4 Replies Latest reply on May 10, 2010 10:04 AM by TherionWare
    (Date Math) data from text member 1 minus text from member 2
    MAC800 Level 1
      Help!  I'm building something like an "age verifier"
      >> I'm looking to subtract dates
      I have a text member called "DateToday" -- is todays date
      and a text member called "DateYouTyped" --is keyed by the user (first YEAR then MONTH then DAY) using YYYYMMDD format
      How do you "pull" the text from the members and use them as part of the formula ?
      And what would the formula look like
      I used Director help and found
      myBirthday = date(19650712)
      YourBirthday = date(19450529)
      would you do something like
      date1 = (member "DateToday").text
      date 2= (member("DateYouTyped).text
      and then
      put date1 - date2  ???  I want the result to go into a text member lets call it "finalanswer"
        • 1. Re: (Date Math) data from text member 1 minus text from member 2
          TherionWare
          The function below should enable you to do what you want.
          It returns the specified number of time periods between 1/1/[baseyear> (parameter b) and the specified date (parameter d). Parameter r specifies the return time period type.
          This is off the top of my head, but should be easily extensible to do what you want.
          Generally speaking dates are complicated, not least because of the different representations people use. There are several xtras that do this kind of thing,
          eg: http://www.scirius.com/eng/index.html and it's free unless you need recondite stuff, but doesn't work in shockwave.
          Rgds
          TW.
          on DatePrd b, d, r
          -- this function returns the specified number of time periods between the 1/1/ [base year] and the
          -- param b the base year
          -- param d this is the target date expected format YYYYMMDD HHMMSS
          -- param r 1 = return seconds, 2 = return minutes, 3 = return hours, 4 = return days, 5 = return weeks
          -- between 1/1/ base year and the target date
          if  (float( the systemdate.year ) / 4.0 = 0) AND (float( the systemdate.year ) / 400.0 <> 0) then
             tMon = [31, 29, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31]
          else
             tMon = [31, 28, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31]
          end if
          -- Assumes d in format YYYYMMDD HHMMSS
          dd = integer(chars(d, 7, 8 ))
          mm = integer(chars(d, 5, 6 ))
          yy = integer(chars(d, 1, 4 )) - b
          -- put dd, mm, yy
          tt = 0
          repeat with x = 1 to mm - 1
              tt = tt + tMon[x]
          end repeat
          repeat with x = 1 to yy - 1
             if (float( x ) / 4.0 = 0) AND ( float( x ) / 400.0 <> 0) then
                tt = tt + 366
             else
                tt = tt + 365
          end if
          end repeat
             hh = value( chars(the long time, 1, 2) )
             mm = value( chars(the long time, 4, 5) )
             ss = value( chars(the long time, 7, 8) )
          case r of
             1 : tt = ((tt + dd) * 24 * 60 * 60 ) + (hh * 3600) + (mm * 60) + ss -- seconds
             2 : tt = ((tt + dd) * 24 * 60 ) + (hh * 60) + mm -- minutes
             3 : tt = ((tt + dd) * 24) + hh -- hours
             4 : tt = tt + dd -- days
             5 : tt = (tt + dd) / 7 -- weeks
          otherwise
              tt = 0
          end case
          return tt
          end
          • 2. Re: (Date Math) data from text member 1 minus text from member 2
            TherionWare Level 1
            Opps. How embarsassing...
            That should of course have (probably) read:
            on DateSecs b, d, r
               if the number of chars in d = 8 then
                  d = d && "000000"
               end if
               -- a leap year is defined as any year that is exactly divisible by 4 but not exactly divisible by 400
               -- as in so far as I recall...
               if (float( chars(d,1, 4) ) / 4.0 = 0) AND (float( chars(d,1, 4) / 400.0) <> 0) then -- leap year check.
                  tMon = [31, 29, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31] -- is leap year
               else
                  tMon = [31, 28, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31] -- is not leap year
               end if
               -- put dd, mm, yy
               tt = 0
                  tt = tt + tMon[x]
               end repeat
                     tt = tt + 366
                  else
                     tt = tt + 365
               end if
               end repeat
               -- 19800101 235904
               -- 123456789012345
               if the number of chars in d = 15 then
               else
                  hh = 0
                 mm = 0
                  ss = 0
               end if
               case r of
                  1 tt = ((tt + dd) * 24 * 60 * 60 ) + (hh * 3600) + (mm * 60) + ss -- seconds
                  2 tt = ((tt + dd) * 24 * 60 ) + (hh * 60) + mm -- minutes
                  3 tt = ((tt + dd) * 24) + hh -- hours
                  4 tt = tt + dd -- days
                  5 tt = (tt + dd) / 7 -- weeks
                  6 tt = 0 -- months are difficult to do properly.
                  7 tt = 0 -- years are less difficult but ...
               otherwise
                  tt = 0
               end case
               return tt
            end
            • 3. Re: (Date Math) data from text member 1 minus text from member 2
              Sean_Wilson Adobe Community Professional
              You had one response that, admittedly, I didn't spend too long picking apart - mostly because it seemed over-complicated.
              I would approach what you describe by firstly ensuring there are enough numbers entered to create a valid date - this includes leading zeros in the case of day and month. Either that, or supply separate entry fields for year, month and day that can be individually validated. However, going with your posited 8-digit entry the "trick" is to grab the first 4 characters as the year, the next 2 as the month and the last 2 as the day and coerce them from strings to integers. Something like:
              sDateToday = member("DateToday").text
              tYear = value(sDateToday.char[1..4])
              tMonth = value(sDateToday.char[5..6])
              tDay = value(sDateToday.char[7..8])
              dToday = date(tYear, tMonth, tDay)
              sDateEntered = member("DateYouTyped").text
              tYear = value(sDateEntered.char[1..4])
              tMonth = value(sDateEntered.char[5..6])
              tDay = value(sDateEntered.char[7..8])
              dEntered = date(tYear, tMonth, tDay)
              -- this gives the number of days between the 2 dates
              -- it's not clear how you want the result formatted, so ...
              nDifference = dToday - dEntered
              member("finalanswer").text = "There are" && string(nDifference) && "days between the two dates entered"
              • 4. Re: (Date Math) data from text member 1 minus text from member 2
                TherionWare Level 1
                Erm, Good Point, as trivially shown by:
                d1 = date(1980, 2, 29)
                d2 = date(1981, 2, 28)
                put d2 - d1
                -- 365
                d1 = date(2000, 2, 29)
                d2 = date(2001, 2, 27)
                put d2 - d1
                -- 365
                That said:
                d1 = date(2000, 2, 35)
                d2 = date(2001, 2, 247)
                put d2 - d1
                -- 578
                Which I suppose just shows the need for input validation!
                Nice one.
                Best Regards
                TW.
