14 Replies Latest reply on Sep 17, 2012 8:15 AM by Diseño Web Bogota
    Flash builder 4 crash on start
    wwwcad Level 1
      I can't start the builder in my Windows XP system, it only lets a file with the name hs_err_pid8040.log o hs_err_pidxxx.log in the builder folder.
      # A fatal error has been detected by the Java Runtime Environment:
      #  Internal Error (0xe06d7363), pid=8040, tid=6068
      # JRE version: 6.0_16-b01
      # Java VM: Java HotSpot(TM) Client VM (14.2-b01 mixed mode windows-x86 )
      # Problematic frame:
      # C  [kernel32.dll+0x12aeb]
      # If you would like to submit a bug report, please visit:
      #   http://java.sun.com/webapps/bugreport/crash.jsp
      # The crash happened outside the Java Virtual Machine in native code.
      # See problematic frame for where to report the bug.
      ---------------  T H R E A D  ---------------
      Current thread (0x00936800):  JavaThread "main" [_thread_in_native, id=6068, stack(0x00030000,0x00130000)]
      siginfo: ExceptionCode=0xe06d7363, ExceptionInformation=0x19930520 0x0012be20 0x361c0800
      Registers:
      EAX=0x0012bd78, EBX=0x0012bee0, ECX=0x00000000, EDX=0x00000003
      ESP=0x0012bd74, EBP=0x0012bdc8, ESI=0x0012be00, EDI=0x0012c194
      EIP=0x7c812aeb, EFLAGS=0x00000206
      Top of Stack: (sp=0x0012bd74)
      0x0012bd74:   0012bec4 e06d7363 00000001 00000000
      0x0012bd84:   7c812aeb 00000003 19930520 0012be20
      0x0012bd94:   361c0800 3636ba40 3636ded0 00000017
      0x0012bda4:   00000017 0012be2c 00000000 360d19cf
      0x0012bdb4:   3636ba40 0000001f 3636ded0 00000017
      0x0012bdc4:   0012c194 0012be00 3611716a e06d7363
      0x0012bdd4:   00000001 00000003 0012bdf4 e06d7363
      0x0012bde4:   00000001 00000000 00000000 00000003
      Instructions: (pc=0x7c812aeb)
      0x7c812adb:   8d 7d c4 f3 a5 5f 8d 45 b0 50 ff 15 10 15 80 7c
      0x7c812aeb:   5e c9 c2 10 00 85 ff 0f 8e 36 93 ff ff 8b 55 fc
      Stack: [0x00030000,0x00130000],  sp=0x0012bd74,  free space=1007k
      Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
      C  [amtservices.dll+0x4716a]
      C  [amtservices.dll+0x727a8]
      Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
      j  com.adobe.flexide.amt.AMTLib.AMTObtainProductLicense(IILjava/lang/String;Ljava/lang/Strin g;Ljava/lang/String;Ljava/lang/String;IILjava/lang/String;)I+0
      j  com.adobe.flexide.amt.AMTLib.ObtainProductLicense(Ljava/lang/String;Ljava/lang/String;Lja va/lang/String;Ljava/lang/String;IILjava/lang/String;Z)I+27
      j  com.adobe.flexide.amt.Activator.AMT_ObtainLicense(Ljava/lang/String;Ljava/lang/String;IIZ )I+32
      j  com.adobe.flexbuilder.ui.asn.ASNUIBridge.start()Z+43
      j  com.adobe.flexbuilder.ui.UIPlugin.start(Lorg/osgi/framework/BundleContext;)V+21
      j  org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run()Ljava/lang/Object;+64
      v  ~StubRoutines::call_stub
      j  java.security.AccessController.doPrivileged(Ljava/security/PrivilegedExceptionAction;)Lja va/lang/Object;+0
      j  org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(Lorg/osgi/frame work/BundleActivator;)V+22
      j  org.eclipse.osgi.framework.internal.core.BundleContextImpl.start()V+23
      j  org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(I)V+379
      j  org.eclipse.osgi.framework.internal.core.AbstractBundle.start(I)V+20
      j  org.eclipse.osgi.framework.util.SecureAction.start(Lorg/osgi/framework/Bundle;I)V+8
      J  org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(Ljava/lan g/String;Ljava/lang/Class;Lorg/eclipse/osgi/baseadaptor/loader/ClasspathManager;)V
      J  org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(Ljava/lang/String;)Lj ava/lang/Class;
      J  org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(Ljava/lang/String;)Ljava/lan g/Class;
      j  org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(Ljava/lang/String;)Ljava/l ang/Class;+8
      J  org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(Ljava/lang/String;ZLjava/ lang/ClassLoader;)Ljava/lang/Class;
      J  org.eclipse.osgi.internal.loader.BundleLoader.findClass(Ljava/lang/String;Z)Ljava/lang/Cl ass;
      J  org.eclipse.osgi.internal.loader.BundleLoader.findClass(Ljava/lang/String;)Ljava/lang/Cla ss;
      J  org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(Ljava/lang/String;Z)Lj ava/lang/Class;
      J  java.lang.ClassLoader.loadClass(Ljava/lang/String;)Ljava/lang/Class;
      J  java.lang.ClassLoader.loadClassInternal(Ljava/lang/String;)Ljava/lang/Class;
      j  com.adobe.flexbuilder.standalone.SplashHandler.init(Lorg/eclipse/swt/widgets/Shell;)V+120
      j  org.eclipse.ui.internal.Workbench$6.run()V+174
      j  org.eclipse.core.runtime.SafeRunner.run(Lorg/eclipse/core/runtime/ISafeRunnable;)V+5
      j  org.eclipse.ui.internal.Workbench.createSplashWrapper()V+32
      j  org.eclipse.ui.internal.Workbench.runUI()I+111
      j  org.eclipse.ui.internal.Workbench.access$4(Lorg/eclipse/ui/internal/Workbench;)I+1
      j  org.eclipse.ui.internal.Workbench$5.run()V+55
      j  org.eclipse.core.databinding.observable.Realm.runWithDefault(Lorg/eclipse/core/databindin g/observable/Realm;Ljava/lang/Runnable;)V+12
      j  org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Lorg/eclipse/swt/widgets/Display; Lorg/eclipse/ui/application/WorkbenchAdvisor;)I+18
      j  org.eclipse.ui.PlatformUI.createAndRunWorkbench(Lorg/eclipse/swt/widgets/Display;Lorg/ecl ipse/ui/application/WorkbenchAdvisor;)I+2
      j  com.adobe.flexbuilder.standalone.FlexBuilderApplication.start(Lorg/eclipse/equinox/app/IA pplicationContext;)Ljava/lang/Object;+100
      j  org.eclipse.equinox.internal.app.EclipseAppHandle.run(Ljava/lang/Object;)Ljava/lang/Objec t;+135
      j  org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(Ljava/lang/Ob ject;)Ljava/lang/Object;+103
      j  org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(Ljava/lang/Object;)Lja va/lang/Object;+29
      j  org.eclipse.core.runtime.adaptor.EclipseStarter.run(Ljava/lang/Object;)Ljava/lang/Object; +149
      j  org.eclipse.core.runtime.adaptor.EclipseStarter.run([Ljava/lang/String;Ljava/lang/Runnabl e;)Ljava/lang/Object;+183
      j  sun.reflect.NativeMethodAccessorImpl.invoke0(Ljava/lang/reflect/Method;Ljava/lang/Object; [Ljava/lang/Object;)Ljava/lang/Object;+0
      j  sun.reflect.NativeMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/l ang/Object;+87
      j  sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Lja va/lang/Object;+6
      j  java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+ 161
      j  org.eclipse.equinox.launcher.Main.invokeFramework([Ljava/lang/String;[Ljava/net/URL;)V+21 1
      j  org.eclipse.equinox.launcher.Main.basicRun([Ljava/lang/String;)V+114
      j  org.eclipse.equinox.launcher.Main.run([Ljava/lang/String;)I+4
      ---------------  P R O C E S S  ---------------
      Java Threads: ( => current thread )
        0x33d9bc00 JavaThread "Thread-1" [_thread_in_native, id=3428, stack(0x35d80000,0x35e80000)]
        0x33cfb000 JavaThread "[Timer] - Main Queue Handler" daemon [_thread_blocked, id=4840, stack(0x34d90000,0x34e90000)]
        0x33e56400 JavaThread "Worker-1" [_thread_blocked, id=6964, stack(0x34b90000,0x34c90000)]
        0x33cd1400 JavaThread "Provisioning Event Dispatcher" daemon [_thread_blocked, id=6876, stack(0x34a90000,0x34b90000)]
        0x33cbdc00 JavaThread "Worker-0" [_thread_blocked, id=4612, stack(0x34990000,0x34a90000)]
        0x34044000 JavaThread "Bundle File Closer" daemon [_thread_blocked, id=1216, stack(0x34080000,0x34180000)]
        0x33733800 JavaThread "Start Level Event Dispatcher" daemon [_thread_blocked, id=4484, stack(0x33b80000,0x33c80000)]
        0x33758800 JavaThread "Framework Event Dispatcher" daemon [_thread_blocked, id=7004, stack(0x33a80000,0x33b80000)]
        0x33758400 JavaThread "State Saver" [_thread_blocked, id=7660, stack(0x33980000,0x33a80000)]
        0x32e30c00 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=5996, stack(0x334a0000,0x335a0000)]
        0x32e2ac00 JavaThread "CompilerThread0" daemon [_thread_blocked, id=1344, stack(0x333a0000,0x334a0000)]
        0x32e29400 JavaThread "Attach Listener" daemon [_thread_blocked, id=6608, stack(0x332a0000,0x333a0000)]
        0x32e28000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=6596, stack(0x331a0000,0x332a0000)]
        0x32e17c00 JavaThread "Finalizer" daemon [_thread_blocked, id=7752, stack(0x330a0000,0x331a0000)]
        0x32e13000 JavaThread "Reference Handler" daemon [_thread_blocked, id=6244, stack(0x32fa0000,0x330a0000)]
      =>0x00936800 JavaThread "main" [_thread_in_native, id=6068, stack(0x00030000,0x00130000)]
      Other Threads:
        0x32e10000 VMThread [stack: 0x32ea0000,0x32fa0000] [id=4600]
        0x32e33000 WatcherThread [stack: 0x335a0000,0x336a0000] [id=6544]
      VM state:not at safepoint (normal execution)
      VM Mutex/Monitor currently owned by a thread: None
      Heap
      def new generation   total 18176K, used 6949K [0x02a90000, 0x03e40000, 0x051f0000)
        eden space 16192K,  30% used [0x02a90000, 0x02f69650, 0x03a60000)
        from space 1984K, 100% used [0x03c50000, 0x03e40000, 0x03e40000)
        to   space 1984K,   0% used [0x03a60000, 0x03a60000, 0x03c50000)
      tenured generation   total 241984K, used 14787K [0x051f0000, 0x13e40000, 0x22a90000)
         the space 241984K,   6% used [0x051f0000, 0x06060ea0, 0x06061000, 0x13e40000)
      compacting perm gen  total 65536K, used 16042K [0x22a90000, 0x26a90000, 0x32a90000)
         the space 65536K,  24% used [0x22a90000, 0x23a3abe8, 0x23a3ac00, 0x26a90000)
      No shared spaces configured.
      Dynamic libraries:
      0x00400000 - 0x0040e000     C:\Archivos de programa\Adobe\Adobe Flash Builder 4\FlashBuilder.exe
      0x7c910000 - 0x7c9c5000     C:\WINDOWS\system32\ntdll.dll
      0x7c800000 - 0x7c903000     C:\WINDOWS\system32\kernel32.dll
      0x7e390000 - 0x7e421000     C:\WINDOWS\system32\USER32.dll
      0x77ef0000 - 0x77f39000     C:\WINDOWS\system32\GDI32.dll
      0x773a0000 - 0x774a3000     C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x- ww_35d4ce83\COMCTL32.dll
      0x77be0000 - 0x77c38000     C:\WINDOWS\system32\msvcrt.dll
      0x77da0000 - 0x77e4c000     C:\WINDOWS\system32\ADVAPI32.dll
      0x77e50000 - 0x77ee2000     C:\WINDOWS\system32\RPCRT4.dll
      0x77fc0000 - 0x77fd1000     C:\WINDOWS\system32\Secur32.dll
      0x77f40000 - 0x77fb6000     C:\WINDOWS\system32\SHLWAPI.dll
      0x76340000 - 0x7635d000     C:\WINDOWS\system32\IMM32.DLL
      0x6d710000 - 0x6d723000     C:\ARCHIV~1\KASPER~1\KASPER~1\mzvkbd.dll
      0x76bb0000 - 0x76bbb000     C:\WINDOWS\system32\PSAPI.DLL
      0x6d730000 - 0x6d743000     C:\ARCHIV~1\KASPER~1\KASPER~1\mzvkbd3.dll
      0x6d020000 - 0x6d035000     C:\ARCHIV~1\KASPER~1\KASPER~1\adialhk.dll
      0x6d4c0000 - 0x6d4c6000     C:\ARCHIV~1\KASPER~1\KASPER~1\kloehk.dll
      0x72000000 - 0x72014000     C:\Archivos de programa\Adobe\Adobe Flash Builder 4\plugins\org.eclipse.equinox.launcher.win32.win32.x86_1.0.200.v20090519\eclipse_1206.dll
      0x77bd0000 - 0x77bd8000     C:\WINDOWS\system32\VERSION.dll
      0x6d800000 - 0x6da8b000     C:\Archivos de programa\Adobe\Adobe Flash Builder 4\jre\bin\client\jvm.dll
      0x76b00000 - 0x76b2e000     C:\WINDOWS\system32\WINMM.dll
      0x7c340000 - 0x7c396000     C:\WINDOWS\system32\MSVCR71.dll
      0x6d7b0000 - 0x6d7bc000     C:\Archivos de programa\Adobe\Adobe Flash Builder 4\jre\bin\verify.dll
      0x6d330000 - 0x6d34f000     C:\Archivos de programa\Adobe\Adobe Flash Builder 4\jre\bin\java.dll
      0x6d290000 - 0x6d298000     C:\Archivos de programa\Adobe\Adobe Flash Builder 4\jre\bin\hpi.dll
      0x6d7f0000 - 0x6d7ff000     C:\Archivos de programa\Adobe\Adobe Flash Builder 4\jre\bin\zip.dll
      0x68000000 - 0x68036000     C:\WINDOWS\system32\rsaenh.dll
      0x76630000 - 0x766e5000     C:\WINDOWS\system32\USERENV.dll
      0x597f0000 - 0x59845000     C:\WINDOWS\system32\netapi32.dll
      0x6d610000 - 0x6d623000     C:\Archivos de programa\Adobe\Adobe Flash Builder 4\jre\bin\net.dll
      0x71a30000 - 0x71a47000     C:\WINDOWS\system32\WS2_32.dll
      0x71a20000 - 0x71a28000     C:\WINDOWS\system32\WS2HELP.dll
      0x719d0000 - 0x71a10000     C:\WINDOWS\System32\mswsock.dll
      0x76ee0000 - 0x76f07000     C:\WINDOWS\system32\DNSAPI.dll
      0x76d20000 - 0x76d39000     C:\WINDOWS\system32\iphlpapi.dll
      0x76f70000 - 0x76f78000     C:\WINDOWS\System32\winrnr.dll
      0x76f20000 - 0x76f4d000     C:\WINDOWS\system32\WLDAP32.dll
      0x33940000 - 0x33959000     C:\Archivos de programa\Bonjour\mdnsNSP.dll
      0x76f80000 - 0x76f86000     C:\WINDOWS\system32\rasadhlp.dll
      0x6d630000 - 0x6d639000     C:\Archivos de programa\Adobe\Adobe Flash Builder 4\jre\bin\nio.dll
      0x34e90000 - 0x34ee9000     C:\Archivos de programa\Adobe\Adobe Flash Builder 4\configuration\org.eclipse.osgi\bundles\297\1\.cp\swt-win32-3555.dll
      0x774b0000 - 0x775ed000     C:\WINDOWS\system32\ole32.dll
      0x770f0000 - 0x7717b000     C:\WINDOWS\system32\OLEAUT32.dll
      0x76360000 - 0x763aa000     C:\WINDOWS\system32\comdlg32.dll
      0x7e6a0000 - 0x7eec1000     C:\WINDOWS\system32\SHELL32.dll
      0x74d20000 - 0x74d8b000     C:\WINDOWS\system32\USP10.dll
      0x63000000 - 0x630e6000     C:\WINDOWS\system32\WININET.dll
      0x34f00000 - 0x34f09000     C:\WINDOWS\system32\Normaliz.dll
      0x34f10000 - 0x35042000     C:\WINDOWS\system32\urlmon.dll
      0x5dca0000 - 0x5de88000     C:\WINDOWS\system32\iertutil.dll
      0x5ad70000 - 0x5ada8000     C:\WINDOWS\system32\uxtheme.dll
      0x75160000 - 0x7518e000     C:\WINDOWS\system32\msctfime.ime
      0x353f0000 - 0x35404000     C:\Archivos de programa\Adobe\Adobe Flash Builder 4\configuration\org.eclipse.osgi\bundles\297\1\.cp\swt-gdip-win32-3555.dll
      0x4eba0000 - 0x4ed46000     C:\WINDOWS\WinSxS\x86_Microsoft.Windows.GdiPlus_6595b64144ccf1df_1.0.2600.5512_x-ww_dfb54 e0c\gdiplus.dll
      0x35810000 - 0x35851000     C:\Archivos de programa\Adobe\Adobe Flash Builder 4\plugins\com.adobe.flexide.nativelibs_4.0.0.272416\os\win32\x86\BridgeTalk.dll
      0x35900000 - 0x3596a000     C:\Archivos de programa\Adobe\Adobe Flash Builder 4\plugins\com.adobe.flexide.nativelibs_4.0.0.272416\libs\adobe_caps.dll
      0x778f0000 - 0x779e7000     C:\WINDOWS\system32\SETUPAPI.dll
      0x77660000 - 0x77681000     C:\WINDOWS\system32\NTMARTA.DLL
      0x71b90000 - 0x71ba3000     C:\WINDOWS\system32\SAMLIB.dll
      0x35f80000 - 0x35f97000     C:\Archivos de programa\Adobe\Adobe Flash Builder 4\plugins\com.adobe.flexbuilder.utils.osnative_4.0.0.272416\os\win32\x86\JNIToNativeBridg e.dll
      0x35970000 - 0x3597a000     C:\Archivos de programa\Adobe\Adobe Flash Builder 4\plugins\com.adobe.flexide.amt_4.0.0.272416\os\win32\x86\amt_win_jnilib.dll
      0x78480000 - 0x7850e000     C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.4148_x-ww_d495ac4e\MS VCP90.dll
      0x78520000 - 0x785c3000     C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.4148_x-ww_d495ac4e\MS VCR90.dll
      0x35fc0000 - 0x360a6000     C:\Archivos de programa\Adobe\Adobe Flash Builder 4\plugins\com.adobe.flexide.amt_4.0.0.272416\os\win32\x86\amtlib.dll
      0x360d0000 - 0x361e4000     C:\Archivos de programa\Adobe\Adobe Flash Builder 4\plugins\com.adobe.flexide.amt_4.0.0.272416\os\win32\x86\amtservices.dll
      0x4d550000 - 0x4d5a9000     C:\WINDOWS\system32\WINHTTP.dll
      0x36470000 - 0x364da000     C:\Archivos de programa\Adobe\Adobe Flash Builder 4\plugins\com.adobe.flexide.amt_4.0.0.272416\os\win32\x86\adobe_caps.dll
      0x36600000 - 0x36628000     C:\Archivos de programa\Adobe\Adobe Flash Builder 4\plugins\com.adobe.flexide.amt_4.0.0.272416\os\win32\x86\asneu.dll
      0x36750000 - 0x36a26000     C:\WINDOWS\system32\xpsp2res.dll
      0x76f90000 - 0x7700f000     C:\WINDOWS\system32\CLBCATQ.DLL
      0x77010000 - 0x770e0000     C:\WINDOWS\system32\COMRes.dll
      0x74e80000 - 0x74e88000     C:\WINDOWS\system32\wbem\wbemprox.dll
      0x75220000 - 0x75257000     C:\WINDOWS\system32\wbem\wbemcomn.dll
      0x74e60000 - 0x74e6e000     C:\WINDOWS\system32\wbem\wbemsvc.dll
      0x75630000 - 0x756a6000     C:\WINDOWS\system32\wbem\fastprox.dll
      0x76030000 - 0x76095000     C:\WINDOWS\system32\MSVCP60.dll
      0x76760000 - 0x76773000     C:\WINDOWS\system32\NTDSAPI.dll
      0x76bf0000 - 0x76c1e000     C:\WINDOWS\system32\WINTRUST.dll
      0x77a50000 - 0x77ae6000     C:\WINDOWS\system32\CRYPT32.dll
      0x77af0000 - 0x77b02000     C:\WINDOWS\system32\MSASN1.dll
      0x76c50000 - 0x76c78000     C:\WINDOWS\system32\IMAGEHLP.dll
      VM Arguments:
      jvm_args: -Xms256m -Xmx512m -XX:MaxPermSize=256m -XX:PermSize=64m -Djava.net.preferIPv4Stack=true -Dorg.eclipse.equinox.p2.reconciler.dropins.directory=dropins
      java_command: <unknown>
      Launcher Type: generic
      Environment Variables:
      PATH=C:/Archivos de programa/Adobe/Adobe Flash Builder 4/jre/bin/client;C:/Archivos de programa/Adobe/Adobe Flash Builder 4/jre/bin;C:\Archivos de programa\Adobe\Adobe Flash Builder 4\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Archivos de programa\TortoiseSVN\bin
      USERNAME=Imagina1
      OS=Windows_NT
      PROCESSOR_IDENTIFIER=x86 Family 6 Model 23 Stepping 10, GenuineIntel
      ---------------  S Y S T E M  ---------------
      OS: Windows XP Build 2600 Service Pack 3
      CPU:total 4 (4 cores per cpu, 1 threads per core) family 6 model 23 stepping 10, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3
      Memory: 4k page, physical 2084628k(711692k free), swap 4017868k(2375388k free)
      vm_info: Java HotSpot(TM) Client VM (14.2-b01) for windows-x86 JRE (1.6.0_16-b01), built on Jul 31 2009 11:26:58 by "java_re" with MS VC++ 7.1
      time: Sat May 01 18:54:20 2010
      elapsed time: 6 seconds
        • 1. Re: Flash builder 4 crash on start
          wwwcad Level 1
          Well, i check with "Process Explorer" and the service causing problems is winmgmt, you can PAUSE that service inside svchost.com and start Flex Builder without problems.
