2 Replies Latest reply on Apr 30, 2010 12:06 PM by Chorale0001
    Gradient Problem
    kelvinspace Level 1
      Does any body known how to change the default setting of gradient panel to CMYK?
        • 1. Re: Gradient Problem
          Chorale0001 Level 1
          This can only be done if you switch your file to RGB ( Files / document color mode / RGB ). Then double click on the color pin in the gradient tool and Voila. you got your RGB. You just have to do it on each Pin because it is not certain that the color tool will switch ( though it is supposed to ). So double click the pin just to be safe.
          Have fun
          • 2. Re: Gradient Problem
            Chorale0001 Level 1
            Erratum : For the color tools, you have to click its option ( top right corner of the tool ) top switch to RGB.
            You still can double click the Pin in the gradient tools.
