4 Replies Latest reply on May 4, 2010 10:53 AM by Peter deHaan
    how do you make a gradient background on a button in flex 4
    mcmcmark
      Hey everyone, this is driving me crazy. Below is my css for a button in file.  I want a gradient background on a button in flex 4. I can not for the life of me figure out how to do this. There is no longer the backgroundColors option. chromeColor is only a single color and all the examples I see on the web using fill, and linearGradient throw up errors so I assume these were only in the beta? This is very frustrating to not be able to do a simple thing in flex 4 that worked in flex 3. Any ideas? Thanks.
      Button {
      cornerRadius: 3;
      highlightAlphas: 0.36, 0;
      fillAlphas: 1, 1, 1, 1;
      paddingLeft: 5;
      paddingRight: 5;
      backgroundColors: #ff6600, #ff9900, #ffffff, #eeeeee;
      color: #ffffff;
      disabledColor: black;
      textRollOverColor: #000000;
      textSelectedColor: #000000;
      borderColor: #ff6600;
      fontWeight: normal;
        • 1. Re: how do you make a gradient background on a button in flex 4
          FTQuest Level 3
          As the shortest/simplest solution instead of 'chromeColor' try 'accentColor'. It gives very nice subtle gradients.
          But if you want to control it really, just make a custom skin - copy the default skin and then play with gradients in the layers.
          HTH,
          FTQuest
          • 2. Re: how do you make a gradient background on a button in flex 4
            mcmcmark Level 1
            accentColor does not work. I am still unable to figure out for the life of me how to apply a gradient on a flex 4 button so my buttons look like they did in flex 3.
            • 3. Re: how do you make a gradient background on a button in flex 4
              reidabel
              This may not be what you're looking for, but since you are stuck, I'll elaborate on what FTQuest was saying. It will only take a few minutes to do this.
              In FB4:
              1. right-click the button, choose "Create Skin", give it a package (directory) and name (filename), host component "spark.components.Button" and "Create as copy of" "spark.skins.spark.ButtonSkin".
              This creates junk.mxml for you, the skin file.
              2. In the source of junk.mxml, change layer 1 (shadow) and layer 2 (fill) colors as I did here in this code. Note that where you see {color#}, this is data-binding to a variable I've made in a color.as file that I've included in the skin file. In fact, that is ALL that I changed in the skin file it generated for me.
              snippet from colors.as:
              public
              var color1:int = new int(0xA1D190);
              snippet from junk.mxml:
              <![CDATA[
              include "Colors.as";
              layer changes in junk.mxml:
              <!-- layer 1: shadow -->
              <!--- @private -->
              <s:Rect id="shadow" left="-1" right="-1" top="-1" bottom="-1" radiusX="2">
              <s:fill>
              <s:LinearGradient rotation="90">
              <s:GradientEntry color="0x000000"
              color.down="
              {color5}"
              alpha="
              0.01"
              alpha.down="
              0" />
              color.down="
              {color6}"
              alpha="
              0.07"
              alpha.down="
              0.5" />
              </s:LinearGradient>
              </s:fill>
              </s:Rect>
              <!-- layer 2: fill -->
              <!--- @private -->
              <s:Rect id="fill" left="1" right="1" top="1" bottom="1" radiusX="2">
              <s:fill>
              <s:GradientEntry color="{color2}"
              color.over="
              {color3}"
              color.down="
              {color4}"
              alpha="
              0.85" />
              <s:GradientEntry color="{color4}"
              color.over="
              {color5}"
              color.down="
              {color6}"
              alpha="
              0.85" />
              </s:LinearGradient>
              </s:fill>
              </s:Rect>
              You can (and maybe should) hardcode colors in here to do your gradients. After this, your button will need to use the skin, like:
              <s:Button ... skinClass="Skins.junk">
              ... where "Skins" is the name of the package/directory I told it to create the skin in.
              This may not be ideal for you, but it's working for me. Regarding having variables for color values, I posted a thread this morning asking if this is the best way to do things or not, so I don't know if it's the way to go.
              Hope this helps ...
              • 4. Re: how do you make a gradient background on a button in flex 4
                Peter deHaan Level 4
                I believe the accentColor style only works if the Boolean emphasized property is set to true.
                There isn't a SWF, but some easy copy-paste examples at http://blog.flexexamples.com/2010/04/05/setting-the-accent-color-on-the-spark-button-contr ol-in-flex-4/ to see what the accentColor vs emphasized bits do.
                Peter