          Just in case anyone else is having the same trouble.
          http://www.imaginacolombia.com
          • 2. Re: Flash builder 4 crash on start
            ciroppina
            If You are experiencing a message "Error: Java Heap Space" when building Falsh Builder 4 Workpace, or cleaning projects, or generating bin-Relase (expecially for AIR) or launching a Flex App (sdk 3/4) from the IDE
            here You are the solutions:
            There are two reasons:
            a) Flash Builder 4 IDE (Eclipse+Equinox) memory is finshed!
            b) Run/Debug actions memory in finished!
            Solutions
            Solution for case a):
            - Go to Flash Builder 4 install_dir
            - edit file: FlashBuilder.ini
            - increase the following parameters, as follows (or more, depening on system available RAM memory):
            -Xms256m -> -Xms384m
            -Xmx384m -> -Xmx512m
            [if the previous 2 parms are absent, add them to the file, one for line]
            - save, close file .ini editing
            - restart Falsh Builder 4
            Solution for case b):
            - Go to each of two  /sdks folders, both 3.5 and 4.0, then enter subfolder /bin
            - edit files: jvm.config
            - modufy args on the line java.args= as follows (or more):
                 to: -Xms384m -Xmx512m -Dsun.io.useCanonCaches=false
            - save, close editing of jvm.config files
            Tha's all folks!
            • 3. Re: Flash builder 4 crash on start
              zooomproductions
              I am experiencing the same problem. The tweak with pausing the winmgtm service did not work.
              #  EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x6801f1d3, pid=1156, tid=2744
              # C  [FlDbg10e.ocx+0x17f1d3]
              Current thread (0x00289000):  JavaThread "main" [_thread_in_native, id=2744, stack(0x00090000,0x00190000)]
              siginfo: ExceptionCode=0xc0000005, writing address 0xeaba061c
              Registers:
              EAX=0x7ebb7479, EBX=0x001842ac, ECX=0x0018429c, EDX=0x000005c4
              ESP=0x0018426c, EBP=0x00184280, ESI=0x3abcaee0, EDI=0x3aa870e0
              EIP=0x6801f1d3, EFLAGS=0x00210246
              Top of Stack: (sp=0x0018426c)
              0x0018426c:   3abcbfa0 3abcaee0 001842ac 0018429c
              0x0018427c:   0018429c 001842f4 3e2600db 3aa870e0
              0x0018428c:   00000000 3abdc0f8 3aa80918 3ab51c70
              0x0018429c:   3ab51c70 3ab96ac0 3ab96ac0 3aa80918
              0x001842ac:   3abcbfa0 3aa80918 00000000 00000000
              0x001842bc:   001843a8 00000004 00184320 00000000
              0x001842cc:   001842dc 001842ec 00000000 00000000
              0x001842dc:   001842a4 0018429c 3ab96ac0 3ab51c70
              Instructions: (pc=0x6801f1d3)
              0x6801f1c3:   c2 04 00 55 8b ec 51 51 53 56 57 0f 31 8b 7d 08
              0x6801f1d3:   ff 04 b9 ff 81 00 04 00 00 8b b1 04 04 00 00 99
              Stack: [0x00090000,0x00190000],  sp=0x0018426c,  free space=976k
              C  0x3e2600db
              C  [FlDbg10e.ocx+0x233472]
              j  org.eclipse.swt.internal.win32.OS.DispatchMessageW(Lorg/eclipse/swt/internal/win32/MSG;)I +0
              j  org.eclipse.swt.internal.win32.OS.DispatchMessage(Lorg/eclipse/swt/internal/win32/MSG;)I+ 7
              j  org.eclipse.swt.widgets.Display.readAndDispatch()Z+54
              j  org.eclipse.ui.application.WorkbenchAdvisor.openWindows()Z+44
              j  org.eclipse.ui.internal.Workbench$28.runWithException()V+27
              j  org.eclipse.ui.internal.StartupThreading$StartupRunnable.run()V+1
              j  org.eclipse.swt.widgets.RunnableLock.run()V+11
              j  org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Z)Z+29
              j  org.eclipse.swt.widgets.Display.runAsyncMessages(Z)Z+5
              j  org.eclipse.swt.widgets.Display.readAndDispatch()Z+81
              j  org.eclipse.ui.internal.Workbench.runUI()I+220
                0x35ba3800 JavaThread "Thread-7" daemon [_thread_blocked, id=2876, stack(0x3a460000,0x3a560000)]
                0x35ba3000 JavaThread "Code Model Worker" [_thread_blocked, id=640, stack(0x39590000,0x39690000)]
                0x35ba2c00 JavaThread "Code Model Worker" [_thread_blocked, id=2084, stack(0x39490000,0x39590000)]
                0x35ba2400 JavaThread "Thread-4" [_thread_in_native, id=2964, stack(0x39210000,0x39310000)]
                0x34f34c00 JavaThread "Thread-2" [_thread_blocked, id=3256, stack(0x37f30000,0x38030000)]
                0x359aa400 JavaThread "Thread-1" [_thread_in_native, id=3076, stack(0x37780000,0x37880000)]
                0x34f31c00 JavaThread "[Timer] - Main Queue Handler" daemon [_thread_blocked, id=1824, stack(0x368b0000,0x369b0000)]
                0x35a45800 JavaThread "Provisioning Event Dispatcher" daemon [_thread_blocked, id=3500, stack(0x36630000,0x36730000)]
                0x35bea000 JavaThread "Worker-0" [_thread_blocked, id=3420, stack(0x364f0000,0x365f0000)]
                0x35a89000 JavaThread "Bundle File Closer" daemon [_thread_blocked, id=3116, stack(0x362c0000,0x363c0000)]
                0x34ed9800 JavaThread "Start Level Event Dispatcher" daemon [_thread_blocked, id=3156, stack(0x35580000,0x35680000)]
                0x34e9f000 JavaThread "Framework Event Dispatcher" daemon [_thread_blocked, id=312, stack(0x35480000,0x35580000)]
                0x34ee2800 JavaThread "State Saver" [_thread_blocked, id=3892, stack(0x35280000,0x35380000)]
                0x0229d400 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=3616, stack(0x34ba0000,0x34ca0000)]
                0x02298000 JavaThread "CompilerThread0" daemon [_thread_blocked, id=2976, stack(0x34a60000,0x34b60000)]
                0x02297800 JavaThread "Attach Listener" daemon [_thread_blocked, id=1372, stack(0x34920000,0x34a20000)]
                0x0228d000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=1448, stack(0x347e0000,0x348e0000)]
                0x0225f800 JavaThread "Finalizer" daemon [_thread_blocked, id=3888, stack(0x346a0000,0x347a0000)]
                0x0225ac00 JavaThread "Reference Handler" daemon [_thread_blocked, id=428, stack(0x34560000,0x34660000)]
              =>0x00289000 JavaThread "main" [_thread_in_native, id=2744, stack(0x00090000,0x00190000)]
              Other Threads:
                0x02257000 VMThread [stack: 0x34460000,0x34560000] [id=3728]
                0x0229e800 WatcherThread [stack: 0x34ce0000,0x34de0000] [id=2304]
              Heap
              def new generation   total 18176K, used 11094K [0x042d0000, 0x05680000, 0x06a30000)
                eden space 16192K,  66% used [0x042d0000, 0x04d58928, 0x052a0000)
                from space 1984K,  15% used [0x052a0000, 0x052ed268, 0x05490000)
                to   space 1984K,   0% used [0x05490000, 0x05490000, 0x05680000)
              tenured generation   total 241984K, used 15655K [0x06a30000, 0x15680000, 0x242d0000)
                 the space 241984K,   6% used [0x06a30000, 0x07979cf0, 0x07979e00, 0x15680000)
              compacting perm gen  total 65536K, used 31761K [0x242d0000, 0x282d0000, 0x342d0000)
                 the space 65536K,  48% used [0x242d0000, 0x261d4420, 0x261d4600, 0x282d0000)
              Dynamic libraries:
              0x00400000 - 0x0040e000     D:\Program Files (x86)\Adobe\Adobe Flash Builder 4\FlashBuilder.exe
              0x77ce0000 - 0x77e60000     C:\Windows\SysWOW64\ntdll.dll
              0x76740000 - 0x76840000     C:\Windows\syswow64\kernel32.dll
              0x75ae0000 - 0x75b26000     C:\Windows\syswow64\KERNELBASE.dll
              0x76940000 - 0x76a40000     C:\Windows\syswow64\USER32.dll
              0x75bb0000 - 0x75c40000     C:\Windows\syswow64\GDI32.dll
              0x77cb0000 - 0x77cba000     C:\Windows\syswow64\LPK.dll
              0x77840000 - 0x778dd000     C:\Windows\syswow64\USP10.dll
              0x76230000 - 0x762dc000     C:\Windows\syswow64\msvcrt.dll
              0x75d80000 - 0x75e20000     C:\Windows\syswow64\ADVAPI32.dll
              0x76720000 - 0x76739000     C:\Windows\SysWOW64\sechost.dll
              0x765e0000 - 0x766d0000     C:\Windows\syswow64\RPCRT4.dll
              0x75850000 - 0x758b0000     C:\Windows\syswow64\SspiCli.dll
              0x75840000 - 0x7584c000     C:\Windows\syswow64\CRYPTBASE.dll
              0x73200000 - 0x7339e000     C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7600.16385_n one_421189da2b7fabfc\COMCTL32.dll
              0x75e30000 - 0x75e87000     C:\Windows\syswow64\SHLWAPI.dll
              0x760e0000 - 0x76140000     C:\Windows\system32\IMM32.DLL
              0x76160000 - 0x7622c000     C:\Windows\syswow64\MSCTF.dll
              0x72000000 - 0x72014000     D:\Program Files (x86)\Adobe\Adobe Flash Builder 4\plugins\org.eclipse.equinox.launcher.win32.win32.x86_1.0.200.v20090519\eclipse_1206.dll
              0x74100000 - 0x74109000     C:\Windows\system32\VERSION.dll
              0x6d800000 - 0x6da8b000     D:\Program Files (x86)\Adobe\Adobe Flash Builder 4\jre\bin\client\jvm.dll
              0x75650000 - 0x75682000     C:\Windows\system32\WINMM.dll
              0x7c340000 - 0x7c396000     C:\Windows\system32\MSVCR71.dll
              0x73ca0000 - 0x73ceb000     C:\Windows\system32\apphelp.dll
              0x6d7b0000 - 0x6d7bc000     D:\Program Files (x86)\Adobe\Adobe Flash Builder 4\jre\bin\verify.dll
              0x6d330000 - 0x6d34f000     D:\Program Files (x86)\Adobe\Adobe Flash Builder 4\jre\bin\java.dll
              0x6d290000 - 0x6d298000     D:\Program Files (x86)\Adobe\Adobe Flash Builder 4\jre\bin\hpi.dll
              0x76be0000 - 0x76be5000     C:\Windows\syswow64\PSAPI.DLL
              0x6d7f0000 - 0x6d7ff000     D:\Program Files (x86)\Adobe\Adobe Flash Builder 4\jre\bin\zip.dll
              0x74000000 - 0x74016000     C:\Windows\system32\CRYPTSP.dll
              0x73fc0000 - 0x73ffb000     C:\Windows\system32\rsaenh.dll
              0x73ed0000 - 0x73ee7000     C:\Windows\system32\USERENV.dll
              0x73ec0000 - 0x73ecb000     C:\Windows\system32\profapi.dll
              0x6d610000 - 0x6d623000     D:\Program Files (x86)\Adobe\Adobe Flash Builder 4\jre\bin\net.dll
              0x75b70000 - 0x75ba5000     C:\Windows\syswow64\WS2_32.dll
              0x75e20000 - 0x75e26000     C:\Windows\syswow64\NSI.dll
              0x73e70000 - 0x73eac000     C:\Windows\system32\mswsock.dll
              0x73e50000 - 0x73e56000     C:\Windows\System32\wship6.dll
              0x73d90000 - 0x73da0000     C:\Windows\system32\NLAapi.dll
              0x73da0000 - 0x73de4000     C:\Windows\system32\DNSAPI.dll
              0x73d80000 - 0x73d88000     C:\Windows\System32\winrnr.dll
              0x73d70000 - 0x73d80000     C:\Windows\system32\napinsp.dll
              0x73d50000 - 0x73d62000     C:\Windows\system32\pnrpnsp.dll
              0x003e0000 - 0x003f9000     C:\Program Files (x86)\Bonjour\mdnsNSP.dll
              0x74260000 - 0x7427c000     C:\Windows\system32\Iphlpapi.DLL
              0x74250000 - 0x74257000     C:\Windows\system32\WINNSI.DLL
              0x73d10000 - 0x73d48000     C:\Windows\System32\fwpuclnt.dll
              0x73d00000 - 0x73d06000     C:\Windows\system32\rasadhlp.dll
              0x6d630000 - 0x6d639000     D:\Program Files (x86)\Adobe\Adobe Flash Builder 4\jre\bin\nio.dll
              0x369b0000 - 0x36a09000     D:\Program Files (x86)\Adobe\Adobe Flash Builder 4\configuration\org.eclipse.osgi\bundles\297\1\.cp\swt-win32-3555.dll
              0x75f50000 - 0x760ac000     C:\Windows\syswow64\ole32.dll
              0x75ec0000 - 0x75f4f000     C:\Windows\syswow64\OLEAUT32.dll
              0x76b60000 - 0x76bdb000     C:\Windows\syswow64\comdlg32.dll
              0x76bf0000 - 0x77839000     C:\Windows\syswow64\SHELL32.dll
              0x76840000 - 0x76934000     C:\Windows\syswow64\WININET.dll
              0x76340000 - 0x76343000     C:\Windows\syswow64\Normaliz.dll
              0x75c40000 - 0x75d75000     C:\Windows\syswow64\urlmon.dll
              0x76a40000 - 0x76b5c000     C:\Windows\syswow64\CRYPT32.dll
              0x75b30000 - 0x75b3c000     C:\Windows\syswow64\MSASN1.dll
              0x76350000 - 0x76549000     C:\Windows\syswow64\iertutil.dll
              0x73530000 - 0x735b0000     C:\Windows\system32\uxtheme.dll
              0x35450000 - 0x35464000     D:\Program Files (x86)\Adobe\Adobe Flash Builder 4\configuration\org.eclipse.osgi\bundles\297\1\.cp\swt-gdip-win32-3555.dll
              0x72de0000 - 0x72f70000     C:\Windows\WinSxS\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7600.16385_none_72fc 7cbf861225ca\gdiplus.dll
              0x75220000 - 0x7531b000     C:\Windows\system32\WindowsCodecs.dll
              0x36730000 - 0x36771000     D:\Program Files (x86)\Adobe\Adobe Flash Builder 4\plugins\com.adobe.flexide.nativelibs_4.0.0.272416\os\win32\x86\BridgeTalk.dll
              0x36780000 - 0x367ea000     D:\Program Files (x86)\Adobe\Adobe Flash Builder 4\plugins\com.adobe.flexide.nativelibs_4.0.0.272416\libs\adobe_caps.dll
              0x758b0000 - 0x75a4d000     C:\Windows\syswow64\SETUPAPI.dll
              0x75e90000 - 0x75eb7000     C:\Windows\syswow64\CFGMGR32.dll
              0x76140000 - 0x76152000     C:\Windows\syswow64\DEVOBJ.dll
              0x76550000 - 0x765d3000     C:\Windows\syswow64\CLBCatQ.DLL
              0x75340000 - 0x75435000     C:\Windows\system32\propsys.dll
              0x73bb0000 - 0x73bd1000     C:\Windows\system32\ntmarta.dll
              0x766d0000 - 0x76715000     C:\Windows\syswow64\WLDAP32.dll
              0x37390000 - 0x373a7000     D:\Program Files (x86)\Adobe\Adobe Flash Builder 4\plugins\com.adobe.flexbuilder.utils.osnative_4.0.0.272416\os\win32\x86\JNIToNativeBridg e.dll
              0x37020000 - 0x3702a000     D:\Program Files (x86)\Adobe\Adobe Flash Builder 4\plugins\com.adobe.flexide.amt_4.0.0.272416\os\win32\x86\amt_win_jnilib.dll
              0x741c0000 - 0x7424e000     C:\Windows\WinSxS\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4926_none_508ed732bcb c0e5a\MSVCP90.dll
              0x74110000 - 0x741b3000     C:\Windows\WinSxS\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4926_none_508ed732bcb c0e5a\MSVCR90.dll
              0x68bb0000 - 0x68c96000     D:\Program Files (x86)\Adobe\Adobe Flash Builder 4\plugins\com.adobe.flexide.amt_4.0.0.272416\os\win32\x86\amtlib.dll
              0x68a90000 - 0x68ba4000     D:\Program Files (x86)\Adobe\Adobe Flash Builder 4\plugins\com.adobe.flexide.amt_4.0.0.272416\os\win32\x86\amtservices.dll
              0x73a60000 - 0x73ab8000     C:\Windows\system32\WINHTTP.dll
              0x73a10000 - 0x73a5f000     C:\Windows\system32\webio.dll
              0x6b4f0000 - 0x6b55a000     D:\Program Files (x86)\Adobe\Adobe Flash Builder 4\plugins\com.adobe.flexide.amt_4.0.0.272416\os\win32\x86\adobe_caps.dll
              0x37880000 - 0x378a8000     D:\Program Files (x86)\Adobe\Adobe Flash Builder 4\plugins\com.adobe.flexide.amt_4.0.0.272416\os\win32\x86\asneu.dll
              0x74fa0000 - 0x74faa000     C:\Windows\system32\wbem\wbemprox.dll
              0x749f0000 - 0x74a4c000     C:\Windows\system32\wbemcomn.dll
              0x73ac0000 - 0x73ace000     C:\Windows\system32\RpcRtRemote.dll
              0x749e0000 - 0x749ef000     C:\Windows\system32\wbem\wbemsvc.dll
              0x74940000 - 0x749d6000     C:\Windows\system32\wbem\fastprox.dll
              0x74920000 - 0x74938000     C:\Windows\system32\NTDSAPI.dll
              0x68cf0000 - 0x68d83000     D:\Program Files (x86)\Adobe\Adobe Flash Builder 4\plugins\com.adobe.flexide.amt_4.0.0.272416\os\win32\x86\updaternotifications.dll
              0x73f40000 - 0x73f51000     C:\Windows\system32\NETAPI32.dll
              0x73f30000 - 0x73f39000     C:\Windows\system32\netutils.dll
              0x73f10000 - 0x73f29000     C:\Windows\system32\srvcli.dll
              0x73f00000 - 0x73f0f000     C:\Windows\system32\wkscli.dll
              0x6b7c0000 - 0x6b83b000     C:\Windows\SysWOW64\taskschd.dll
              0x37460000 - 0x3746b000     D:\Program Files (x86)\Adobe\Adobe Flash Builder 4\plugins\com.adobe.flexide.nativelibs_4.0.0.272416\os\win32\x86\Headlights.dll
              0x378d0000 - 0x378d7000     C:\Windows\SysWOW64\ctagent.DLL
              0x73ad0000 - 0x73ad5000     C:\Windows\system32\msimg32.dll
              0x755e0000 - 0x7561c000     C:\Windows\system32\oleacc.dll
              0x39310000 - 0x39357000     C:\Program Files (x86)\Avira\AntiVir Desktop\avsda.dll
              0x73e60000 - 0x73e65000     C:\Windows\System32\wshtcpip.dll
              0x6f0e0000 - 0x6fb5e000     C:\Windows\SysWOW64\ieframe.dll
              0x75000000 - 0x7505f000     C:\Windows\system32\SXS.DLL
              0x684d0000 - 0x68a85000     C:\Windows\SysWOW64\mshtml.dll
              0x6bb60000 - 0x6bb8a000     C:\Windows\SysWOW64\msls31.dll
              0x74850000 - 0x7485b000     C:\Windows\system32\msimtf.dll
              0x68410000 - 0x684c2000     C:\Windows\SysWow64\jscript.dll
              0x67ea0000 - 0x68410000     C:\Windows\SysWow64\Macromed\Flash\FlDbg10e.ocx
              0x709d0000 - 0x70a49000     C:\Windows\system32\mscms.dll
              0x75440000 - 0x75479000     C:\Windows\system32\MMDevAPI.DLL
              0x744a0000 - 0x744d0000     C:\Windows\system32\wdmaud.drv
              0x74490000 - 0x74494000     C:\Windows\system32\ksuser.dll
              0x74480000 - 0x74487000     C:\Windows\system32\AVRT.dll
              0x746a0000 - 0x746d6000     C:\Windows\system32\AUDIOSES.DLL
              0x74470000 - 0x74478000     C:\Windows\system32\msacm32.drv
              0x73090000 - 0x730a4000     C:\Windows\system32\MSACM32.dll
              0x74460000 - 0x74467000     C:\Windows\system32\midimap.dll
              0x6e670000 - 0x6e69e000     C:\Windows\system32\mlang.dll
              VM Arguments:
              PATH=D:/Program Files (x86)/Adobe/Adobe Flash Builder 4/jre/bin/client;D:/Program Files (x86)/Adobe/Adobe Flash Builder 4/jre/bin;D:\Program Files (x86)\Adobe\Adobe Flash Builder 4\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPow erShell\v1.0\;D:\Program Files (x86)\tortoise\bin;C:\Program Files (x86)\Java\jre1.6.0_16\bin;
              USERNAME=cybarg
              OS=Windows_NT
              PROCESSOR_IDENTIFIER=AMD64 Family 15 Model 43 Stepping 1, AuthenticAMD
              OS: Windows 7 Build 7600
              CPU:total 2 (2 cores per cpu, 1 threads per core) family 15 model 43 stepping 1, cmov, cx8, fxsr, mmx, sse, sse2, sse3, mmxext, 3dnow, 3dnowext
              Memory: 4k page, physical 3145016k(1585268k free), swap 4194303k(4194303k free)
              time: Wed Jun 30 10:30:17 2010
              elapsed time: 23 seconds
              Kind regards,
              Carsten
              • 4. Re: Flash builder 4 crash on start
                C. Agruss (Adobe) Level 3
                Hi Carsten,
                Toward the top of your log, the problematic frame is called out:
                This seems to be pointing to the Debug Flash Player OCX (ActiveX) as the culprit.
