4 Replies Latest reply on May 1, 2010 10:26 AM by kas8
    File Format Not Supported: MOV
    kas8 Level 1
      I just wanted to start following some tutorials, but when I open the project file, I need to locate the media file. No problems here.
      But when I select the MOV file which is needed, and press SELECT , i get this message: File Format Not Supported.
      The file Im using is a regular QuickTime MOV File. However, when I use GSpot to determine the codec, it says its the dvc codec [DV].
      Im using Adobe Premier Pro CS4, with all latest updates.
      Does anyone know how to fix this issue?
      Note: I am able to play this file, as I do have QuickTime installed.
      PS: im using Windows Vista Home Premium 32bit.
      EDIT: I tried playing it with GOM Player but that didnt work. Quicktime somehow cant be started :S
