10 Replies Latest reply on May 14, 2010 9:45 AM by Mark Lindberg
    Assistance with Query for Multiple Rows as XML mapping
    Mark Lindberg Level 2
      I am trying to use the Query for Multiple Rows service to populate a schema that is not 'Flat' in the repeating node.
      I have used this service successfully when all elements to be populated are at the same level.
      I hope someone can tell me how to enter the mappings in the XML Information panel of the service operation.
      I have tried 'ATTRIBS/appt_req', and various other formats I could think of for mapping to the proper element name, but I always get XML errors.
      ACTIVES is the root, and ACTIVE is the repeating node.
      ATTRIBS does not repeat within ACTIVE.
      I am including a sample of the schema I am trying to load, and I can get data into the ACTIVES/ACTIVE level, but I have not been able to address to the ACTIVES/ACTIVE/ATTRIBS elements
      I will also have to figure out how to deal with the KEYWORDS node at some point.
      Thank You
              <dflt_pcc_notes>This is a test for Template 01 v1.2</dflt_pcc_notes>
                <keyword>key 1 v1.2</keyword>
                <keyword>key 2 v1.2</keyword>
                <keyword>key 3 v1.2</keyword>