                Perhaps try upgrading to the Debug Player 10.1 version here, and see if that helps:
                http://www.adobe.com/support/flashplayer/downloads.html
                -Chris
                • 5. Re: Flash builder 4 crash on start
                  Marge&Robert
                  I have just installed CS5 Master on mac. Flash catalyst and Flash builder bot fail to open. Error reports say to to look at the relevant log files, but those files are empty.
                  I am using snow leopard, which is up to date and there are adequate resources.
                  Finding an easy link to support, like a simple "help button" for sending someone an email is a nightmare. What do I do?
                  Can anyone help please?
                  Marjorie
                  • 6. Re: Flash builder 4 crash on start
                    Deeptika Gottipati Adobe Employee
                    Hi Marjorie,
                    We are sorry for the issue that you are facing. But we need a few more details that would enable us to triage the issue.
                    Can you please attach the following log files
                    1. amt3.log and oobelib.log from your tmp folder.
                         On Mac, you'll generally find the temp folder under /private/tmp/
                         On Win, you can find the temp folder this way:
                         - open a command window, and type "set" to view the environment variables
                         - navigate to the folder defined by the envvar named TMP
                    2. latest installation log. This can be found at
                    Mac - /Library/Logs/Adobe/Installers/
                    Win - \Program Files\Common Files\Adobe\Installers\
                    Also please let us know whether you are able to launch other CS products in Master Collection (products other than Flash Builder and Flash Catalyst).
                    Deeptika
                    • 7. Re: Flash builder 4 crash on start
                      Marge&Robert Level 1
                      Hello Deeptika,
                      I am Marjorie's husband Robert. She has asked me to help her in this.
                      Thank you for your response to her request for help as below.
                      All other applications open normally and she is very pleased with them. I like CS5 too and think I will upgrade now after seeing the new application.
                      The only problems seems to be opening Flash Catalyst and Flash Builder.
                      I uninstalled the application for her and reinstalled it but the problem remains.
                      I cannot find the files you requested.
                      The folder  .../Library/Logs/Adobe/Installers is empty.
                      Everything else seems to be working. The computer is always kept up to date with all upgrades etc and periodic maintenance performed with Mactuneup.
                      Thank you,
                      Robert
                      • 8. Re: Flash builder 4 crash on start
                        Hi Robert,
                        What is the error message shown when you launch Flash Catalyst or Flash Builder?
                        Also, are you able to see /private/tmp folder? That folder is hidden by default.
                        If that is the case, please do this to view hidden files/folders in Finder
                        Open the terminal and type this at command prompt -
                          defaults write com.apple.finder AppleShowAllFiles -bool true
                        Close all Finder instances and relaunch Finder. You should be able to see the hidden files in the Finder now.
                        Deeptika
                        • 9. Re: Flash builder 4 crash on start
                          Hi Deeptika,
                          I installed the apps on my imac with the same problem that I had on Marge's notebook. I uninstalled my own CS3 and installed Marge's CS5 there and will give her that computer when I have it up and running properly.
                          The error message reads-
                          An error has occurred. See the log files...../Library/Application Support/Adobe/Flash Catayst/Workspace/.Metadata/.Log
                          The information you requested in ...Library/Logs/Adobe/Installers has four log files. Each refer to CS3 (which we had before) and both are empty.
                          There is nothing else.
                          The folder ..../Private/tmp contains seventeen items.
                          file:///private/tmp/.font-unix/
                          file:///private/tmp/.ICE-unix/
                          file:///private/tmp/.wine-501/
                          file:///private/tmp/.X11-unix/
                          file:///private/tmp/000244c7acaf6
                          file:///private/tmp/501/
                          file:///private/tmp/amt3.log
                          file:///private/tmp/aprBG2BBK
                          file:///private/tmp/geColladaModelCacheLock
                          file:///private/tmp/geIconCacheLock
                          file:///private/tmp/icssuis501
                          file:///private/tmp/launch-bM9ZKZ/
                          file:///private/tmp/launch-fRn2A8/
                          file:///private/tmp/launch-iijbO7/
                          file:///private/tmp/launchd-156.wKvvu3/
                          file:///private/tmp/lilo.1609/
                          file:///private/tmp/swtag.log
                          The last file is large. Is this of interest. I can copy its contents and send that to you. I am not sure of those other files and did not want to get into them.
                          All other elements in the application such as Dreamweaver, Fireworks, Flash etc, without problems.
                          Other than that we are very impressed.
                          Thank you.
                          Robert
                          • 10. Re: Flash builder 4 crash on start
                            Hi Robert,
                            Please attach the following files
                            /Library/Application Support/Adobe/Flash Catayst/Workspace/.Metadata/.Log and
                            Deeptika
                            • 11. Re: Flash builder 4 crash on start
                              Hi Deeptika,
                              Thanks for your quick reply.
                              Here are the files you requested.
                              Robert.
                              The files taken from /Library/Application Support/Adobe/Flash Catayst/Workspace/.Metadata/.Log
                              !SESSION 2010-08-20 12:04:51.186 -----------------------------------------------
                              eclipse.buildId=unknown
                              java.version=1.6.0_20
                              java.vendor=Apple Inc.
                              BootLoader constants: OS=macosx, ARCH=x86, WS=carbon, NL=en_US
                              Framework arguments:  -keyring /Users/robertcarter/.eclipse_keyring -showlocation
                              Command-line arguments:  -os macosx -ws carbon -arch x86 -clean -keyring /Users/robertcarter/.eclipse_keyring -consoleLog -showlocation
                              !ENTRY org.eclipse.osgi 4 0 2010-08-20 12:04:59.867
                              !MESSAGE An error occurred while automatically activating bundle com.adobe.flexbuilder.project (17).
                              !STACK 0
                              org.osgi.framework.BundleException: Exception in com.adobe.flexbuilder.project.internal.FlexProjectCore.start() of bundle com.adobe.flexbuilder.project.
                                          at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextIm pl.java:1028)
                                          at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:9 84)
                                          at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:346)
                                          at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:265)
                                          at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:400)
                                          at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLa zyStarter.java:111)
                                          at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java :427)
                                          at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoade r.java:193)
                                          at org.eclipse.osgi.framework.internal.core.BundleLoader.findLocalClass(BundleLoader.java:36 8)
                                          at org.eclipse.osgi.framework.internal.core.SingleSourcePackage.loadClass(SingleSourcePackag e.java:33)
                                          at org.eclipse.osgi.framework.internal.core.BundleLoader.findClassInternal(BundleLoader.java :441)
                                          at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:397)
                                          at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:385)
                                          at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.jav a:87)
                                          at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
                                          at com.adobe.thermo.application.ThermoApplication.start(ThermoApplication.java:62)
                                          at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:193)
                                          at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:110)
                                          at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:79)
                                          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:382)
                                          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
                                          at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
                                          at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
                                          at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
                                          at java.lang.reflect.Method.invoke(Method.java:597)
                                          at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:549)
                                          at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
                                          at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
                              Caused by: java.lang.AbstractMethodError: org.apache.xerces.dom.DocumentImpl.getXmlStandalone()Z
                                          at com.sun.org.apache.xalan.internal.xsltc.trax.DOM2TO.setDocumentInfo(DOM2TO.java:373)
                                          at com.sun.org.apache.xalan.internal.xsltc.trax.DOM2TO.parse(DOM2TO.java:127)
                                          at com.sun.org.apache.xalan.internal.xsltc.trax.DOM2TO.parse(DOM2TO.java:94)
                                          at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transformIdentity(Transforme rImpl.java:661)
                                          at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transform(TransformerImpl.ja va:707)
                                          at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transform(TransformerImpl.ja va:313)
                                          at com.adobe.flexbuilder.util.XMLUtil.toByteArrayOutputStream(XMLUtil.java:232)
                                          at com.adobe.flexbuilder.util.XMLUtil.toString(XMLUtil.java:94)
                                          at com.adobe.flexbuilder.project.sdks.FlexSDKPreferences.saveToPrefStore(FlexSDKPreferences. java:318)
                                          at com.adobe.flexbuilder.project.sdks.FlexSDKPreferenceInitializer.initializeDefaultPreferen ces(FlexSDKPreferenceInitializer.java:44)
                                          at org.eclipse.core.internal.preferences.PreferenceServiceRegistryHelper.runInitializer(Pref erenceServiceRegistryHelper.java:276)
                                          at org.eclipse.core.internal.preferences.PreferenceServiceRegistryHelper.applyRuntimeDefault s(PreferenceServiceRegistryHelper.java:130)
                                          at org.eclipse.core.internal.preferences.PreferencesService.applyRuntimeDefaults(Preferences Service.java:367)
                                          at org.eclipse.core.internal.preferences.DefaultPreferences.applyRuntimeDefaults(DefaultPref erences.java:163)
                                          at org.eclipse.core.internal.preferences.DefaultPreferences.loadDefaults(DefaultPreferences. java:236)
                                          at org.eclipse.core.internal.preferences.DefaultPreferences.load(DefaultPreferences.java:232 )
                                          at org.eclipse.core.internal.preferences.EclipsePreferences.create(EclipsePreferences.java:3 07)
                                          at org.eclipse.core.internal.preferences.EclipsePreferences.internalNode(EclipsePreferences. java:543)
                                          at org.eclipse.core.internal.preferences.DefaultPreferences.node(DefaultPreferences.java:150 )
                                          at org.eclipse.core.internal.preferences.legacy.PreferenceForwarder.getDefaultPreferences(Pr eferenceForwarder.java:130)
                                          at org.eclipse.core.internal.preferences.legacy.PreferenceForwarder.getString(PreferenceForw arder.java:636)
                                          at com.adobe.flexbuilder.project.sdks.FlexSDKPreferences.loadFromPreferenceStore(FlexSDKPref erences.java:307)
                                          at com.adobe.flexbuilder.project.internal.FlexProjectCore.getFlexSDKPreferences(FlexProjectC ore.java:1127)
                                          at com.adobe.flexbuilder.project.actionscript.ActionScriptCore.start(ActionScriptCore.java:3 80)
                                          at com.adobe.flexbuilder.project.internal.FlexProjectCore.start(FlexProjectCore.java:320)
                                          at org.eclipse.osgi.framework.internal.core.BundleContextImpl$2.run(BundleContextImpl.java:1 009)
                                          at java.security.AccessController.doPrivileged(Native Method)
                                          at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextIm pl.java:1003)
                                          ... 27 more
                              Root exception:
                              !ENTRY org.eclipse.osgi 4 0 2010-08-20 12:04:59.904
                              !MESSAGE Application error
                              !STACK 1
                              java.lang.NoClassDefFoundError: com/adobe/flexbuilder/project/FlexBuilderInstallation
                              Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundExce ption: An error occurred while automatically activating bundle com.adobe.flexbuilder.project (17).
                                          at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLa zyStarter.java:125)
                                          ... 13 more
                              Caused by: org.osgi.framework.BundleException: Exception in com.adobe.flexbuilder.project.internal.FlexProjectCore.start() of bundle com.adobe.flexbuilder.project.
                                          ... 22 more
                                          ... 27 more
                              !ENTRY org.eclipse.osgi 2 0 2010-08-20 12:04:59.914
                              !MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
                              !SUBENTRY 1 org.eclipse.osgi 2 0 2010-08-20 12:04:59.914
                              !MESSAGE Bundle update@plugins/org.eclipse.help.ui.nl1_0.2.0.v20080914043401.jar was not resolved.
                              !SUBENTRY 2 org.eclipse.help.ui.nl1_0.2.0.v20080914043401 2 0 2010-08-20 12:04:59.914
                              !MESSAGE Missing host org.eclipse.help.ui_[0.0.0,9.0.0).
                              !MESSAGE Bundle update@plugins/org.eclipse.help.appserver.nl1_0.2.0.v20080914043401.jar was not resolved.
                              !SUBENTRY 2 org.eclipse.help.appserver.nl1_0.2.0.v20080914043401 2 0 2010-08-20 12:04:59.915
                              !MESSAGE Missing host org.eclipse.help.appserver_[0.0.0,9.0.0).
                              !SUBENTRY 1 org.eclipse.osgi 2 0 2010-08-20 12:04:59.915
                              !MESSAGE Bundle update@plugins/org.eclipse.help.webapp.nl1_0.2.0.v20080914043401.jar was not resolved.
                              !SUBENTRY 2 org.eclipse.help.webapp.nl1_0.2.0.v20080914043401 2 0 2010-08-20 12:04:59.915
                              !MESSAGE Missing host org.eclipse.help.webapp_[0.0.0,9.0.0).
                              !MESSAGE Bundle update@plugins/org.eclipse.team.cvs.ssh2.nl1_0.2.0.v20080914043401.jar was not resolved.
                              !SUBENTRY 2 org.eclipse.team.cvs.ssh2.nl1_0.2.0.v20080914043401 2 0 2010-08-20 12:04:59.916
                              !MESSAGE Missing host org.eclipse.team.cvs.ssh2_[0.0.0,9.0.0).
                              !SUBENTRY 1 org.eclipse.osgi 2 0 2010-08-20 12:04:59.916
                              !MESSAGE Bundle update@plugins/org.eclipse.team.cvs.ssh.nl1_0.2.0.v20080914043401.jar was not resolved.
                              !SUBENTRY 2 org.eclipse.team.cvs.ssh.nl1_0.2.0.v20080914043401 2 0 2010-08-20 12:04:59.916
                              !MESSAGE Missing host org.eclipse.team.cvs.ssh_[0.0.0,9.0.0).
                              !MESSAGE Bundle update@plugins/org.junit4.nl1_0.2.0.v20080914043401.jar was not resolved.
                              !SUBENTRY 2 org.junit4.nl1_0.2.0.v20080914043401 2 0 2010-08-20 12:04:59.916
                              !MESSAGE Missing host org.junit4_[0.0.0,9.0.0).
                              !SUBENTRY 1 org.eclipse.osgi 2 0 2010-08-20 12:04:59.917
                              !MESSAGE Bundle update@plugins/org.eclipse.team.cvs.ui.nl1_0.2.0.v20080914043401.jar was not resolved.
                              !SUBENTRY 2 org.eclipse.team.cvs.ui.nl1_0.2.0.v20080914043401 2 0 2010-08-20 12:04:59.917
                              !MESSAGE Missing host org.eclipse.team.cvs.ui_[0.0.0,9.0.0).
                              !MESSAGE Bundle update@plugins/org.eclipse.team.cvs.core.nl1_0.2.0.v20080914043401.jar was not resolved.
                              !SUBENTRY 2 org.eclipse.team.cvs.core.nl1_0.2.0.v20080914043401 2 0 2010-08-20 12:04:59.917
                              !MESSAGE Missing host org.eclipse.team.cvs.core_[0.0.0,9.0.0).
                              !SUBENTRY 1 org.eclipse.osgi 2 0 2010-08-20 12:04:59.918
                              !MESSAGE Bundle update@plugins/org.eclipse.ui.cheatsheets.nl1_0.2.0.v20080914043401.jar was not resolved.
                              !SUBENTRY 2 org.eclipse.ui.cheatsheets.nl1_0.2.0.v20080914043401 2 0 2010-08-20 12:04:59.918
                              !MESSAGE Missing host org.eclipse.ui.cheatsheets_[0.0.0,9.0.0).
                              !MESSAGE Bundle update@plugins/org.eclipse.ui.externaltools.nl1_0.2.0.v20080914043401.jar was not resolved.
                              !SUBENTRY 2 org.eclipse.ui.externaltools.nl1_0.2.0.v20080914043401 2 0 2010-08-20 12:04:59.918
                              !MESSAGE Missing host org.eclipse.ui.externaltools_[0.0.0,9.0.0).
                              !MESSAGE Bundle update@plugins/org.eclipse.update.scheduler.nl1_0.2.0.v20080914043401.jar was not resolved.
                              !SUBENTRY 2 org.eclipse.update.scheduler.nl1_0.2.0.v20080914043401 2 0 2010-08-20 12:04:59.919
                              !MESSAGE Missing host org.eclipse.update.scheduler_[0.0.0,9.0.0).
                              !ENTRY org.eclipse.osgi 2 0 2010-08-20 12:04:59.920
                              !MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
                              !SUBENTRY 1 org.eclipse.osgi 2 0 2010-08-20 12:04:59.920
                              !MESSAGE Bundle update@plugins/com.adobe.flexbuilder.utils.osnative.win_1.0.0.273393/ [19] was not resolved.
                              !SUBENTRY 2 com.adobe.flexbuilder.utils.osnative.win 2 0 2010-08-20 12:04:59.921
                              !MESSAGE Platform filter did not match: (& (osgi.ws=win32) (osgi.os=win32) (osgi.arch=x86))
                              !SUBENTRY 1 org.eclipse.osgi 2 0 2010-08-20 12:04:59.921
                              !MESSAGE Bundle update@plugins/org.eclipse.help.appserver.nl1_0.2.0.v20080914043401.jar [171] was not resolved.
                              !SUBENTRY 2 org.eclipse.help.appserver.nl1_0.2.0.v20080914043401 2 0 2010-08-20 12:04:59.921
                              !MESSAGE Bundle update@plugins/org.eclipse.help.ui.nl1_0.2.0.v20080914043401.jar [175] was not resolved.
                              !SUBENTRY 2 org.eclipse.help.ui.nl1_0.2.0.v20080914043401 2 0 2010-08-20 12:04:59.921
                              !SUBENTRY 1 org.eclipse.osgi 2 0 2010-08-20 12:04:59.922
                              !MESSAGE Bundle update@plugins/org.eclipse.help.webapp.nl1_0.2.0.v20080914043401.jar [176] was not resolved.
                              !SUBENTRY 2 org.eclipse.help.webapp.nl1_0.2.0.v20080914043401 2 0 2010-08-20 12:04:59.922
                              !MESSAGE Bundle update@plugins/org.eclipse.swt.carbon.macosx_3.4.0.v3448f.jar [205] was not resolved.
                              !SUBENTRY 2 org.eclipse.swt.carbon.macosx 2 0 2010-08-20 12:04:59.922
                              !MESSAGE Another singleton version selected: org.eclipse.swt.carbon.macosx_3.4.0.v3449
                              !SUBENTRY 1 org.eclipse.osgi 2 0 2010-08-20 12:04:59.923
                              !MESSAGE Bundle update@plugins/org.eclipse.swt_3.4.0.v3448f.jar [208] was not resolved.
                              !SUBENTRY 2 org.eclipse.swt 2 0 2010-08-20 12:04:59.923
                              !MESSAGE Missing imported package org.mozilla.xpcom_0.0.0.
                              !MESSAGE Bundle update@plugins/org.eclipse.team.cvs.core.nl1_0.2.0.v20080914043401.jar [212] was not resolved.
                              !SUBENTRY 2 org.eclipse.team.cvs.core.nl1_0.2.0.v20080914043401 2 0 2010-08-20 12:04:59.923
                              !SUBENTRY 1 org.eclipse.osgi 2 0 2010-08-20 12:04:59.924
                              !MESSAGE Bundle update@plugins/org.eclipse.team.cvs.ssh.nl1_0.2.0.v20080914043401.jar [213] was not resolved.
