8 Replies Latest reply on May 2, 2010 4:42 PM by the_wine_snob
    PE 3.0.2 not saving volume levels
    tim7g
      Hello,
      I'm encountering a persistent audio problem when loading projects in Premiere Elements 3.0.2.  Whenever a saved project is reopened, the volume of every video clip in the timeline is set to minimum (-oo dB).  I can set the volume back by sliding the yellow line on the audio-wave, or by writing in the clip properties panel, and the project will then play perfectly, with sound.  But after saving and reloading the project, the sound is set back to -oo dB.  This is absolutely consistent and reproducible.
      Things I've tried so far: creating a new project with only one video clip; using video files from another (different) camera;  splitting clips into separate audio and video files and importing both into PE;  updating Windows sound drivers; using alternative ASIO sound drivers; a clean install of PE.  All source clips play perfectly in media player.
      Any help much appreciated.
      thanks,
      -Tim
        • 1. Re: PE 3.0.2 not saving volume levels
          tim7g Level 1
          Screenshots attached, and un-scaled versions available here: http://timgiles.free.fr/tmp/
          Between these two screenshots I have saved the project, and reloaded it.  Nothing else.
          • 2. Re: PE 3.0.2 not saving volume levels
            the_wine_snob Level 9
            Tim,
            Welcome to the forum.
            I cannot recall having ever read of such behavior, and at one time, I had read every post in this forum. Maybe Steve, or another long-time user has some thoughts.
            I would recommend that you also post to the Muvipix site's "Community." There is a PrE 3 forum there, and a lot of folk, who have been on PrE for many versions. Someone there should know of this problem, or perhaps have ideas of where to begin checking for the cause.
            • 3. Re: PE 3.0.2 not saving volume levels
              I'm with Hunt. In the four years since version 3 was released, this is the first I've heard of this issue.
              On the other hand, I see that you're working with MOD files, which often pose unique challenges to Premiere Elements and other PC-based video editors.
              • 4. Re: PE 3.0.2 not saving volume levels
                tim7g Level 1
                When needs must, a text editor can save the day -- and this is such a case.  After hours of testing, searching the web, and head-scratching, I have found the problem by loading the project files into Notepad++ and searching for the volume properties.
                This is a French edition of PE, running on a French laptop, configured (as in many European countries) to use a comma instead of a point as a decimals separator.  PE uses the local preferences to store decimals in its project files, but also uses commas to store lists of values.  When re-loading the project, there is an unresolvable ambiguity and the values cannot be read correctly.  Changing the number preferences in the Windows Control Panel to the English-style decimal point avoids the problem.
                This bug must have affected users all across Europe, and wasn't fixed by the v3.0.2 patch.  So, Adobe, I'm afraid I'm rather unimpressed.
                • 5. Re: PE 3.0.2 not saving volume levels
                  Amazing troubleshooting, Tim!
                  • 6. Re: PE 3.0.2 not saving volume levels
                    Very interesting, and thank you for reporting.
                    I am surprised that we've not seen this issue before, as many subscribers here are in Europe, and use the language/conventions in those countries, plus the Adobe programs. In the PrPro forum, there are hundreds of Euro-users with many different languages, especially FR and Dutch.
                    I have seen issues with the colon vs semi-colon delineators, especially for Sub-titles in Encore, but never this issue.
                    Your work and the solution is greatly appreciated,
                    • 7. Re: PE 3.0.2 not saving volume levels
                      tim7g Level 1
                      Sorry for the rather grumpy ending to my last post.
                      Although French is not my first language (the software belongs to my French wife), I do speak French tolerably well.  So I'm surprised that I was not able to find any previous references to this problem online, either in English or French.  Can anybody confirm whether more recent versions of Premiere suffer from this bug?
                      • 8. Re: PE 3.0.2 not saving volume levels
                        Tim,
                        I wish that I could help, but with both PrE and PrPro, I have never seen mention of such. Your report was total news to me.
                        What I would do is post to the PrPro forum, and just mention "Premiere" and NOT PrElements (or you'll just get pointers back to this forum), and ask that question. I know a dozen folk, who are on other languages (OS, computer and program), and ask about the commas. If there is a known issue, those Euro-contributors will know. Now, this will NOT tell you specifically about PrE, but will give you a clue as to how Adobe handles this. I know that we have 2 Dutch, 2 Spanish and at least one French subscriber there, and all do work in full Euro-versions and PAL Projects.
                        Now, are you doing PAL Projects, or NTSC? Might be something there, regardless of the language of the program, OS and computer setup.
                        PS - I promise to not divulge that you are asking about PrE. If asked, just tell 'em CS3.
