2 Replies Latest reply on May 3, 2010 10:37 AM by Necromanthus
    rotate camera inside a sphere (or room)
    CRB_Pat
      I found this source code to start from http://necromanthus.com/Games/ShockWave/tutorials/PanCamera.html (no target) - Unfortunately, I dont have enough knowledge with Lingo to understand what I need to change to make this work with my scene. I've been reading into this for weeks trying to force a simple understanding, with no luck - any help would be much appreciated!!! **specifically i need this type of function, all the camera functions that are included with Director, do not work...this also includes the chromlibs camera.**
      my W3D file is called "example2", its #13 (in my cast)
      the room or in this case sphere (with image attached) is called "Sphere01"
      and my camera is "Camera01"
      here is a copy of the script from the above link: (I dont need the "dummy")
      global w
      global demo
      global dmy
      global pCamera
      global way
      property pMouse
      on beginSprite me
        pCamera = w.camera(1)
        pMouse = the mouseLoc
        if demo = 1 then
          w.model("room").clone("dummy")
          dmy = w.model("dummy")
          dmy.visibility = #back
          dmy.scale(0.066)
          dmy.rotate(0,0,180)
          pCamera.transform.position = vector(-50,0,20)
          pCamera.pointAt(dmy,vector(0,0,1))
          way = 40.0
        end if
      end
      on mouseDown
      end
      on exitFrame me
        if the mouseDown then
          dMouse = (pMouse - the mouseLoc) / 100.0
          dx = dMouse.locV * 20
          dz = dMouse.locH * 20
          if demo = 1 then
            pCamera.rotate(vector(0,dx,dz),dmy)
          else
            pCamera.transform.rotation = pCamera.transform.rotation + vector(dx,0,dz)
          end if
        end if
        if demo = 1 then
          if keypressed(123) then
            -- Cursor Left is down
            pCamera.rotate(vector(0,0,-1),dmy)
          end if
          if keypressed(124) then
            -- Cursor Right is down
            pCamera.rotate(vector(0,0,1),dmy)
          end if
          if keypressed(125) then
            -- Cursor Up is down (Zoom In)
            if way < 80.0 then
              way = way + 0.2
              pCamera.translate(0,0,0.2)
            end if
          end if
          if keypressed(126) then
            -- Cursor Down is down (Zoom Out)
            if way > 0.0 then
              way = way - 0.2
              pCamera.translate(0,0,-0.2)
            end if
          end if
        end if
        go to frame 2
      end
        • 1. Re: rotate camera inside a sphere (or room)
          tyree_2 Level 2
          try the drag to rotate behavior link or group everything in your 3d program. and you can rotate everything that way
          • 2. Re: rotate camera inside a sphere (or room)
            Necromanthus Level 2
            Edit the "init" movie script and replace "room" with "example2"
            Edit the "frame2" script and replace:
            w.camera(1) with w.camera("Camera01")
            and
            "room" with "Sphere01"
            That's all.