                              !SUBENTRY 2 org.eclipse.team.cvs.ssh.nl1_0.2.0.v20080914043401 2 0 2010-08-20 12:04:59.924
                              !MESSAGE Bundle update@plugins/org.eclipse.team.cvs.ssh2.nl1_0.2.0.v20080914043401.jar [214] was not resolved.
                              !SUBENTRY 2 org.eclipse.team.cvs.ssh2.nl1_0.2.0.v20080914043401 2 0 2010-08-20 12:04:59.925
                              !SUBENTRY 1 org.eclipse.osgi 2 0 2010-08-20 12:04:59.925
                              !MESSAGE Bundle update@plugins/org.eclipse.team.cvs.ui.nl1_0.2.0.v20080914043401.jar [215] was not resolved.
                              !SUBENTRY 2 org.eclipse.team.cvs.ui.nl1_0.2.0.v20080914043401 2 0 2010-08-20 12:04:59.925
                              !MESSAGE Bundle update@plugins/org.eclipse.ui.cheatsheets.nl1_0.2.0.v20080914043401.jar [224] was not resolved.
                              !SUBENTRY 2 org.eclipse.ui.cheatsheets.nl1_0.2.0.v20080914043401 2 0 2010-08-20 12:04:59.925
                              !SUBENTRY 1 org.eclipse.osgi 2 0 2010-08-20 12:04:59.926
                              !MESSAGE Bundle update@plugins/org.eclipse.ui.externaltools.nl1_0.2.0.v20080914043401.jar [229] was not resolved.
                              !SUBENTRY 2 org.eclipse.ui.externaltools.nl1_0.2.0.v20080914043401 2 0 2010-08-20 12:04:59.926
                              !MESSAGE Bundle update@plugins/org.eclipse.update.scheduler.nl1_0.2.0.v20080914043401.jar [263] was not resolved.
                              !SUBENTRY 2 org.eclipse.update.scheduler.nl1_0.2.0.v20080914043401 2 0 2010-08-20 12:04:59.926
                              !MESSAGE Bundle update@plugins/org.junit4.nl1_0.2.0.v20080914043401.jar [266] was not resolved.
                              !SUBENTRY 2 org.junit4.nl1_0.2.0.v20080914043401 2 0 2010-08-20 12:04:59.927
                              !SESSION 2010-08-30 12:14:32.657 -----------------------------------------------
                              !ENTRY org.eclipse.osgi 4 0 2010-08-30 12:14:41.058
                              !STACK 0
                                          ... 27 more
                              Root exception:
                              !ENTRY org.eclipse.osgi 4 0 2010-08-30 12:14:41.139
                              !STACK 1
                                          ... 13 more
                                          ... 22 more
                                          ... 27 more
                              !ENTRY org.eclipse.osgi 2 0 2010-08-30 12:14:41.149
                              !SUBENTRY 1 org.eclipse.osgi 2 0 2010-08-30 12:14:41.150
                              !SUBENTRY 2 org.junit4.nl1_0.2.0.v20080914043401 2 0 2010-08-30 12:14:41.150
                              !SUBENTRY 2 org.eclipse.help.ui.nl1_0.2.0.v20080914043401 2 0 2010-08-30 12:14:41.150
                              !SUBENTRY 2 org.eclipse.ui.cheatsheets.nl1_0.2.0.v20080914043401 2 0 2010-08-30 12:14:41.151
                              !SUBENTRY 1 org.eclipse.osgi 2 0 2010-08-30 12:14:41.151
                              !SUBENTRY 2 org.eclipse.team.cvs.core.nl1_0.2.0.v20080914043401 2 0 2010-08-30 12:14:41.151
                              !SUBENTRY 2 org.eclipse.update.scheduler.nl1_0.2.0.v20080914043401 2 0 2010-08-30 12:14:41.152
                              !SUBENTRY 1 org.eclipse.osgi 2 0 2010-08-30 12:14:41.152
                              !SUBENTRY 2 org.eclipse.ui.externaltools.nl1_0.2.0.v20080914043401 2 0 2010-08-30 12:14:41.152
                              !SUBENTRY 2 org.eclipse.team.cvs.ui.nl1_0.2.0.v20080914043401 2 0 2010-08-30 12:14:41.152
                              !SUBENTRY 1 org.eclipse.osgi 2 0 2010-08-30 12:14:41.153
                              !SUBENTRY 2 org.eclipse.team.cvs.ssh.nl1_0.2.0.v20080914043401 2 0 2010-08-30 12:14:41.153
                              !SUBENTRY 2 org.eclipse.help.appserver.nl1_0.2.0.v20080914043401 2 0 2010-08-30 12:14:41.153
                              !SUBENTRY 1 org.eclipse.osgi 2 0 2010-08-30 12:14:41.154
                              !SUBENTRY 2 org.eclipse.team.cvs.ssh2.nl1_0.2.0.v20080914043401 2 0 2010-08-30 12:14:41.154
                              !SUBENTRY 2 org.eclipse.help.webapp.nl1_0.2.0.v20080914043401 2 0 2010-08-30 12:14:41.154
                              !ENTRY org.eclipse.osgi 2 0 2010-08-30 12:14:41.156
                              !SUBENTRY 1 org.eclipse.osgi 2 0 2010-08-30 12:14:41.156
                              !SUBENTRY 2 com.adobe.flexbuilder.utils.osnative.win 2 0 2010-08-30 12:14:41.156
                              !SUBENTRY 2 org.eclipse.help.appserver.nl1_0.2.0.v20080914043401 2 0 2010-08-30 12:14:41.157
                              !SUBENTRY 1 org.eclipse.osgi 2 0 2010-08-30 12:14:41.157
                              !SUBENTRY 2 org.eclipse.help.ui.nl1_0.2.0.v20080914043401 2 0 2010-08-30 12:14:41.157
                              !SUBENTRY 2 org.eclipse.help.webapp.nl1_0.2.0.v20080914043401 2 0 2010-08-30 12:14:41.157
                              !SUBENTRY 1 org.eclipse.osgi 2 0 2010-08-30 12:14:41.158
                              !SUBENTRY 2 org.eclipse.swt.carbon.macosx 2 0 2010-08-30 12:14:41.158
                              !SUBENTRY 2 org.eclipse.swt 2 0 2010-08-30 12:14:41.158
                              !SUBENTRY 2 org.eclipse.team.cvs.core.nl1_0.2.0.v20080914043401 2 0 2010-08-30 12:14:41.159
                              !SUBENTRY 1 org.eclipse.osgi 2 0 2010-08-30 12:14:41.159
                              !SUBENTRY 2 org.eclipse.team.cvs.ssh.nl1_0.2.0.v20080914043401 2 0 2010-08-30 12:14:41.159
                              !SUBENTRY 2 org.eclipse.team.cvs.ssh2.nl1_0.2.0.v20080914043401 2 0 2010-08-30 12:14:41.159
                              !SUBENTRY 1 org.eclipse.osgi 2 0 2010-08-30 12:14:41.160
                              !SUBENTRY 2 org.eclipse.team.cvs.ui.nl1_0.2.0.v20080914043401 2 0 2010-08-30 12:14:41.160
                              !SUBENTRY 2 org.eclipse.ui.cheatsheets.nl1_0.2.0.v20080914043401 2 0 2010-08-30 12:14:41.160
                              !SUBENTRY 2 org.eclipse.ui.externaltools.nl1_0.2.0.v20080914043401 2 0 2010-08-30 12:14:41.161
                              !SUBENTRY 1 org.eclipse.osgi 2 0 2010-08-30 12:14:41.161
                              !SUBENTRY 2 org.eclipse.update.scheduler.nl1_0.2.0.v20080914043401 2 0 2010-08-30 12:14:41.161
                              !SUBENTRY 2 org.junit4.nl1_0.2.0.v20080914043401 2 0 2010-08-30 12:14:41.161
                              The files taken from /private/tmp/amt3.log
                              2010-08-30 11:19:10 [1609]  AMT: START SESSION, library version 3.0.0.64,3.0
                              2010-08-30 11:19:10 [1609]  AMT: Initializing /Applications/Adobe Illustrator CS5/Adobe Illustrator.app/
                              2010-08-30 11:19:10 [1609]  AMT: Adobe License Manager version 3.2 (build 64.0) RELEASE
                              2010-08-30 11:19:10 [1609]  ServiceLoader: looking for library /Applications/Adobe Illustrator CS5/Adobe Illustrator.app/Contents/Frameworks/amtservices.framework/Versions/A/adobe_caps.framework /adobe_caps
                              2010-08-30 11:19:10 [1609]  ServiceLoader: looking for library /Applications/Adobe Illustrator CS5/Adobe Illustrator.app/Contents/Frameworks/amtservices.framework/Versions/adobe_caps.framework/a dobe_caps
                              2010-08-30 11:19:10 [1609]  ServiceLoader: looking for library /Applications/Adobe Illustrator CS5/Adobe Illustrator.app/Contents/Frameworks/adobe_caps.framework/adobe_caps
                              2010-08-30 11:19:10 [1609]  ServiceLoader: Found library /Applications/Adobe Illustrator CS5/Adobe Illustrator.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
                              2010-08-30 11:19:10 [1609]  PCDService: PCD Service in threaded mode
                              2010-08-30 11:19:10 [1609]  PCD thread: PCD thread started
                              2010-08-30 11:19:10 [1609]  performance: AMTPreObtainProductLicense took 107.079002 ms
                              2010-08-30 11:19:10 [1609]  ServiceLoader: looking for library /Applications/Adobe Illustrator CS5/Adobe Illustrator.app/Contents/Frameworks/amtservices.framework/Versions/A/Adobe_OOBE_Launcher. framework/Adobe_OOBE_Launcher
                              2010-08-30 11:19:10 [1609]  ServiceLoader: looking for library /Applications/Adobe Illustrator CS5/Adobe Illustrator.app/Contents/Frameworks/amtservices.framework/Versions/Adobe_OOBE_Launcher.fr amework/Adobe_OOBE_Launcher
                              2010-08-30 11:19:10 [1609]  ServiceLoader: looking for library /Applications/Adobe Illustrator CS5/Adobe Illustrator.app/Contents/Frameworks/Adobe_OOBE_Launcher.framework/Adobe_OOBE_Launcher
                              2010-08-30 11:19:10 [1609]  ServiceLoader: Found library /Applications/Adobe Illustrator CS5/Adobe Illustrator.app/Contents/Frameworks/adobe_oobe_launcher.framework/Versions/A/adobe_oobe_l auncher
                              2010-08-30 11:19:10 [1609]  AMT: App Product Locale [0] = en_GB
                              2010-08-30 11:19:10 [1609]  config: Loading configuration for /Applications/Adobe Illustrator CS5/Adobe Illustrator.app/Contents/Resources/AMT/application.xml
                              2010-08-30 11:19:10 [1609]  config: Found payload code {6A75E573-6909-4D48-BDFA-D8ED118605A5}
                              2010-08-30 11:19:10 [1609]  PCDService: found driver code {D348C659-234A-497E-9E75-92D1AB019C8C}
                              2010-08-30 11:19:10 [1609]  config: config: Host app was installed, using installed license configuration.
                              2010-08-30 11:19:10 [1609]  PCDService: No value for key [FLMap] in hive [Illustrator-CS5-Mac-GM{|}ALL] in cache.
                              2010-08-30 11:19:10 [1609]  config: Setting current license to the driver at startup because no mapping was found.
                              2010-08-30 11:19:10 [1609]  config: Setting current license to MasterCollection-CS5-Mac-GM [ALL]
                              2010-08-30 11:19:10 [1609]  config: payload code: {6A75E573-6909-4D48-BDFA-D8ED118605A5}
                              2010-08-30 11:19:10 [1609]  config: driver payload code: {D348C659-234A-497E-9E75-92D1AB019C8C}
                              2010-08-30 11:19:10 [1609]  config: driver licensing code: MasterCollection-CS5-Mac-GM
                              2010-08-30 11:19:10 [1609]  config: current licensing code: MasterCollection-CS5-Mac-GM
                              2010-08-30 11:19:10 [1609]  config: current locale code: ALL
                              2010-08-30 11:19:10 [1609]  config: Done loading configuration
                              2010-08-30 11:19:10 [1609]  AMT: Locale from PCD [0] = en_GB
                              2010-08-30 11:19:10 [1609]  AMT: Reordered Installed App Product Locale [0] = en_GB
                              2010-08-30 11:19:10 [1609]  config: Setting insalled locales
                              2010-08-30 11:19:10 [1609]  config: Changing locale to "en_GB" because old locale "" is not in the new list of installed languages
                              2010-08-30 11:19:10 [1609]  ServiceLoader: looking for library /Applications/Adobe Illustrator CS5/Adobe Illustrator.app/Contents/Frameworks/amtservices.framework/Versions/A/asneu.framework/asne u
                              2010-08-30 11:19:10 [1609]  ServiceLoader: looking for library /Applications/Adobe Illustrator CS5/Adobe Illustrator.app/Contents/Frameworks/amtservices.framework/Versions/asneu.framework/asneu
                              2010-08-30 11:19:10 [1609]  ServiceLoader: looking for library /Applications/Adobe Illustrator CS5/Adobe Illustrator.app/Contents/Frameworks/asneu.framework/asneu
                              2010-08-30 11:19:10 [1609]  ServiceLoader: Found library /Applications/Adobe Illustrator CS5/Adobe Illustrator.app/Contents/Frameworks/asneu.framework/Versions/A/asneu
                              2010-08-30 11:19:10 [1609]  PCDService: No value for key [ReLaunchMode] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 11:19:10 [1609]  PCDService: No value for key [ReLaunchMode] in hive [{6A75E573-6909-4D48-BDFA-D8ED118605A5}] in master.
                              2010-08-30 11:19:10 [1609]  AMT: App's last known config file is: /Applications/Adobe Illustrator CS5/Adobe Illustrator.app/Contents/Resources/AMT/application.xml
                              2010-08-30 11:19:10 [1609]  apf: current config file path is: /Applications/Adobe Illustrator CS5/Adobe Illustrator.app/Contents/Resources/AMT/application.xml
                              2010-08-30 11:19:10 [1609]  AMT: config: Finding license info for payload: {D348C659-234A-497E-9E75-92D1AB019C8C}
                              2010-08-30 11:19:10 [1609]  AMT: config: PayloadCode: {6A75E573-6909-4D48-BDFA-D8ED118605A5}
                              2010-08-30 11:19:10 [1609]  AMT: config: Driver PayloadCode: {D348C659-234A-497E-9E75-92D1AB019C8C}
                              2010-08-30 11:19:10 [1609]  AMT: config: Installed LicensingCode: MasterCollection-CS5-Mac-GM
                              2010-08-30 11:19:10 [1609]  PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{6A75E573-6909-4D48-BDFA-D8ED118605A5}] in master.
                              2010-08-30 11:19:10 [1609]  PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 11:19:10 [1609]  PCDService: No value for key [BridgeTalkCode] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 11:19:10 [1609]  PCDService: No value for key [ISO_TAGGING_DISABLED] in hive [Illustrator-CS5-Mac-GM] in master.
                              2010-08-30 11:19:10 [1609]  PCDService: No value for key [EULA] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 11:19:10 [1609]  PCDService: No value for key [Registration] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 11:19:10 [1609]  PCDService: No value for key [Registration] in hive [{6A75E573-6909-4D48-BDFA-D8ED118605A5}] in master.
                              2010-08-30 11:19:10 [1609]  PCDService: No value for key [Updates] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 11:19:10 [1609]  PCDService: No value for key [Updates] in hive [{6A75E573-6909-4D48-BDFA-D8ED118605A5}] in master.
                              2010-08-30 11:19:10 [1609]  AMT: Application can be serialized (sif file found).
                              2010-08-30 11:19:10 [1609]  config: Setting current license to MasterCollection-CS5-Mac-GM [en_GB]
                              2010-08-30 11:19:10 [1609]  PCDService: No value for key [AMTConfigPath] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in cache.
                              2010-08-30 11:19:10 [1609]  PCDService: No value for key [ExpirationDate] in hive [Illustrator-CS5-Mac-GM] in master.
                              2010-08-30 11:19:10 [1609]  AMT: Subsequent launch (serial [92299707061434977111]).
                              2010-08-30 11:19:10 [1609]  AMT: Application state initialized.  Obtaining Product License.
                              2010-08-30 11:19:10 [1609]  AMT: Obtaining client features from cache.
                              2010-08-30 11:19:10 [1609]  AMT: Obtaining client product info from cache.
                              2010-08-30 11:19:10 [1609]  AMT: Running in PROV_APP
                              2010-08-30 11:19:10 [1609]  PCDService: No value for key [EULADelay] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 11:19:10 [1609]  PCDService: No value for key [MediaTag] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 11:19:10 [1609]  config: No media tag found for payload {D348C659-234A-497E-9E75-92D1AB019C8C}
                              2010-08-30 11:19:10 [1609]  config: Using default media policy RET
                              2010-08-30 11:19:10 [1609]  uiswitch: EULA has already been accepted.
                              2010-08-30 11:19:10 [1609]  AMT: This is a subsequent launch. Deferring services.
                              2010-08-30 11:19:10 [1609]  performance: AMTObtainProductLicense took 587.523010 ms
                              2010-08-30 11:19:27 [1609]  AMT: Pre-Validating Product License.
                              2010-08-30 11:19:27 [1609]  AMT: Services not yet loaded in this session.
                              2010-08-30 11:19:27 [1609]  AMT: Loading services in background to get ready for Validate call.
                              2010-08-30 11:19:27 [1609]  AMT: Spawning background thread to load services.
                              2010-08-30 11:19:27 [1609]  performance: AMTPreValidateProductLicense took 0.021000 ms
                              2010-08-30 11:19:27 [1609]  AMT: Starting work on prevalidate thread.
                              2010-08-30 11:19:27 [1609]  AMT: AMT: PreValidating Product License.
                              2010-08-30 11:19:27 [1609]  AMT: Launch Workflow not yet done in this session.
                              2010-08-30 11:19:27 [1609]  AMT: Starting Background Subsequent Launch Workflow
                              2010-08-30 11:19:27 [1609]  AMT: Starting ALM workflow.
                              2010-08-30 11:19:27 [1609]  AMT: Initializing ALM for serialized activation.
                              2010-08-30 11:19:27 [1609]  ALMService: Initializing as licensed app
                              2010-08-30 11:19:27 [1609]  ALM: _info_: Start ALM 3.2 Release (build 3.2.64.0)
                              2010-08-30 11:19:27 [1609]  SLCoreService: Starting up SLCore 1.0 Release (build 1.0.13.199023).
                              2010-08-30 11:19:27 [1609]  SLCoreService: Service construction took 0.1 ms and succeed.
                              2010-08-30 11:19:27 [1609]  ALM: _info_: LEID passed MasterCollection-CS5-Mac-GM is used to configure SLCore = 0
                              2010-08-30 11:19:27 [1609]  ALM: _info_: Host app is Licensable App
                              2010-08-30 11:19:27 [1609]  PCDService: No value for key [Illustrator-CS5-Mac-GM{|}5] in hive [SSC-CS5-LE-Dominance] in master.
                              2010-08-30 11:19:27 [1609]  ALM: _info_: Found LEID Illustrator-CS5-Mac-GM with AMT Path /Applications/Adobe Illustrator CS5/Adobe Illustrator.app/Contents/Resources/AMT
                              2010-08-30 11:19:27 [1609]  ALM: _info_: Found LEID DesignSuiteStandard-CS5-Mac-GM with AMT Path /Library/Application Support/Adobe/ssc/DesignSuiteStandard-CS5-Mac-GM
                              2010-08-30 11:19:27 [1609]  ALM: _info_: Found LEID WebSuitePremium-CS5-Mac-GM with AMT Path /Library/Application Support/Adobe/ssc/WebSuitePremium-CS5-Mac-GM
                              2010-08-30 11:19:27 [1609]  ALM: _info_: Found LEID DesignSuitePremium-CS5-Mac-GM with AMT Path /Library/Application Support/Adobe/ssc/DesignSuitePremium-CS5-Mac-GM
                              2010-08-30 11:19:27 [1609]  ALM: _info_: Found LEID VideoSuitePremium-CS5-Mac-GM with AMT Path /Library/Application Support/Adobe/ssc/VideoSuitePremium-CS5-Mac-GM
                              2010-08-30 11:19:27 [1609]  ALM: _info_: Found LEID MasterCollection-CS5-Mac-GM with AMT Path /Library/Application Support/Adobe/Adobe Creative Suite 5 Master Collection/AMT
                              2010-08-30 11:19:27 [1609]  PCDService: No value for key [MediaTag] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 11:19:27 [1609]  config: No media tag found for payload {D348C659-234A-497E-9E75-92D1AB019C8C}
                              2010-08-30 11:19:27 [1609]  config: Using default media policy RET
                              2010-08-30 11:19:27 [1609]  ALM: _info_: MediaTagPolicy is RET
                              2010-08-30 11:19:27 [1609]  PCDService: No value for key [NTL_WO_SN] in hive [MasterCollection-CS5-Mac-GM] in master.
