, which inserts Lorem ipsum and other filler text into Dreamweaver pages, can cause Dreamweaver CS5 to crash in certain circumstances.
      I have updated the extension to make it compatible with CS5. If you use Lorem and More, please download the updated version (1.3.0) from http://foundationphp.com/tools/index.php.
      It's a free extension, and the new version is backwards compatible with all versions of Dreamweaver (apart from really ancient ones).
        • 1. Re: ANN: Upgrade Lorem and More for Dreamweaver CS5
          Ben M Adobe Community Professional
          Wow David I never realized you had this type of extension.  Do you happen to have a version for InDesign?
          • 2. Re: ANN: Upgrade Lorem and More for Dreamweaver CS5
            No, I'm sorry. It's Dreamweaver only. I created it seven years ago, so it's a bit of a golden oldie.
            • 3. Re: ANN: Upgrade Lorem and More for Dreamweaver CS5
              blv
              Works intermittently in:
              • DW CS5.5. (Version 11.5 Build 5344. Windows 7. Lorem and More 1.3.0.)
              • DW CS4 (Version 10.0 Build 4117. Windows XP Pro. Lorem and More 1.3.0.)
              • identical behavior in both
              It works fine IF:
              • I open a file, go immediately to Insert | Lorem & More | choose any combination of Type, Format and Amount and click OK;
              • I open a file, click anywhere in the file or move the cursor with the keyboard arrow keys and then choose Insert | Lorem.... (etc)
              BUT, if I type any keyboard character, number, Enter, Space or Backspace, then Lorem & More will NOT work.
              If I then close the file, reopen it and try Lorem & More again without first typing anything in the file, it will work.
              EDIT: just discovered that it will work again if I give the focus to something outside of the Document window (for example, click on a file or folder name in the Files panel, launch Help, click in the CSS Styles panel or Properties panel), then repeat the Insert | Lorem... steps. Also, it works if I click on something outside the Document window, then click again in the Document window. So:
              1. Type anything in the document
              2. Insert | Lorem....
              3. = FAIL
              2. Click somewhere else in Dreamweaver to remove the focus from the Document window
              3. Insert | Lorem...
              4. = WIN
              3. Click back in the Document window where you want to insert the lorem ipsum
              4. Insert | Lorem...
              5. = WIN
              Message was edited by: blv
              • 4. Re: ANN: Upgrade Lorem and More for Dreamweaver CS5
                Sorry, I can't reproduce this problem. Lorem and More works just fine in my Windows 7 64-bit setup, even if I type something into the page first.
