4 Replies Latest reply on May 14, 2010 7:04 AM by TeotiGraphix
    Global Scroll policy
    puddytat5000 Level 1
      Hi
      Is it possible to set the scroll policies for all controls globally? or do I have to set them individually for each control?
        • 1. Re: Global Scroll policy
          Hi, any ideas on this?
          • 2. Re: Global Scroll policy
            BhaskerChari Level 4
            You need to set individually for all components there is no other way I guess..
            Thanx,
            Bhasker Chari
            • 3. Re: Global Scroll policy
              TeotiGraphix Level 3
              Each control is it's own instance, so there is no way to set them all at once globally.
              You could however listen to the main application's Event.ADDED since it bubbles and check the type of each instance. If it's a container, set the scroll policy for it. In a way this might be global.
                             xmlns:mx="library://ns.adobe.com/flex/mx"
                             added="application_addedHandler(event)">
                  <fx:Script>
                      <![CDATA[
                          import mx.core.Container;
                          import mx.core.ScrollPolicy;
                          protected function application_addedHandler(event:Event):void
                              var container:Container = event.target as Container;
                              if (event.target is Container)
                                  trace("Container " + event.target.id);
                                  container.verticalScrollPolicy = ScrollPolicy.OFF;
                  </fx:Script>
                  <mx:VBox id="container1">
                      <mx:VBox id="container2">
                      </mx:VBox>
                  </mx:VBox>
              </s:Application>
              You could do the same thing with Groups etc.
              Mike
              • 4. Re: Global Scroll policy
                sorry duplicate post