                              2010-08-30 11:19:27 [1609]  ALM: _info_: Canonical LEID is Illustrator-CS5-Mac-GM
                              2010-08-30 11:19:27 [1609]  ALM: _info_: Driver LEID is MasterCollection-CS5-Mac-GM
                              2010-08-30 11:19:27 [1609]  PCDService: No value for key [922997097461591857680129] in hive [RejectedSNDomain_CS5] in cache.
                              2010-08-30 11:19:27 [1609]  SLCoreService: Reading product config [/Library/Application Support/Adobe/Adobe Creative Suite 5 Master Collection/AMT/SLConfig.xml]
                              2010-08-30 11:19:28 [1609]  ALM: _info_: alm::IsLangPackForLocaleInstalled - Checking if lang pack is installed for ALL
                              2010-08-30 11:19:28 [1609]  ALM: _info_: alm::IsLangPackForLocaleInstalled - Lang pack is not installed
                              2010-08-30 11:19:28 [1609]  ALM: _info_: Set Running Locale to en_GB
                              2010-08-30 11:19:28 [1609]  ALM: _time_: (func: ALM_Initialize, duration: 0.233 sec)
                              2010-08-30 11:19:28 [1609]  AMT: Performing ALM silent license verification.
                              2010-08-30 11:19:28 [1609]  PCDService: No value for key [EncryptedSerial] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in cache.
                              2010-08-30 11:19:28 [1609]  PCDService: No value for key [Serial] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in cache.
                              2010-08-30 11:19:28 [1609]  config: No pre-serial number found in {D348C659-234A-497E-9E75-92D1AB019C8C}
                              2010-08-30 11:19:28 [1609]  PCDService: No value for key [PSN] in hive [MasterCollection-CS5-Mac-GM{|}en_GB] in cache.
                              2010-08-30 11:19:28 [1609]  config: No en_GB provisional serial number found in MasterCollection-CS5-Mac-GM
                              2010-08-30 11:19:28 [1609]  PCDService: No value for key [PSN] in hive [MasterCollection-CS5-Mac-GM{|}ALL] in cache.
                              2010-08-30 11:19:28 [1609]  config: No ALL provisional serial number found in MasterCollection-CS5-Mac-GM
                              2010-08-30 11:19:28 [1609]  ALM: _info_: Validate license at Post-Chrome time, running locale is en_GB
                              2010-08-30 11:19:28 [1609]  ALM: _info_: Searching license for locale en_GB ...
                              2010-08-30 11:19:28 [1609]  PCDService: No value for key [922997070614349771111224] in hive [RejectedSNDomain_CS5] in cache.
                              2010-08-30 11:19:28 [1609]  ALM: _info_: alm::IsLangPackForLocaleInstalled - Checking if lang pack is installed for en_GB
                              2010-08-30 11:19:28 [1609]  ALM: _info_: alm::IsLangPackForLocaleInstalled - Lang pack is installed
                              2010-08-30 11:19:28 [1609]  ALM: _info_: Found existing serialization under LEID MasterCollection-CS5-Mac-GM, the serial number locale is en_GB
                              2010-08-30 11:19:28 [1609]  ALM: _info_: This is the running locale, stop the search
                              2010-08-30 11:19:28 [1609]  config: Setting current license to MasterCollection-CS5-Mac-GM [en_GB]
                              2010-08-30 11:19:28 [1609]  SLCoreService: Syncing to license store...
                              2010-08-30 11:19:28 [1609]  SLCoreService: Found server mkey.
                              2010-08-30 11:19:28 [1609]  SLCoreService: Found 1 license file(s)
                              2010-08-30 11:19:28 [1609]  SLCoreService: Parsing license file [49986045.lic] succeed.
                              2010-08-30 11:19:28 [1609]  SLCoreService: License store synchronization took 232.4 ms and succeed.
                              2010-08-30 11:19:28 [1609]  SLCoreService: Query license: type = 3, duration = permanent, remaining = permanent.
                              2010-08-30 11:19:28 [1609]  PCDService: No value for key [PDApp_WF] in hive [MasterCollection-CS5-Mac-GM] in cache.
                              2010-08-30 11:19:28 [1609]  SLCoreService: Feature ALM_CS5MasterCollectionGM_5.0 is enabled.
                              2010-08-30 11:19:28 [1609]  SLCoreService: Feature AfterEffects_10.0 is enabled.
                              2010-08-30 11:19:28 [1609]  SLCoreService: Feature AfterEffects_Base_10.0 is enabled.
                              2010-08-30 11:19:28 [1609]  SLCoreService: Feature Bridge_Base_4.0 is enabled.
                              2010-08-30 11:19:28 [1609]  SLCoreService: Feature Bridge_CameraRaw_4.0 is enabled.
                              2010-08-30 11:19:28 [1609]  SLCoreService: Feature Bridge_ColorSettings_4.0 is enabled.
                              2010-08-30 11:19:28 [1609]  SLCoreService: Feature Bridge_MiniBridge_1.0 is enabled.
                              2010-08-30 11:19:28 [1609]  SLCoreService: Feature Contribute_6.0 is enabled.
                              2010-08-30 11:19:28 [1609]  SLCoreService: Feature Contribute_Base_6.0 is enabled.
                              2010-08-30 11:19:28 [1609]  SLCoreService: Feature CreativeSuite_5.0 is enabled.
                              2010-08-30 11:19:28 [1609]  SLCoreService: Feature CreativeSuite_DVADynamicLink_4.0 is enabled.
                              2010-08-30 11:19:28 [1609]  SLCoreService: Feature CreativeSuite_MasterCollection_5.0 is enabled.
                              2010-08-30 11:19:28 [1609]  SLCoreService: Feature Dreamweaver_11.0 is enabled.
                              2010-08-30 11:19:28 [1609]  SLCoreService: Feature Dreamweaver_Base_11.0 is enabled.
                              2010-08-30 11:19:28 [1609]  SLCoreService: Feature Encore_Base_5.0 is enabled.
                              2010-08-30 11:19:28 [1609]  SLCoreService: Feature Fireworks_11.0 is enabled.
                              2010-08-30 11:19:28 [1609]  SLCoreService: Feature Fireworks_Base_11.0 is enabled.
                              2010-08-30 11:19:28 [1609]  SLCoreService: Feature FlashBuilder_4.0 is enabled.
                              2010-08-30 11:19:28 [1609]  SLCoreService: Feature FlashBuilder_Base_4.0 is enabled.
                              2010-08-30 11:19:28 [1609]  SLCoreService: Feature FlashCatalyst_1.0 is enabled.
                              2010-08-30 11:19:28 [1609]  SLCoreService: Feature FlashCatalyst_Base_1.0 is enabled.
                              2010-08-30 11:19:28 [1609]  SLCoreService: Feature Flash_11.0 is enabled.
                              2010-08-30 11:19:28 [1609]  SLCoreService: Feature Flash_Base_11.0 is enabled.
                              2010-08-30 11:19:28 [1609]  SLCoreService: Feature Flash_Pro_11.0 is enabled.
                              2010-08-30 11:19:28 [1609]  SLCoreService: Feature Illustrator_15.0 is enabled.
                              2010-08-30 11:19:28 [1609]  SLCoreService: Feature Illustrator_Base_15.0 is enabled.
                              2010-08-30 11:19:28 [1609]  SLCoreService: Feature InDesign_7.0 is enabled.
                              2010-08-30 11:19:28 [1609]  SLCoreService: Feature InDesign_Base_7.0 is enabled.
                              2010-08-30 11:19:28 [1609]  SLCoreService: Feature MediaEncoder_Addtnl_Exporter_2.0 is enabled.
                              2010-08-30 11:19:28 [1609]  SLCoreService: Feature MediaEncoder_Base_2.0 is enabled.
                              2010-08-30 11:19:28 [1609]  SLCoreService: Feature MobileCenter_Base_3.0 is enabled.
                              2010-08-30 11:19:28 [1609]  SLCoreService: Feature OnLocation_Base_5.0 is enabled.
                              2010-08-30 11:19:28 [1609]  SLCoreService: Feature Photoshop_12.0 is enabled.
                              2010-08-30 11:19:28 [1609]  SLCoreService: Feature Photoshop_Base_12.0 is enabled.
                              2010-08-30 11:19:28 [1609]  SLCoreService: Feature Photoshop_Premium_12.0 is enabled.
                              2010-08-30 11:19:28 [1609]  SLCoreService: Feature Premiere_5.0 is enabled.
                              2010-08-30 11:19:28 [1609]  SLCoreService: Feature Premiere_Base_5.0 is enabled.
                              2010-08-30 11:19:28 [1609]  SLCoreService: Feature Soundbooth_3.0 is enabled.
                              2010-08-30 11:19:28 [1609]  SLCoreService: Feature Soundbooth_Base_3.0 is enabled.
                              2010-08-30 11:19:28 [1609]  PCDService: No value for key [ALM_Info_S1] in hive [MasterCollection-CS5-Mac-GM{|}en_GB] in cache.
                              2010-08-30 11:19:28 [1609]  ALM: _info_: Performing Block Check
                              2010-08-30 11:19:28 [1609]  ALM: _info_: Block Check ByPassed
                              2010-08-30 11:19:28 [1609]  ALM: _time_: (func: ALM_License_SilentValidate, duration: 0.250 sec)
                              2010-08-30 11:19:28 [1609]  ALM: _info_: ALM_License_SilentValidate return license status: Valid And Activated
                              2010-08-30 11:19:28 [1609]  AMT: License check shows serialized product is already activated.
                              2010-08-30 11:19:28 [1609]  ALM: _info_: Entered ALM_NeedANAG
                              2010-08-30 11:19:28 [1609]  PCDService: No value for key [ADOBEID_EXT_PROFILE] in hive [922997070614349771111224] in cache.
                              2010-08-30 11:19:28 [1609]  ALM: _info_: Exiting ALM_NeedANAG
                              2010-08-30 11:19:28 [1609]  PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 11:19:28 [1609]  PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{6A75E573-6909-4D48-BDFA-D8ED118605A5}] in master.
                              2010-08-30 11:19:28 [1609]  PCDService: No value for key [Updates] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 11:19:28 [1609]  PCDService: No value for key [Updates] in hive [{6A75E573-6909-4D48-BDFA-D8ED118605A5}] in master.
                              2010-08-30 11:19:28 [1609]  AUMService: config: No AdobeUpdaterCode found in configuration; AUM will be disabled.
                              2010-08-30 11:19:28 [1609]  ServiceLoader: looking for library /Applications/Adobe Illustrator CS5/Adobe Illustrator.app/Contents/Frameworks/amtservices.framework/Versions/A/UpdaterNotifications .framework/UpdaterNotifications
                              2010-08-30 11:19:28 [1609]  ServiceLoader: looking for library /Applications/Adobe Illustrator CS5/Adobe Illustrator.app/Contents/Frameworks/amtservices.framework/Versions/UpdaterNotifications.f ramework/UpdaterNotifications
                              2010-08-30 11:19:28 [1609]  ServiceLoader: looking for library /Applications/Adobe Illustrator CS5/Adobe Illustrator.app/Contents/Frameworks/UpdaterNotifications.framework/UpdaterNotifications
                              2010-08-30 11:19:28 [1609]  ServiceLoader: Found library /Applications/Adobe Illustrator CS5/Adobe Illustrator.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNoti fications
                              2010-08-30 11:19:28 [1609]  AUMService: IsUpdaterEnabled call
                              2010-08-30 11:19:28 [1609]  AUMService: IsUpdaterEnabled call succeeded
                              2010-08-30 11:19:28 [1609]  ALM: _info_: Deactivation menu is enabled
                              2010-08-30 11:19:28 [1609]  AMT: Completed Launch Workflow successfully.
                              2010-08-30 11:19:28 [1609]  AMT: Calling AUM API to create scheduler entry to be used by updater.
                              2010-08-30 11:19:28 [1609]  AUMService: Get LEID xml call
                              2010-08-30 11:19:28 [1609]  AUMService: Get LEID XML call succeeded
                              2010-08-30 11:19:28 [1609]  AMT: AUM GetLEID called with status =0.
                              2010-08-30 11:19:28 [1609]  AMT: Caching Suite Features.
                              2010-08-30 11:19:28 [1609]  AMT: Suite Feature AfterEffects_Base 10.0 is licensed.
                              2010-08-30 11:19:28 [1609]  AMT: Suite Feature Bridge_Base 4.0 is licensed.
                              2010-08-30 11:19:28 [1609]  AMT: Suite Feature Bridge_CameraRaw 4.0 is licensed.
                              2010-08-30 11:19:28 [1609]  AMT: Suite Feature Bridge_ColorSettings 4.0 is licensed.
                              2010-08-30 11:19:28 [1609]  AMT: Suite Feature Bridge_MiniBridge 1.0 is licensed.
                              2010-08-30 11:19:28 [1609]  AMT: Suite Feature Contribute_Base 6.0 is licensed.
                              2010-08-30 11:19:28 [1609]  AMT: Suite Feature Dreamweaver_Base 11.0 is licensed.
                              2010-08-30 11:19:28 [1609]  AMT: Suite Feature DynamicLink_Base 4.0 is unlicensed.
                              2010-08-30 11:19:28 [1609]  AMT: Suite Feature Encore_Base 5.0 is licensed.
                              2010-08-30 11:19:28 [1609]  AMT: Suite Feature Fireworks_Base 11.0 is licensed.
                              2010-08-30 11:19:28 [1609]  AMT: Suite Feature Flash_Base 11.0 is licensed.
                              2010-08-30 11:19:28 [1609]  AMT: Suite Feature Flash_Pro 11.0 is licensed.
                              2010-08-30 11:19:28 [1609]  AMT: Suite Feature FlashBuilder_Base 4.1 is unlicensed.
                              2010-08-30 11:19:28 [1609]  AMT: Suite Feature FlashCatalyst_Base 1.0 is licensed.
                              2010-08-30 11:19:28 [1609]  AMT: Suite Feature Illustrator_Base 15.0 is licensed.
                              2010-08-30 11:19:28 [1609]  AMT: Suite Feature InDesign_Base 7.0 is licensed.
                              2010-08-30 11:19:28 [1609]  AMT: Suite Feature MediaEncoder_Base 2.0 is licensed.
                              2010-08-30 11:19:28 [1609]  AMT: Suite Feature MobileCenter_Base 3.0 is licensed.
                              2010-08-30 11:19:28 [1609]  AMT: Suite Feature OnLocation_Base 5.0 is licensed.
                              2010-08-30 11:19:28 [1609]  AMT: Suite Feature Photoshop_Base 12.0 is licensed.
                              2010-08-30 11:19:28 [1609]  AMT: Suite Feature Photoshop_Premium 12.0 is licensed.
                              2010-08-30 11:19:28 [1609]  AMT: Suite Feature Premiere_Base 5.0 is licensed.
                              2010-08-30 11:19:28 [1609]  AMT: Suite Feature Soundbooth_Base 3.0 is licensed.
                              2010-08-30 11:19:28 [1609]  AMT: Checking client features against cache.
                              2010-08-30 11:19:28 [1609]  AMT: Feature Illustrator_Base 15.0 is licensed (was licensed).
                              2010-08-30 11:19:28 [1609]  AMT: Feature Bridge_Base 4.0 is licensed (was licensed).
                              2010-08-30 11:19:28 [1609]  AMT: Feature MobileCenter_Base 3.0 is licensed (was licensed).
                              2010-08-30 11:19:28 [1609]  AMT: Validating client product info against cache.
                              2010-08-30 11:19:28 [1609]  PCDService: No value for key [ExpirationDate] in hive [Illustrator-CS5-Mac-GM] in master.
                              2010-08-30 11:19:28 [1609]  AMT: Starting Data Collection for SWTag_Init()
                              2010-08-30 11:19:28 [1609]  AMT: DoISOTagging() productCanonicalLEID = Illustrator-CS5-Mac-GM;outMappedLEID =  MasterCollection-CS5-Mac-GM, unused = MasterCollection-CS5-Mac-GM
                              2010-08-30 11:19:28 [1609]  AMT: DoISOTagging() productPayloadCode = {6A75E573-6909-4D48-BDFA-D8ED118605A5};driverPayloadCode =  {D348C659-234A-497E-9E75-92D1AB019C8C}
                              2010-08-30 11:19:28 [1609]  AMT: SWTag_Init() Tags Arguments Adobe Creative Suite 5 Master Collection; MasterCollection-CS5-Mac-GM; en_GB
                              2010-08-30 11:19:28 [1609]  AMT: DoISOTagging() License Status = activated
                              2010-08-30 11:19:28 [1609]  AMT: DoISOTagging() Tags 922997070614349771111224; 5.0; RETAIL
                              2010-08-30 11:19:28 [1609]  AMT: DoISOTagging() Product Version 5; 0
                              2010-08-30 11:19:28 [1609]  AMT: AMT: Product License PreValidated.
                              2010-08-30 11:19:28 [1609]  AMT: Prevalidate indicates license is good and no UI required.
                              2010-08-30 11:19:28 [1609]  performance: PreValidate thread took 813.083984 ms
                              2010-08-30 11:19:32 [1609]  AMT: PlugPlug : AdobeId has been created or SN with no SaaS bit
                              2010-08-30 11:19:32 [1609]  AMT: PlugPlug : Can Go Online returned as true
                              2010-08-30 11:19:32 [1609]  performance: AMTPlugPlugRequest took 9.779000 ms
                              2010-08-30 11:19:32 [1609]  performance: AMTPlugPlugRequest took 0.665000 ms
                              2010-08-30 11:19:32 [1609]  performance: AMTPlugPlugRequest took 0.885000 ms
                              2010-08-30 11:19:32 [1609]  performance: AMTPlugPlugRequest took 1.012000 ms
                              2010-08-30 11:23:22 [1626]  AMT: START SESSION, library version 3.0.0.64,3.0
                              2010-08-30 11:23:22 [1626]  AMT: Initializing /Applications/Adobe Device Central CS5/Adobe Device Central CS5.app/
                              2010-08-30 11:23:22 [1626]  AMT: Adobe License Manager version 3.2 (build 64.0) RELEASE
                              2010-08-30 11:23:22 [1626]  ServiceLoader: looking for library /Applications/Adobe Device Central CS5/Adobe Device Central CS5.app/Contents/Frameworks/amtservices.framework/Versions/A/adobe_caps.framework/adobe_c aps
                              2010-08-30 11:23:22 [1626]  ServiceLoader: looking for library /Applications/Adobe Device Central CS5/Adobe Device Central CS5.app/Contents/Frameworks/amtservices.framework/Versions/adobe_caps.framework/adobe_cap s
                              2010-08-30 11:23:22 [1626]  ServiceLoader: looking for library /Applications/Adobe Device Central CS5/Adobe Device Central CS5.app/Contents/Frameworks/adobe_caps.framework/adobe_caps
                              2010-08-30 11:23:22 [1626]  ServiceLoader: Found library /Applications/Adobe Device Central CS5/Adobe Device Central CS5.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
                              2010-08-30 11:23:22 [1626]  PCDService: PCD Service in threaded mode
                              2010-08-30 11:23:22 [1626]  PCD thread: PCD thread started
                              2010-08-30 11:23:22 [1626]  performance: AMTPreObtainProductLicense took 50.591000 ms
                              2010-08-30 11:23:22 [1626]  ServiceLoader: looking for library /Applications/Adobe Device Central CS5/Adobe Device Central CS5.app/Contents/Frameworks/amtservices.framework/Versions/A/Adobe_OOBE_Launcher.framewor k/Adobe_OOBE_Launcher
                              2010-08-30 11:23:22 [1626]  ServiceLoader: looking for library /Applications/Adobe Device Central CS5/Adobe Device Central CS5.app/Contents/Frameworks/amtservices.framework/Versions/Adobe_OOBE_Launcher.framework/ Adobe_OOBE_Launcher
                              2010-08-30 11:23:22 [1626]  ServiceLoader: looking for library /Applications/Adobe Device Central CS5/Adobe Device Central CS5.app/Contents/Frameworks/Adobe_OOBE_Launcher.framework/Adobe_OOBE_Launcher
                              2010-08-30 11:23:22 [1626]  ServiceLoader: Found library /Applications/Adobe Device Central CS5/Adobe Device Central CS5.app/Contents/Frameworks/adobe_oobe_launcher.framework/Versions/A/adobe_oobe_launcher
                              2010-08-30 11:23:22 [1626]  AMT: App Product Locale [0] = en_GB
                              2010-08-30 11:23:22 [1626]  config: Loading configuration for /Applications/Adobe Device Central CS5/Adobe Device Central CS5.app/Contents/Resources/AMT/application.xml
                              2010-08-30 11:23:22 [1626]  config: Found payload code {6E505C8F-2896-11DF-9B64-0013724DD917}
                              2010-08-30 11:23:22 [1626]  PCDService: found driver code {D348C659-234A-497E-9E75-92D1AB019C8C}
                              2010-08-30 11:23:22 [1626]  config: config: Host app was installed, using installed license configuration.
                              2010-08-30 11:23:22 [1626]  PCDService: No value for key [FLMap] in hive [DeviceCentral-CS5-Mac-GM{|}ALL] in cache.
                              2010-08-30 11:23:22 [1626]  config: Setting current license to the driver at startup because no mapping was found.
                              2010-08-30 11:23:22 [1626]  config: Setting current license to MasterCollection-CS5-Mac-GM [ALL]
                              2010-08-30 11:23:22 [1626]  config: payload code: {6E505C8F-2896-11DF-9B64-0013724DD917}
                              2010-08-30 11:23:22 [1626]  config: driver payload code: {D348C659-234A-497E-9E75-92D1AB019C8C}
                              2010-08-30 11:23:22 [1626]  config: driver licensing code: MasterCollection-CS5-Mac-GM
                              2010-08-30 11:23:22 [1626]  config: current licensing code: MasterCollection-CS5-Mac-GM
                              2010-08-30 11:23:22 [1626]  config: current locale code: ALL
                              2010-08-30 11:23:22 [1626]  config: Done loading configuration
                              2010-08-30 11:23:22 [1626]  AMT: Locale from PCD [0] = en_GB
                              2010-08-30 11:23:22 [1626]  AMT: Reordered Installed App Product Locale [0] = en_GB
                              2010-08-30 11:23:22 [1626]  config: Setting insalled locales
                              2010-08-30 11:23:22 [1626]  config: Changing locale to "en_GB" because old locale "" is not in the new list of installed languages
                              2010-08-30 11:23:22 [1626]  ServiceLoader: looking for library /Applications/Adobe Device Central CS5/Adobe Device Central CS5.app/Contents/Frameworks/amtservices.framework/Versions/A/asneu.framework/asneu
                              2010-08-30 11:23:22 [1626]  ServiceLoader: looking for library /Applications/Adobe Device Central CS5/Adobe Device Central CS5.app/Contents/Frameworks/amtservices.framework/Versions/asneu.framework/asneu
                              2010-08-30 11:23:22 [1626]  ServiceLoader: looking for library /Applications/Adobe Device Central CS5/Adobe Device Central CS5.app/Contents/Frameworks/asneu.framework/asneu
                              2010-08-30 11:23:22 [1626]  ServiceLoader: Found library /Applications/Adobe Device Central CS5/Adobe Device Central CS5.app/Contents/Frameworks/asneu.framework/Versions/A/asneu
                              2010-08-30 11:23:22 [1626]  PCDService: No value for key [ReLaunchMode] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 11:23:22 [1626]  PCDService: No value for key [ReLaunchMode] in hive [{6E505C8F-2896-11DF-9B64-0013724DD917}] in master.
                              2010-08-30 11:23:22 [1626]  AMT: App's last known config file is: /Applications/Adobe CS5/Adobe Device Central CS5/Adobe Device Central CS5.app/Contents/Resources/AMT/application.xml
                              2010-08-30 11:23:22 [1626]  apf: current config file path is: /Applications/Adobe Device Central CS5/Adobe Device Central CS5.app/Contents/Resources/AMT/application.xml
                              2010-08-30 11:23:22 [1626]  apf: Last known config file path does not match current, app has moved!
                              2010-08-30 11:23:24 [1626]  apf: App is allowed to move and user approved updating location info.
                              2010-08-30 11:23:29 [1626]  ServiceLoader: looking for library /Applications/Adobe Device Central CS5/Adobe Device Central CS5.app/Contents/Frameworks/amtlib.framework/Versions/A/adobe_caps.framework/adobe_caps
                              2010-08-30 11:23:29 [1626]  ServiceLoader: looking for library /Applications/Adobe Device Central CS5/Adobe Device Central CS5.app/Contents/Frameworks/amtlib.framework/Versions/adobe_caps.framework/adobe_caps
                              2010-08-30 11:23:29 [1626]  ServiceLoader: looking for library /Applications/Adobe Device Central CS5/Adobe Device Central CS5.app/Contents/Frameworks/adobe_caps.framework/adobe_caps
                              2010-08-30 11:23:29 [1626]  ServiceLoader: Found library /Applications/Adobe Device Central CS5/Adobe Device Central CS5.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
                              2010-08-30 11:23:30 [1626]  apf: successfully updated PCD
                              2010-08-30 11:23:30 [1626]  AMT: config: Finding license info for payload: {D348C659-234A-497E-9E75-92D1AB019C8C}
                              2010-08-30 11:23:30 [1626]  AMT: config: PayloadCode: {6E505C8F-2896-11DF-9B64-0013724DD917}
                              2010-08-30 11:23:30 [1626]  AMT: config: Driver PayloadCode: {D348C659-234A-497E-9E75-92D1AB019C8C}
                              2010-08-30 11:23:30 [1626]  AMT: config: Installed LicensingCode: MasterCollection-CS5-Mac-GM
                              2010-08-30 11:23:30 [1626]  PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{6E505C8F-2896-11DF-9B64-0013724DD917}] in master.
                              2010-08-30 11:23:30 [1626]  PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 11:23:30 [1626]  PCDService: No value for key [BridgeTalkCode] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 11:23:30 [1626]  PCDService: No value for key [ISO_TAGGING_DISABLED] in hive [DeviceCentral-CS5-Mac-GM] in master.
                              2010-08-30 11:23:30 [1626]  PCDService: No value for key [EULA] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 11:23:30 [1626]  PCDService: No value for key [Registration] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 11:23:30 [1626]  PCDService: No value for key [Registration] in hive [{6E505C8F-2896-11DF-9B64-0013724DD917}] in master.
                              2010-08-30 11:23:30 [1626]  PCDService: No value for key [Updates] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 11:23:30 [1626]  PCDService: No value for key [Updates] in hive [{6E505C8F-2896-11DF-9B64-0013724DD917}] in master.
                              2010-08-30 11:23:30 [1626]  AMT: Application cannot be serialized (no sif file found).
                              2010-08-30 11:23:30 [1626]  config: Setting current license to DeviceCentral-CS5-Mac-GM [ALL]
                              2010-08-30 11:23:30 [1626]  AMT: Passive first launch before parent after install.
                              2010-08-30 11:23:30 [1626]  AMT: First launch (serial []).
                              2010-08-30 11:23:30 [1626]  PCDService: No value for key [GracePeriod] in hive [MasterCollection-CS5-Mac-GM] in master.
                              2010-08-30 11:23:30 [1626]  PCDService: No value for key [GracePeriod] in hive [DeviceCentral-CS5-Mac-GM] in master.
                              2010-08-30 11:23:30 [1626]  AMT: Starting passive grace period of 14 days.
                              2010-08-30 11:23:30 [1626]  AMT: Application state initialized.  Obtaining Product License.
                              2010-08-30 11:23:30 [1626]  AMT: Obtaining client features from cache.
                              2010-08-30 11:23:30 [1626]  AMT: Obtaining client product info from cache.
                              2010-08-30 11:23:30 [1626]  AMT: Skipping grace recomputation in same session.
                              2010-08-30 11:23:30 [1626]  AMT: Forcing first launch workflow because product is not licensed from previous launch.
                              2010-08-30 11:23:30 [1626]  AMT: AMT: Obtaining Product License.
                              2010-08-30 11:23:30 [1626]  AMT: Launch Workflow not yet done in foreground in this session.
                              2010-08-30 11:23:30 [1626]  AMT: Starting First Launch Workflow
                              2010-08-30 11:23:30 [1626]  AMT: Checking whether product has been pre-serialized.
                              2010-08-30 11:23:30 [1626]  AMT: Starting ALM workflow.
                              2010-08-30 11:23:30 [1626]  AMT: Initializing ALM for passive activation.
                              2010-08-30 11:23:30 [1626]  ALMService: Initializing as shared app
                              2010-08-30 11:23:30 [1626]  ALM: _info_: Start ALM 3.2 Release (build 3.2.64.0)
                              2010-08-30 11:23:30 [1626]  SLCoreService: Starting up SLCore 1.0 Release (build 1.0.13.199023).
                              2010-08-30 11:23:30 [1626]  SLCoreService: Service construction took 0.1 ms and succeed.
                              2010-08-30 11:23:30 [1626]  ALM: _info_: LEID passed MasterCollection-CS5-Mac-GM is used to configure SLCore = 0
                              2010-08-30 11:23:30 [1626]  ALM: _info_: Host app is Passive Licensed App
                              2010-08-30 11:23:30 [1626]  ALM: _time_: (func: ALM_Initialize, duration: 0.050 sec)
                              2010-08-30 11:23:30 [1626]  SLCoreService: Syncing to license store...
                              2010-08-30 11:23:30 [1626]  SLCoreService: Found server mkey.
                              2010-08-30 11:23:30 [1626]  SLCoreService: Found 1 license file(s)
                              2010-08-30 11:23:30 [1626]  SLCoreService: Parsing license file [49986045.lic] succeed.
                              2010-08-30 11:23:30 [1626]  SLCoreService: License store synchronization took 13.9 ms and succeed.
                              2010-08-30 11:23:30 [1626]  SLCoreService: Feature ALM_CS5MasterCollectionGM_5.0 is enabled.
                              2010-08-30 11:23:30 [1626]  SLCoreService: Feature AfterEffects_10.0 is enabled.
                              2010-08-30 11:23:30 [1626]  SLCoreService: Feature AfterEffects_Base_10.0 is enabled.
                              2010-08-30 11:23:30 [1626]  SLCoreService: Feature Bridge_Base_4.0 is enabled.
                              2010-08-30 11:23:30 [1626]  SLCoreService: Feature Bridge_CameraRaw_4.0 is enabled.
                              2010-08-30 11:23:30 [1626]  SLCoreService: Feature Bridge_ColorSettings_4.0 is enabled.
                              2010-08-30 11:23:30 [1626]  SLCoreService: Feature Bridge_MiniBridge_1.0 is enabled.
                              2010-08-30 11:23:30 [1626]  SLCoreService: Feature Contribute_6.0 is enabled.
                              2010-08-30 11:23:30 [1626]  SLCoreService: Feature Contribute_Base_6.0 is enabled.
                              2010-08-30 11:23:30 [1626]  SLCoreService: Feature CreativeSuite_5.0 is enabled.
                              2010-08-30 11:23:30 [1626]  SLCoreService: Feature CreativeSuite_DVADynamicLink_4.0 is enabled.
                              2010-08-30 11:23:30 [1626]  SLCoreService: Feature CreativeSuite_MasterCollection_5.0 is enabled.
                              2010-08-30 11:23:30 [1626]  SLCoreService: Feature Dreamweaver_11.0 is enabled.
                              2010-08-30 11:23:30 [1626]  SLCoreService: Feature Dreamweaver_Base_11.0 is enabled.
                              2010-08-30 11:23:30 [1626]  SLCoreService: Feature Encore_Base_5.0 is enabled.
                              2010-08-30 11:23:30 [1626]  SLCoreService: Feature Fireworks_11.0 is enabled.
                              2010-08-30 11:23:30 [1626]  SLCoreService: Feature Fireworks_Base_11.0 is enabled.
                              2010-08-30 11:23:30 [1626]  SLCoreService: Feature FlashBuilder_4.0 is enabled.
                              2010-08-30 11:23:30 [1626]  SLCoreService: Feature FlashBuilder_Base_4.0 is enabled.
                              2010-08-30 11:23:30 [1626]  SLCoreService: Feature FlashCatalyst_1.0 is enabled.
                              2010-08-30 11:23:30 [1626]  SLCoreService: Feature FlashCatalyst_Base_1.0 is enabled.
                              2010-08-30 11:23:30 [1626]  SLCoreService: Feature Flash_11.0 is enabled.
                              2010-08-30 11:23:30 [1626]  SLCoreService: Feature Flash_Base_11.0 is enabled.
                              2010-08-30 11:23:30 [1626]  SLCoreService: Feature Flash_Pro_11.0 is enabled.
                              2010-08-30 11:23:30 [1626]  SLCoreService: Feature Illustrator_15.0 is enabled.
                              2010-08-30 11:23:30 [1626]  SLCoreService: Feature Illustrator_Base_15.0 is enabled.
                              2010-08-30 11:23:30 [1626]  SLCoreService: Feature InDesign_7.0 is enabled.
                              2010-08-30 11:23:30 [1626]  SLCoreService: Feature InDesign_Base_7.0 is enabled.
                              2010-08-30 11:23:30 [1626]  SLCoreService: Feature MediaEncoder_Addtnl_Exporter_2.0 is enabled.
                              2010-08-30 11:23:30 [1626]  SLCoreService: Feature MediaEncoder_Base_2.0 is enabled.
                              2010-08-30 11:23:30 [1626]  SLCoreService: Feature MobileCenter_Base_3.0 is enabled.
                              2010-08-30 11:23:30 [1626]  SLCoreService: Feature OnLocation_Base_5.0 is enabled.
                              2010-08-30 11:23:30 [1626]  SLCoreService: Feature Photoshop_12.0 is enabled.
                              2010-08-30 11:23:30 [1626]  SLCoreService: Feature Photoshop_Base_12.0 is enabled.
                              2010-08-30 11:23:30 [1626]  SLCoreService: Feature Photoshop_Premium_12.0 is enabled.
                              2010-08-30 11:23:30 [1626]  SLCoreService: Feature Premiere_5.0 is enabled.
                              2010-08-30 11:23:30 [1626]  SLCoreService: Feature Premiere_Base_5.0 is enabled.
                              2010-08-30 11:23:30 [1626]  SLCoreService: Feature Soundbooth_3.0 is enabled.
                              2010-08-30 11:23:30 [1626]  SLCoreService: Feature Soundbooth_Base_3.0 is enabled.
                              2010-08-30 11:23:30 [1626]  AMT: Product is non-serialized.  Bypassing EULA and ALM product-level license checks.
                              2010-08-30 11:23:30 [1626]  AMT: Application licensing status has changed to activated.
                              2010-08-30 11:23:30 [1626]  AUMService: config: No AdobeUpdaterCode found in configuration; AUM will be disabled.
                              2010-08-30 11:23:30 [1626]  ServiceLoader: looking for library /Applications/Adobe Device Central CS5/Adobe Device Central CS5.app/Contents/Frameworks/amtservices.framework/Versions/A/UpdaterNotifications.framewo rk/UpdaterNotifications
                              2010-08-30 11:23:30 [1626]  ServiceLoader: looking for library /Applications/Adobe Device Central CS5/Adobe Device Central CS5.app/Contents/Frameworks/amtservices.framework/Versions/UpdaterNotifications.framework /UpdaterNotifications
                              2010-08-30 11:23:30 [1626]  ServiceLoader: looking for library /Applications/Adobe Device Central CS5/Adobe Device Central CS5.app/Contents/Frameworks/UpdaterNotifications.framework/UpdaterNotifications
                              2010-08-30 11:23:30 [1626]  ServiceLoader: Found library /Applications/Adobe Device Central CS5/Adobe Device Central CS5.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotification s
                              2010-08-30 11:23:30 [1626]  AUMService: IsUpdaterEnabled call
                              2010-08-30 11:23:30 [1626]  AUMService: IsUpdaterEnabled call succeeded
                              2010-08-30 11:23:30 [1626]  AMT: Completed Launch Workflow successfully.
                              2010-08-30 11:23:30 [1626]  AMT: Caching Suite Features.
                              2010-08-30 11:23:30 [1626]  AMT: Suite Feature AfterEffects_Base 10.0 is licensed.
                              2010-08-30 11:23:30 [1626]  AMT: Suite Feature Bridge_Base 4.0 is licensed.
                              2010-08-30 11:23:30 [1626]  AMT: Suite Feature Bridge_CameraRaw 4.0 is licensed.
                              2010-08-30 11:23:30 [1626]  AMT: Suite Feature Bridge_ColorSettings 4.0 is licensed.
                              2010-08-30 11:23:30 [1626]  AMT: Suite Feature Bridge_MiniBridge 1.0 is licensed.
                              2010-08-30 11:23:30 [1626]  AMT: Suite Feature Contribute_Base 6.0 is licensed.
                              2010-08-30 11:23:30 [1626]  AMT: Suite Feature Dreamweaver_Base 11.0 is licensed.
                              2010-08-30 11:23:30 [1626]  AMT: Suite Feature DynamicLink_Base 4.0 is unlicensed.
                              2010-08-30 11:23:30 [1626]  AMT: Suite Feature Encore_Base 5.0 is licensed.
                              2010-08-30 11:23:30 [1626]  AMT: Suite Feature Fireworks_Base 11.0 is licensed.
                              2010-08-30 11:23:30 [1626]  AMT: Suite Feature Flash_Base 11.0 is licensed.
                              2010-08-30 11:23:30 [1626]  AMT: Suite Feature Flash_Pro 11.0 is licensed.
                              2010-08-30 11:23:30 [1626]  AMT: Suite Feature FlashBuilder_Base 4.1 is unlicensed.
                              2010-08-30 11:23:30 [1626]  AMT: Suite Feature FlashCatalyst_Base 1.0 is licensed.
                              2010-08-30 11:23:30 [1626]  AMT: Suite Feature Illustrator_Base 15.0 is licensed.
                              2010-08-30 11:23:30 [1626]  AMT: Suite Feature InDesign_Base 7.0 is licensed.
                              2010-08-30 11:23:30 [1626]  AMT: Suite Feature MediaEncoder_Base 2.0 is licensed.
                              2010-08-30 11:23:30 [1626]  AMT: Suite Feature MobileCenter_Base 3.0 is licensed.
                              2010-08-30 11:23:30 [1626]  AMT: Suite Feature OnLocation_Base 5.0 is licensed.
                              2010-08-30 11:23:30 [1626]  AMT: Suite Feature Photoshop_Base 12.0 is licensed.
                              2010-08-30 11:23:30 [1626]  AMT: Suite Feature Photoshop_Premium 12.0 is licensed.
                              2010-08-30 11:23:30 [1626]  AMT: Suite Feature Premiere_Base 5.0 is licensed.
                              2010-08-30 11:23:30 [1626]  AMT: Suite Feature Soundbooth_Base 3.0 is licensed.
                              2010-08-30 11:23:30 [1626]  AMT: Checking client features against cache.
                              2010-08-30 11:23:30 [1626]  AMT: Feature AMT_REQUEST_NO_TAMPERPROOFING 3.3 is unlicensed (was unlicensed).
                              2010-08-30 11:23:30 [1626]  AMT: Feature MobileCenter_Base 3.0 is licensed (was licensed).
                              2010-08-30 11:23:30 [1626]  AMT: Feature AMT_PASSIVE_ACTIVATION 3.0 is unlicensed (was unlicensed).
                              2010-08-30 11:23:30 [1626]  AMT: Non-serialized app has a licensed feature and is thus licensed.
                              2010-08-30 11:23:30 [1626]  AMT: Validating client product info against cache.
                              2010-08-30 11:23:30 [1626]  AMT: Resetting existing grace period because app is licensed.
                              2010-08-30 11:23:30 [1626]  AMT: Starting Data Collection for SWTag_Init()
                              2010-08-30 11:23:30 [1626]  PCDService: No value for key [FLMap] in hive [DeviceCentral-CS5-Mac-GM{|}en_GB] in cache.
                              2010-08-30 11:23:30 [1626]  AMT: DoISOTagging() will not be performed as there is no FLMap LEID against DeviceCentral-CS5-Mac-GM
                              2010-08-30 11:23:30 [1626]  AMT: AMT: Product License Obtained.
                              2010-08-30 11:23:30 [1626]  AMT: Product license obtained.
                              2010-08-30 11:23:30 [1626]  performance: AMTObtainProductLicense took 7791.960938 ms
                              2010-08-30 11:23:49 [1626]  AMT: Pre-Validating Product License.
                              2010-08-30 11:23:49 [1626] AMT: Services already loaded in this session.
                              2010-08-30 11:23:49 [1626]  performance: AMTPreValidateProductLicense took 0.146000 ms
                              2010-08-30 11:23:50 [1626]  AMT: AMT: Validating Product License.
                              2010-08-30 11:23:50 [1626]  AMT: Launch Workflow already done in this session.
                              2010-08-30 11:23:50 [1626]  AMT: Caching Suite Features.
                              2010-08-30 11:23:50 [1626]  AMT: Suite Feature AfterEffects_Base 10.0 is licensed.
                              2010-08-30 11:23:50 [1626]  AMT: Suite Feature Bridge_Base 4.0 is licensed.
                              2010-08-30 11:23:50 [1626]  AMT: Suite Feature Bridge_CameraRaw 4.0 is licensed.
                              2010-08-30 11:23:50 [1626]  AMT: Suite Feature Bridge_ColorSettings 4.0 is licensed.
                              2010-08-30 11:23:50 [1626]  AMT: Suite Feature Bridge_MiniBridge 1.0 is licensed.
                              2010-08-30 11:23:50 [1626]  AMT: Suite Feature Contribute_Base 6.0 is licensed.
                              2010-08-30 11:23:50 [1626]  AMT: Suite Feature Dreamweaver_Base 11.0 is licensed.
                              2010-08-30 11:23:50 [1626]  AMT: Suite Feature DynamicLink_Base 4.0 is unlicensed.
                              2010-08-30 11:23:50 [1626]  AMT: Suite Feature Encore_Base 5.0 is licensed.
                              2010-08-30 11:23:50 [1626]  AMT: Suite Feature Fireworks_Base 11.0 is licensed.
                              2010-08-30 11:23:50 [1626]  AMT: Suite Feature Flash_Base 11.0 is licensed.
                              2010-08-30 11:23:50 [1626]  AMT: Suite Feature Flash_Pro 11.0 is licensed.
                              2010-08-30 11:23:50 [1626]  AMT: Suite Feature FlashBuilder_Base 4.1 is unlicensed.
                              2010-08-30 11:23:50 [1626]  AMT: Suite Feature FlashCatalyst_Base 1.0 is licensed.
                              2010-08-30 11:23:50 [1626]  AMT: Suite Feature Illustrator_Base 15.0 is licensed.
                              2010-08-30 11:23:50 [1626]  AMT: Suite Feature InDesign_Base 7.0 is licensed.
                              2010-08-30 11:23:50 [1626]  AMT: Suite Feature MediaEncoder_Base 2.0 is licensed.
                              2010-08-30 11:23:50 [1626]  AMT: Suite Feature MobileCenter_Base 3.0 is licensed.
                              2010-08-30 11:23:50 [1626]  AMT: Suite Feature OnLocation_Base 5.0 is licensed.
                              2010-08-30 11:23:50 [1626]  AMT: Suite Feature Photoshop_Base 12.0 is licensed.
                              2010-08-30 11:23:50 [1626]  AMT: Suite Feature Photoshop_Premium 12.0 is licensed.
                              2010-08-30 11:23:50 [1626]  AMT: Suite Feature Premiere_Base 5.0 is licensed.
                              2010-08-30 11:23:50 [1626]  AMT: Suite Feature Soundbooth_Base 3.0 is licensed.
                              2010-08-30 11:23:50 [1626]  AMT: Checking client features against cache.
                              2010-08-30 11:23:50 [1626]  AMT: Feature AMT_REQUEST_NO_TAMPERPROOFING 3.3 is unlicensed (was unlicensed).
                              2010-08-30 11:23:50 [1626]  AMT: Feature MobileCenter_Base 3.0 is licensed (was licensed).
                              2010-08-30 11:23:50 [1626]  AMT: Feature AMT_PASSIVE_ACTIVATION 3.0 is unlicensed (was unlicensed).
                              2010-08-30 11:23:50 [1626]  AMT: Non-serialized app has a licensed feature and is thus licensed.
                              2010-08-30 11:23:50 [1626]  AMT: Validating client product info against cache.
                              2010-08-30 11:23:50 [1626]  PCDService: No value for key [GracePeriod] in hive [MasterCollection-CS5-Mac-GM] in master.
                              2010-08-30 11:23:50 [1626]  PCDService: No value for key [GracePeriod] in hive [DeviceCentral-CS5-Mac-GM] in master.
                              2010-08-30 11:23:50 [1626]  AMT: Starting Data Collection for SWTag_Init()
                              2010-08-30 11:23:50 [1626]  PCDService: No value for key [FLMap] in hive [DeviceCentral-CS5-Mac-GM{|}en_GB] in cache.
                              2010-08-30 11:23:50 [1626]  AMT: DoISOTagging() will not be performed as there is no FLMap LEID against DeviceCentral-CS5-Mac-GM
                              2010-08-30 11:23:50 [1626]  AMT: AMT: Product License Validated.
                              2010-08-30 11:23:50 [1626]  performance: AMTValidateProductLicense took 12.833000 ms
                              2010-08-30 11:24:17 [1626]  PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 11:24:17 [1626]  PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{6E505C8F-2896-11DF-9B64-0013724DD917}] in master.
                              2010-08-30 11:24:17 [1626]  PCDService: No value for key [Updates] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 11:24:17 [1626]  PCDService: No value for key [Updates] in hive [{6E505C8F-2896-11DF-9B64-0013724DD917}] in master.
                              2010-08-30 11:24:17 [1626]  AUMService: config: No AdobeUpdaterCode found in configuration; AUM will be disabled.
                              2010-08-30 11:24:17 [1626]  ALMService: Terminating
                              2010-08-30 11:24:17 [1626]  SLCoreService: Shutting down SLCore 1.0 Release (build 1.0.13.199023).
                              2010-08-30 11:24:17 [1626]  SLCoreService: Service destruction took 19.7 ms and succeed.
                              2010-08-30 11:24:17 [1626]  ALM: _info_: End ALM
                              2010-08-30 11:24:17 [1626]  performance: AMTReleaseProductLicense took 22.645000 ms
                              2010-08-30 11:24:17 [1626]  AMT: END SESSION.
                              2010-08-30 11:28:14 [1609]  PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 11:28:14 [1609]  PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{6A75E573-6909-4D48-BDFA-D8ED118605A5}] in master.
                              2010-08-30 11:28:14 [1609]  PCDService: No value for key [Updates] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 11:28:14 [1609]  PCDService: No value for key [Updates] in hive [{6A75E573-6909-4D48-BDFA-D8ED118605A5}] in master.
                              2010-08-30 11:28:14 [1609]  AUMService: config: No AdobeUpdaterCode found in configuration; AUM will be disabled.
                              2010-08-30 11:28:14 [1609]  AUMService: UpdaterNotificationsLaunchAAMNotifierOnQuitIfReqd call
                              2010-08-30 11:28:14 [1609]  AUMService: UpdaterNotificationsLaunchAAMNotifierOnQuitIfReqd call succeeded
                              2010-08-30 11:28:14 [1609]  AMT: AUM UpdaterNotificationsLaunchAAMNotifierOnQuitIfReqd called with status =0.
                              2010-08-30 11:28:14 [1609]  ALMService: Terminating
                              2010-08-30 11:28:14 [1609]  SLCoreService: Shutting down SLCore 1.0 Release (build 1.0.13.199023).
                              2010-08-30 11:28:14 [1609]  SLCoreService: Service destruction took 1.2 ms and succeed.
                              2010-08-30 11:28:14 [1609]  ALM: _info_: End ALM
                              2010-08-30 11:28:14 [1609]  performance: AMTReleaseProductLicense took 4.632000 ms
                              2010-08-30 11:28:14 [1609]  AMT: END SESSION.
                              2010-08-30 13:47:57 [2279]  AMT: START SESSION, library version 3.0.0.64,3.0
                              2010-08-30 13:47:57 [2279]  AMT: Initializing /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app
                              2010-08-30 13:47:57 [2279]  AMT: Adobe License Manager version 3.2 (build 64.0) RELEASE
                              2010-08-30 13:47:57 [2279]  ServiceLoader: looking for library /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/amtservices.framework/Versions/A/adobe_caps.framework/adobe_c aps
                              2010-08-30 13:47:57 [2279]  ServiceLoader: looking for library /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/amtservices.framework/Versions/adobe_caps.framework/adobe_cap s
                              2010-08-30 13:47:57 [2279]  ServiceLoader: looking for library /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/adobe_caps.framework/adobe_caps
                              2010-08-30 13:47:58 [2279]  ServiceLoader: Found library /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
                              2010-08-30 13:47:58 [2279]  PCDService: PCD Service in threaded mode
                              2010-08-30 13:47:58 [2279]  performance: AMTPreObtainProductLicense took 231.720001 ms
                              2010-08-30 13:47:58 [2279]  PCD thread: PCD thread started
                              2010-08-30 13:47:58 [2279]  ServiceLoader: looking for library /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/amtservices.framework/Versions/A/Adobe_OOBE_Launcher.framewor k/Adobe_OOBE_Launcher
                              2010-08-30 13:47:58 [2279]  ServiceLoader: looking for library /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/amtservices.framework/Versions/Adobe_OOBE_Launcher.framework/ Adobe_OOBE_Launcher
                              2010-08-30 13:47:58 [2279]  ServiceLoader: looking for library /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/Adobe_OOBE_Launcher.framework/Adobe_OOBE_Launcher
                              2010-08-30 13:47:58 [2279]  ServiceLoader: Found library /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/adobe_oobe_launcher.framework/Versions/A/adobe_oobe_launcher
                              2010-08-30 13:47:58 [2279]  AMT: App Product Locale [0] = en_GB
                              2010-08-30 13:47:58 [2279]  config: Loading configuration for /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Resources/AMT/application.xml
                              2010-08-30 13:47:58 [2279]  config: Found payload code {755A9707-8A74-4B18-A6FD-F80F5893BDF2}
                              2010-08-30 13:47:58 [2279]  PCDService: found driver code {D348C659-234A-497E-9E75-92D1AB019C8C}
                              2010-08-30 13:47:58 [2279]  config: config: Host app was installed, using installed license configuration.
                              2010-08-30 13:47:58 [2279]  PCDService: No value for key [FLMap] in hive [Fireworks-CS5-Mac-GM{|}ALL] in cache.
                              2010-08-30 13:47:58 [2279]  config: Setting current license to the driver at startup because no mapping was found.
                              2010-08-30 13:47:58 [2279]  config: Setting current license to MasterCollection-CS5-Mac-GM [ALL]
                              2010-08-30 13:47:58 [2279]  config: payload code: {755A9707-8A74-4B18-A6FD-F80F5893BDF2}
                              2010-08-30 13:47:58 [2279]  config: driver payload code: {D348C659-234A-497E-9E75-92D1AB019C8C}
                              2010-08-30 13:47:58 [2279]  config: driver licensing code: MasterCollection-CS5-Mac-GM
                              2010-08-30 13:47:58 [2279]  config: current licensing code: MasterCollection-CS5-Mac-GM
                              2010-08-30 13:47:58 [2279]  config: current locale code: ALL
                              2010-08-30 13:47:58 [2279]  config: Done loading configuration
                              2010-08-30 13:47:58 [2279]  AMT: Locale from PCD [0] = en_GB
                              2010-08-30 13:47:58 [2279]  AMT: Reordered Installed App Product Locale [0] = en_GB
                              2010-08-30 13:47:58 [2279]  config: Setting insalled locales
                              2010-08-30 13:47:58 [2279]  config: Changing locale to "en_GB" because old locale "" is not in the new list of installed languages
                              2010-08-30 13:47:58 [2279]  AMT: AMTLibraryLoadStrategy_atObtain not implemented, reinterpreted as AMTLibraryLoadStrategy_atValidate
                              2010-08-30 13:47:58 [2279]  ServiceLoader: looking for library /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/amtservices.framework/Versions/A/asneu.framework/asneu
                              2010-08-30 13:47:58 [2279]  ServiceLoader: looking for library /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/amtservices.framework/Versions/asneu.framework/asneu
                              2010-08-30 13:47:58 [2279]  ServiceLoader: looking for library /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/asneu.framework/asneu
                              2010-08-30 13:47:58 [2279]  ServiceLoader: Found library /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/asneu.framework/Versions/A/asneu
                              2010-08-30 13:47:58 [2279]  PCDService: No value for key [ReLaunchMode] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 13:47:58 [2279]  PCDService: No value for key [ReLaunchMode] in hive [{755A9707-8A74-4B18-A6FD-F80F5893BDF2}] in master.
                              2010-08-30 13:47:58 [2279]  AMT: App's last known config file is: /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Resources/AMT/application.xml
                              2010-08-30 13:47:58 [2279]  apf: current config file path is: /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Resources/AMT/application.xml
                              2010-08-30 13:47:58 [2279]  AMT: config: Finding license info for payload: {D348C659-234A-497E-9E75-92D1AB019C8C}
                              2010-08-30 13:47:58 [2279]  AMT: config: PayloadCode: {755A9707-8A74-4B18-A6FD-F80F5893BDF2}
                              2010-08-30 13:47:58 [2279]  AMT: config: Driver PayloadCode: {D348C659-234A-497E-9E75-92D1AB019C8C}
                              2010-08-30 13:47:58 [2279]  AMT: config: Installed LicensingCode: MasterCollection-CS5-Mac-GM
                              2010-08-30 13:47:58 [2279]  PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{755A9707-8A74-4B18-A6FD-F80F5893BDF2}] in master.
                              2010-08-30 13:47:58 [2279]  PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 13:47:58 [2279]  PCDService: No value for key [BridgeTalkCode] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 13:47:58 [2279]  PCDService: No value for key [ISO_TAGGING_DISABLED] in hive [Fireworks-CS5-Mac-GM] in master.
                              2010-08-30 13:47:58 [2279]  PCDService: No value for key [EULA] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 13:47:58 [2279]  PCDService: No value for key [Registration] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 13:47:58 [2279]  PCDService: No value for key [Registration] in hive [{755A9707-8A74-4B18-A6FD-F80F5893BDF2}] in master.
                              2010-08-30 13:47:58 [2279]  PCDService: No value for key [Updates] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 13:47:58 [2279]  PCDService: No value for key [Updates] in hive [{755A9707-8A74-4B18-A6FD-F80F5893BDF2}] in master.
                              2010-08-30 13:47:58 [2279]  AMT: Application can be serialized (sif file found).
                              2010-08-30 13:47:58 [2279]  config: Setting current license to MasterCollection-CS5-Mac-GM [en_GB]
                              2010-08-30 13:47:58 [2279]  PCDService: No value for key [AMTConfigPath] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in cache.
                              2010-08-30 13:47:58 [2279]  PCDService: No value for key [ExpirationDate] in hive [Fireworks-CS5-Mac-GM] in master.
                              2010-08-30 13:47:58 [2279]  AMT: Subsequent launch (serial [92299707061434977111]).
                              2010-08-30 13:47:58 [2279]  AMT: Application state initialized.  Obtaining Product License.
                              2010-08-30 13:47:58 [2279]  AMT: Obtaining client features from cache.
                              2010-08-30 13:47:58 [2279]  AMT: Obtaining client product info from cache.
                              2010-08-30 13:47:58 [2279]  AMT: Running in PROV_APP
                              2010-08-30 13:47:58 [2279]  PCDService: No value for key [EULADelay] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 13:47:58 [2279]  PCDService: No value for key [MediaTag] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 13:47:58 [2279]  config: No media tag found for payload {D348C659-234A-497E-9E75-92D1AB019C8C}
                              2010-08-30 13:47:58 [2279]  config: Using default media policy RET
                              2010-08-30 13:47:58 [2279]  uiswitch: EULA has already been accepted.
                              2010-08-30 13:47:58 [2279]  AMT: This is a subsequent launch. Deferring services.
                              2010-08-30 13:47:58 [2279]  performance: AMTObtainProductLicense took 441.743011 ms
                              2010-08-30 13:48:00 [2279]  AMT: Pre-Validating Product License.
                              2010-08-30 13:48:00 [2279]  AMT: Services not yet loaded in this session.
                              2010-08-30 13:48:00 [2279]  AMT: Loading services in background to get ready for Validate call.
                              2010-08-30 13:48:00 [2279]  AMT: Spawning background thread to load services.
                              2010-08-30 13:48:00 [2279]  AMT: Starting work on prevalidate thread.
                              2010-08-30 13:48:00 [2279]  AMT: AMT: PreValidating Product License.
                              2010-08-30 13:48:00 [2279]  AMT: Launch Workflow not yet done in this session.
                              2010-08-30 13:48:00 [2279]  AMT: Starting Background Subsequent Launch Workflow
                              2010-08-30 13:48:00 [2279]  AMT: Starting ALM workflow.
                              2010-08-30 13:48:00 [2279]  AMT: Initializing ALM for serialized activation.
                              2010-08-30 13:48:00 [2279]  performance: AMTPreValidateProductLicense took 0.651000 ms
                              2010-08-30 13:48:00 [2279]  ALMService: Initializing as licensed app
                              2010-08-30 13:48:00 [2279]  ALM: _info_: Start ALM 3.2 Release (build 3.2.64.0)
                              2010-08-30 13:48:00 [2279]  SLCoreService: Starting up SLCore 1.0 Release (build 1.0.13.199023).
                              2010-08-30 13:48:00 [2279]  SLCoreService: Service construction took 0.1 ms and succeed.
                              2010-08-30 13:48:00 [2279]  ALM: _info_: LEID passed MasterCollection-CS5-Mac-GM is used to configure SLCore = 0
                              2010-08-30 13:48:00 [2279]  ALM: _info_: Host app is Licensable App
                              2010-08-30 13:48:00 [2279]  PCDService: No value for key [Fireworks-CS5-Mac-GM{|}3] in hive [SSC-CS5-LE-Dominance] in master.
                              2010-08-30 13:48:00 [2279]  ALM: _info_: Found LEID Fireworks-CS5-Mac-GM with AMT Path /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Resources/AMT
                              2010-08-30 13:48:00 [2279]  ALM: _info_: Found LEID WebSuitePremium-CS5-Mac-GM with AMT Path /Library/Application Support/Adobe/ssc/WebSuitePremium-CS5-Mac-GM
                              2010-08-30 13:48:00 [2279]  ALM: _info_: Found LEID DesignSuitePremium-CS5-Mac-GM with AMT Path /Library/Application Support/Adobe/ssc/DesignSuitePremium-CS5-Mac-GM
                              2010-08-30 13:48:00 [2279]  ALM: _info_: Found LEID MasterCollection-CS5-Mac-GM with AMT Path /Library/Application Support/Adobe/Adobe Creative Suite 5 Master Collection/AMT
                              2010-08-30 13:48:00 [2279]  PCDService: No value for key [MediaTag] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 13:48:00 [2279]  config: No media tag found for payload {D348C659-234A-497E-9E75-92D1AB019C8C}
                              2010-08-30 13:48:00 [2279]  config: Using default media policy RET
                              2010-08-30 13:48:00 [2279]  ALM: _info_: MediaTagPolicy is RET
                              2010-08-30 13:48:00 [2279]  PCDService: No value for key [NTL_WO_SN] in hive [MasterCollection-CS5-Mac-GM] in master.
                              2010-08-30 13:48:00 [2279]  ALM: _info_: Canonical LEID is Fireworks-CS5-Mac-GM
                              2010-08-30 13:48:00 [2279]  ALM: _info_: Driver LEID is MasterCollection-CS5-Mac-GM
                              2010-08-30 13:48:00 [2279]  PCDService: No value for key [922997097461591857680129] in hive [RejectedSNDomain_CS5] in cache.
                              2010-08-30 13:48:00 [2279]  SLCoreService: Reading product config [/Library/Application Support/Adobe/Adobe Creative Suite 5 Master Collection/AMT/SLConfig.xml]
                              2010-08-30 13:48:00 [2279]  ALM: _info_: alm::IsLangPackForLocaleInstalled - Checking if lang pack is installed for ALL
                              2010-08-30 13:48:00 [2279]  ALM: _info_: alm::IsLangPackForLocaleInstalled - Lang pack is not installed
                              2010-08-30 13:48:00 [2279]  ALM: _info_: Set Running Locale to en_GB
                              2010-08-30 13:48:00 [2279]  ALM: _time_: (func: ALM_Initialize, duration: 0.317 sec)
                              2010-08-30 13:48:00 [2279]  AMT: Performing ALM silent license verification.
                              2010-08-30 13:48:00 [2279]  PCDService: No value for key [EncryptedSerial] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in cache.
                              2010-08-30 13:48:00 [2279]  PCDService: No value for key [Serial] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in cache.
                              2010-08-30 13:48:00 [2279]  config: No pre-serial number found in {D348C659-234A-497E-9E75-92D1AB019C8C}
                              2010-08-30 13:48:00 [2279]  PCDService: No value for key [PSN] in hive [MasterCollection-CS5-Mac-GM{|}en_GB] in cache.
                              2010-08-30 13:48:00 [2279]  config: No en_GB provisional serial number found in MasterCollection-CS5-Mac-GM
                              2010-08-30 13:48:00 [2279]  PCDService: No value for key [PSN] in hive [MasterCollection-CS5-Mac-GM{|}ALL] in cache.
                              2010-08-30 13:48:00 [2279]  config: No ALL provisional serial number found in MasterCollection-CS5-Mac-GM
                              2010-08-30 13:48:00 [2279]  ALM: _info_: Validate license at Post-Chrome time, running locale is en_GB
                              2010-08-30 13:48:00 [2279]  ALM: _info_: Searching license for locale en_GB ...
                              2010-08-30 13:48:00 [2279]  PCDService: No value for key [922997070614349771111224] in hive [RejectedSNDomain_CS5] in cache.
                              2010-08-30 13:48:00 [2279]  ALM: _info_: alm::IsLangPackForLocaleInstalled - Checking if lang pack is installed for en_GB
                              2010-08-30 13:48:00 [2279]  ALM: _info_: alm::IsLangPackForLocaleInstalled - Lang pack is installed
                              2010-08-30 13:48:00 [2279]  ALM: _info_: Found existing serialization under LEID MasterCollection-CS5-Mac-GM, the serial number locale is en_GB
                              2010-08-30 13:48:00 [2279]  ALM: _info_: This is the running locale, stop the search
                              2010-08-30 13:48:00 [2279]  config: Setting current license to MasterCollection-CS5-Mac-GM [en_GB]
                              2010-08-30 13:48:00 [2279]  SLCoreService: Syncing to license store...
                              2010-08-30 13:48:00 [2279]  SLCoreService: Found server mkey.
                              2010-08-30 13:48:00 [2279]  SLCoreService: Found 1 license file(s)
                              2010-08-30 13:48:00 [2279]  SLCoreService: Parsing license file [49986045.lic] succeed.
                              2010-08-30 13:48:00 [2279]  SLCoreService: License store synchronization took 230.0 ms and succeed.
                              2010-08-30 13:48:00 [2279]  SLCoreService: Query license: type = 3, duration = permanent, remaining = permanent.
                              2010-08-30 13:48:00 [2279]  PCDService: No value for key [PDApp_WF] in hive [MasterCollection-CS5-Mac-GM] in cache.
                              2010-08-30 13:48:00 [2279]  SLCoreService: Feature ALM_CS5MasterCollectionGM_5.0 is enabled.
                              2010-08-30 13:48:00 [2279]  SLCoreService: Feature AfterEffects_10.0 is enabled.
                              2010-08-30 13:48:00 [2279]  SLCoreService: Feature AfterEffects_Base_10.0 is enabled.
                              2010-08-30 13:48:00 [2279]  SLCoreService: Feature Bridge_Base_4.0 is enabled.
                              2010-08-30 13:48:00 [2279]  SLCoreService: Feature Bridge_CameraRaw_4.0 is enabled.
                              2010-08-30 13:48:00 [2279]  SLCoreService: Feature Bridge_ColorSettings_4.0 is enabled.
                              2010-08-30 13:48:00 [2279]  SLCoreService: Feature Bridge_MiniBridge_1.0 is enabled.
                              2010-08-30 13:48:00 [2279]  SLCoreService: Feature Contribute_6.0 is enabled.
                              2010-08-30 13:48:00 [2279]  SLCoreService: Feature Contribute_Base_6.0 is enabled.
                              2010-08-30 13:48:00 [2279]  SLCoreService: Feature CreativeSuite_5.0 is enabled.
                              2010-08-30 13:48:00 [2279]  SLCoreService: Feature CreativeSuite_DVADynamicLink_4.0 is enabled.
                              2010-08-30 13:48:00 [2279]  SLCoreService: Feature CreativeSuite_MasterCollection_5.0 is enabled.
                              2010-08-30 13:48:00 [2279]  SLCoreService: Feature Dreamweaver_11.0 is enabled.
                              2010-08-30 13:48:00 [2279]  SLCoreService: Feature Dreamweaver_Base_11.0 is enabled.
                              2010-08-30 13:48:00 [2279]  SLCoreService: Feature Encore_Base_5.0 is enabled.
                              2010-08-30 13:48:00 [2279]  SLCoreService: Feature Fireworks_11.0 is enabled.
                              2010-08-30 13:48:00 [2279]  SLCoreService: Feature Fireworks_Base_11.0 is enabled.
                              2010-08-30 13:48:00 [2279]  SLCoreService: Feature FlashBuilder_4.0 is enabled.
                              2010-08-30 13:48:00 [2279]  SLCoreService: Feature FlashBuilder_Base_4.0 is enabled.
                              2010-08-30 13:48:00 [2279]  SLCoreService: Feature FlashCatalyst_1.0 is enabled.
                              2010-08-30 13:48:00 [2279]  SLCoreService: Feature FlashCatalyst_Base_1.0 is enabled.
                              2010-08-30 13:48:00 [2279]  SLCoreService: Feature Flash_11.0 is enabled.
                              2010-08-30 13:48:00 [2279]  SLCoreService: Feature Flash_Base_11.0 is enabled.
                              2010-08-30 13:48:00 [2279]  SLCoreService: Feature Flash_Pro_11.0 is enabled.
                              2010-08-30 13:48:00 [2279]  SLCoreService: Feature Illustrator_15.0 is enabled.
                              2010-08-30 13:48:00 [2279]  SLCoreService: Feature Illustrator_Base_15.0 is enabled.
                              2010-08-30 13:48:00 [2279]  SLCoreService: Feature InDesign_7.0 is enabled.
                              2010-08-30 13:48:00 [2279]  SLCoreService: Feature InDesign_Base_7.0 is enabled.
                              2010-08-30 13:48:00 [2279]  SLCoreService: Feature MediaEncoder_Addtnl_Exporter_2.0 is enabled.
                              2010-08-30 13:48:00 [2279]  SLCoreService: Feature MediaEncoder_Base_2.0 is enabled.
                              2010-08-30 13:48:00 [2279]  SLCoreService: Feature MobileCenter_Base_3.0 is enabled.
                              2010-08-30 13:48:00 [2279]  SLCoreService: Feature OnLocation_Base_5.0 is enabled.
                              2010-08-30 13:48:00 [2279]  SLCoreService: Feature Photoshop_12.0 is enabled.
                              2010-08-30 13:48:00 [2279]  SLCoreService: Feature Photoshop_Base_12.0 is enabled.
                              2010-08-30 13:48:00 [2279]  SLCoreService: Feature Photoshop_Premium_12.0 is enabled.
                              2010-08-30 13:48:00 [2279]  SLCoreService: Feature Premiere_5.0 is enabled.
                              2010-08-30 13:48:00 [2279]  SLCoreService: Feature Premiere_Base_5.0 is enabled.
                              2010-08-30 13:48:00 [2279]  SLCoreService: Feature Soundbooth_3.0 is enabled.
                              2010-08-30 13:48:00 [2279]  SLCoreService: Feature Soundbooth_Base_3.0 is enabled.
                              2010-08-30 13:48:00 [2279]  PCDService: No value for key [ALM_Info_S1] in hive [MasterCollection-CS5-Mac-GM{|}en_GB] in cache.
                              2010-08-30 13:48:00 [2279]  ALM: _info_: Performing Block Check
                              2010-08-30 13:48:00 [2279]  ALM: _info_: Block Check ByPassed
                              2010-08-30 13:48:00 [2279]  ALM: _time_: (func: ALM_License_SilentValidate, duration: 0.367 sec)
                              2010-08-30 13:48:00 [2279]  ALM: _info_: ALM_License_SilentValidate return license status: Valid And Activated
                              2010-08-30 13:48:00 [2279]  AMT: License check shows serialized product is already activated.
                              2010-08-30 13:48:00 [2279]  ALM: _info_: Entered ALM_NeedANAG
                              2010-08-30 13:48:00 [2279]  PCDService: No value for key [ADOBEID_EXT_PROFILE] in hive [922997070614349771111224] in cache.
                              2010-08-30 13:48:00 [2279]  ALM: _info_: Exiting ALM_NeedANAG
                              2010-08-30 13:48:00 [2279]  PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 13:48:00 [2279]  PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{755A9707-8A74-4B18-A6FD-F80F5893BDF2}] in master.
                              2010-08-30 13:48:00 [2279]  PCDService: No value for key [Updates] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 13:48:00 [2279]  PCDService: No value for key [Updates] in hive [{755A9707-8A74-4B18-A6FD-F80F5893BDF2}] in master.
                              2010-08-30 13:48:00 [2279]  AUMService: config: No AdobeUpdaterCode found in configuration; AUM will be disabled.
                              2010-08-30 13:48:00 [2279]  ServiceLoader: looking for library /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/amtservices.framework/Versions/A/UpdaterNotifications.framewo rk/UpdaterNotifications
                              2010-08-30 13:48:00 [2279]  ServiceLoader: looking for library /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/amtservices.framework/Versions/UpdaterNotifications.framework /UpdaterNotifications
                              2010-08-30 13:48:00 [2279]  ServiceLoader: looking for library /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/UpdaterNotifications.framework/UpdaterNotifications
                              2010-08-30 13:48:00 [2279]  ServiceLoader: Found library /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotification s
                              2010-08-30 13:48:00 [2279]  AUMService: IsUpdaterEnabled call
                              2010-08-30 13:48:00 [2279]  AUMService: IsUpdaterEnabled call succeeded
                              2010-08-30 13:48:00 [2279]  ALM: _info_: Deactivation menu is enabled
                              2010-08-30 13:48:00 [2279]  AMT: Completed Launch Workflow successfully.
                              2010-08-30 13:48:00 [2279]  AMT: Calling AUM API to create scheduler entry to be used by updater.
                              2010-08-30 13:48:00 [2279]  AUMService: Get LEID xml call
                              2010-08-30 13:48:00 [2279]  AUMService: Get LEID XML call succeeded
                              2010-08-30 13:48:00 [2279]  AMT: AUM GetLEID called with status =0.
                              2010-08-30 13:48:00 [2279]  AMT: Caching Suite Features.
                              2010-08-30 13:48:00 [2279]  AMT: Suite Feature AfterEffects_Base 10.0 is licensed.
                              2010-08-30 13:48:00 [2279]  AMT: Suite Feature Bridge_Base 4.0 is licensed.
                              2010-08-30 13:48:00 [2279]  AMT: Suite Feature Bridge_CameraRaw 4.0 is licensed.
                              2010-08-30 13:48:00 [2279]  AMT: Suite Feature Bridge_ColorSettings 4.0 is licensed.
                              2010-08-30 13:48:00 [2279]  AMT: Suite Feature Bridge_MiniBridge 1.0 is licensed.
                              2010-08-30 13:48:00 [2279]  AMT: Suite Feature Contribute_Base 6.0 is licensed.
                              2010-08-30 13:48:00 [2279]  AMT: Suite Feature Dreamweaver_Base 11.0 is licensed.
                              2010-08-30 13:48:00 [2279]  AMT: Suite Feature DynamicLink_Base 4.0 is unlicensed.
                              2010-08-30 13:48:00 [2279]  AMT: Suite Feature Encore_Base 5.0 is licensed.
                              2010-08-30 13:48:00 [2279]  AMT: Suite Feature Fireworks_Base 11.0 is licensed.
                              2010-08-30 13:48:00 [2279]  AMT: Suite Feature Flash_Base 11.0 is licensed.
                              2010-08-30 13:48:00 [2279]  AMT: Suite Feature Flash_Pro 11.0 is licensed.
                              2010-08-30 13:48:00 [2279]  AMT: Suite Feature FlashBuilder_Base 4.1 is unlicensed.
                              2010-08-30 13:48:00 [2279]  AMT: Suite Feature FlashCatalyst_Base 1.0 is licensed.
                              2010-08-30 13:48:00 [2279]  AMT: Suite Feature Illustrator_Base 15.0 is licensed.
                              2010-08-30 13:48:00 [2279]  AMT: Suite Feature InDesign_Base 7.0 is licensed.
                              2010-08-30 13:48:00 [2279]  AMT: Suite Feature MediaEncoder_Base 2.0 is licensed.
                              2010-08-30 13:48:00 [2279]  AMT: Suite Feature MobileCenter_Base 3.0 is licensed.
                              2010-08-30 13:48:00 [2279]  AMT: Suite Feature OnLocation_Base 5.0 is licensed.
                              2010-08-30 13:48:00 [2279]  AMT: Suite Feature Photoshop_Base 12.0 is licensed.
                              2010-08-30 13:48:00 [2279]  AMT: Suite Feature Photoshop_Premium 12.0 is licensed.
                              2010-08-30 13:48:00 [2279]  AMT: Suite Feature Premiere_Base 5.0 is licensed.
                              2010-08-30 13:48:00 [2279]  AMT: Suite Feature Soundbooth_Base 3.0 is licensed.
                              2010-08-30 13:48:00 [2279]  AMT: Checking client features against cache.
                              2010-08-30 13:48:00 [2279]  AMT: Feature Fireworks 11.0 is licensed (was licensed).
                              2010-08-30 13:48:00 [2279]  AMT: Feature Fireworks_Base 11.0 is licensed (was licensed).
                              2010-08-30 13:48:00 [2279]  AMT: Feature Bridge_Base 4.0 is licensed (was licensed).
                              2010-08-30 13:48:00 [2279]  AMT: Feature MobileCenter_Base 3.0 is licensed (was licensed).
                              2010-08-30 13:48:00 [2279]  AMT: Feature AMT_ALLOW_DRAGDROP_INSTALL 3.0 is unlicensed (was unlicensed).
                              2010-08-30 13:48:00 [2279]  AMT: Validating client product info against cache.
                              2010-08-30 13:48:00 [2279]  PCDService: No value for key [ExpirationDate] in hive [Fireworks-CS5-Mac-GM] in master.
                              2010-08-30 13:48:00 [2279]  AMT: Starting Data Collection for SWTag_Init()
                              2010-08-30 13:48:00 [2279]  AMT: DoISOTagging() productCanonicalLEID = Fireworks-CS5-Mac-GM;outMappedLEID =  MasterCollection-CS5-Mac-GM, unused = MasterCollection-CS5-Mac-GM
                              2010-08-30 13:48:00 [2279]  AMT: DoISOTagging() productPayloadCode = {755A9707-8A74-4B18-A6FD-F80F5893BDF2};driverPayloadCode =  {D348C659-234A-497E-9E75-92D1AB019C8C}
                              2010-08-30 13:48:00 [2279]  AMT: SWTag_Init() Tags Arguments Adobe Creative Suite 5 Master Collection; MasterCollection-CS5-Mac-GM; en_GB
                              2010-08-30 13:48:01 [2279]  AMT: DoISOTagging() License Status = activated
                              2010-08-30 13:48:01 [2279]  AMT: DoISOTagging() Tags 922997070614349771111224; 5.0; RETAIL
                              2010-08-30 13:48:01 [2279]  AMT: DoISOTagging() Product Version 5; 0
                              2010-08-30 13:48:01 [2279]  AMT: AMT: Product License PreValidated.
                              2010-08-30 13:48:01 [2279]  AMT: Prevalidate indicates license is good and no UI required.
                              2010-08-30 13:48:01 [2279]  performance: PreValidate thread took 1132.677979 ms
                              2010-08-30 13:48:23 [2279]  AMT: PlugPlug : AdobeId has been created or SN with no SaaS bit
                              2010-08-30 13:48:23 [2279]  AMT: PlugPlug : Can Go Online returned as true
                              2010-08-30 13:48:23 [2279]  performance: AMTPlugPlugRequest took 84.160004 ms
                              2010-08-30 13:48:23 [2279]  performance: AMTPlugPlugRequest took 55.860001 ms
                              2010-08-30 13:48:23 [2279]  performance: AMTPlugPlugRequest took 0.769000 ms
                              2010-08-30 13:48:25 [2279]  performance: AMTPlugPlugRequest took 61.977001 ms
                              2010-08-30 14:40:14 [2279]  PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 14:40:14 [2279]  PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{755A9707-8A74-4B18-A6FD-F80F5893BDF2}] in master.
                              2010-08-30 14:40:14 [2279]  PCDService: No value for key [Updates] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 14:40:14 [2279]  PCDService: No value for key [Updates] in hive [{755A9707-8A74-4B18-A6FD-F80F5893BDF2}] in master.
                              2010-08-30 14:40:14 [2279]  AUMService: config: No AdobeUpdaterCode found in configuration; AUM will be disabled.
                              2010-08-30 14:40:14 [2279]  AUMService: UpdaterNotificationsLaunchAAMNotifierOnQuitIfReqd call
                              2010-08-30 14:40:14 [2279]  AUMService: UpdaterNotificationsLaunchAAMNotifierOnQuitIfReqd call succeeded
                              2010-08-30 14:40:14 [2279]  AMT: AUM UpdaterNotificationsLaunchAAMNotifierOnQuitIfReqd called with status =0.
                              2010-08-30 14:40:14 [2279]  ALMService: Terminating
                              2010-08-30 14:40:14 [2279]  SLCoreService: Shutting down SLCore 1.0 Release (build 1.0.13.199023).
                              2010-08-30 14:40:14 [2279]  SLCoreService: Service destruction took 62.0 ms and succeed.
                              2010-08-30 14:40:14 [2279]  ALM: _info_: End ALM
                              2010-08-30 14:40:14 [2279]  performance: AMTReleaseProductLicense took 179.537003 ms
                              2010-08-30 14:40:14 [2279]  AMT: END SESSION.
                              2010-08-30 15:37:09 [2438]  AMT: START SESSION, library version 3.0.0.64,3.0
                              2010-08-30 15:37:09 [2438]  AMT: Initializing /Applications/Adobe InDesign CS5/Adobe InDesign CS5.app
                              2010-08-30 15:37:09 [2438]  AMT: Adobe License Manager version 3.2 (build 64.0) RELEASE
                              2010-08-30 15:37:09 [2438]  ServiceLoader: looking for library /Applications/Adobe InDesign CS5/Adobe InDesign CS5.app/Contents/Frameworks/amtservices.framework/Versions/A/adobe_caps.framework/adobe_c aps
                              2010-08-30 15:37:09 [2438]  ServiceLoader: looking for library /Applications/Adobe InDesign CS5/Adobe InDesign CS5.app/Contents/Frameworks/amtservices.framework/Versions/adobe_caps.framework/adobe_cap s
                              2010-08-30 15:37:09 [2438]  ServiceLoader: looking for library /Applications/Adobe InDesign CS5/Adobe InDesign CS5.app/Contents/Frameworks/adobe_caps.framework/adobe_caps
                              2010-08-30 15:37:09 [2438]  ServiceLoader: Found library /Applications/Adobe InDesign CS5/Adobe InDesign CS5.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
                              2010-08-30 15:37:09 [2438]  PCDService: PCD Service in threaded mode
                              2010-08-30 15:37:09 [2438]  PCD thread: PCD thread started
                              2010-08-30 15:37:09 [2438]  performance: AMTPreObtainProductLicense took 532.252991 ms
                              2010-08-30 15:37:09 [2438]  ServiceLoader: looking for library /Applications/Adobe InDesign CS5/Adobe InDesign CS5.app/Contents/Frameworks/amtservices.framework/Versions/A/Adobe_OOBE_Launcher.framewor k/Adobe_OOBE_Launcher
                              2010-08-30 15:37:09 [2438]  ServiceLoader: looking for library /Applications/Adobe InDesign CS5/Adobe InDesign CS5.app/Contents/Frameworks/amtservices.framework/Versions/Adobe_OOBE_Launcher.framework/ Adobe_OOBE_Launcher
                              2010-08-30 15:37:09 [2438]  ServiceLoader: looking for library /Applications/Adobe InDesign CS5/Adobe InDesign CS5.app/Contents/Frameworks/Adobe_OOBE_Launcher.framework/Adobe_OOBE_Launcher
                              2010-08-30 15:37:09 [2438]  ServiceLoader: Found library /Applications/Adobe InDesign CS5/Adobe InDesign CS5.app/Contents/Frameworks/adobe_oobe_launcher.framework/Versions/A/adobe_oobe_launcher
                              2010-08-30 15:37:09 [2438]  AMT: App Product Locale [0] = en_GB
                              2010-08-30 15:37:09 [2438]  config: Loading configuration for /Applications/Adobe InDesign CS5/Adobe InDesign CS5.app/Contents/Resources/AMT/application.xml
                              2010-08-30 15:37:09 [2438]  config: Found payload code {9EEF9016-4356-11DF-9781-28A32C404F28}
                              2010-08-30 15:37:09 [2438]  PCDService: found driver code {D348C659-234A-497E-9E75-92D1AB019C8C}
                              2010-08-30 15:37:09 [2438]  config: config: Host app was installed, using installed license configuration.
                              2010-08-30 15:37:09 [2438]  PCDService: No value for key [FLMap] in hive [InDesign-CS5-Mac-GM{|}ALL] in cache.
                              2010-08-30 15:37:09 [2438]  config: Setting current license to the driver at startup because no mapping was found.
                              2010-08-30 15:37:09 [2438]  config: Setting current license to MasterCollection-CS5-Mac-GM [ALL]
                              2010-08-30 15:37:09 [2438]  config: payload code: {9EEF9016-4356-11DF-9781-28A32C404F28}
                              2010-08-30 15:37:09 [2438]  config: driver payload code: {D348C659-234A-497E-9E75-92D1AB019C8C}
                              2010-08-30 15:37:09 [2438]  config: driver licensing code: MasterCollection-CS5-Mac-GM
                              2010-08-30 15:37:09 [2438]  config: current licensing code: MasterCollection-CS5-Mac-GM
                              2010-08-30 15:37:09 [2438]  config: current locale code: ALL
                              2010-08-30 15:37:09 [2438]  config: Done loading configuration
                              2010-08-30 15:37:09 [2438]  AMT: Locale from PCD [0] = en_GB
                              2010-08-30 15:37:09 [2438]  AMT: Reordered Installed App Product Locale [0] = en_GB
                              2010-08-30 15:37:09 [2438]  config: Setting insalled locales
                              2010-08-30 15:37:09 [2438]  config: Changing locale to "en_GB" because old locale "" is not in the new list of installed languages
                              2010-08-30 15:37:09 [2438]  ServiceLoader: looking for library /Applications/Adobe InDesign CS5/Adobe InDesign CS5.app/Contents/Frameworks/amtservices.framework/Versions/A/asneu.framework/asneu
                              2010-08-30 15:37:09 [2438]  ServiceLoader: looking for library /Applications/Adobe InDesign CS5/Adobe InDesign CS5.app/Contents/Frameworks/amtservices.framework/Versions/asneu.framework/asneu
                              2010-08-30 15:37:09 [2438]  ServiceLoader: looking for library /Applications/Adobe InDesign CS5/Adobe InDesign CS5.app/Contents/Frameworks/asneu.framework/asneu
                              2010-08-30 15:37:10 [2438]  ServiceLoader: Found library /Applications/Adobe InDesign CS5/Adobe InDesign CS5.app/Contents/Frameworks/asneu.framework/Versions/A/asneu
                              2010-08-30 15:37:10 [2438]  PCDService: No value for key [ReLaunchMode] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 15:37:10 [2438]  PCDService: No value for key [ReLaunchMode] in hive [{9EEF9016-4356-11DF-9781-28A32C404F28}] in master.
                              2010-08-30 15:37:10 [2438]  AMT: App's last known config file is: /Applications/Adobe InDesign CS5/Adobe InDesign CS5.app/Contents/Resources/AMT/application.xml
                              2010-08-30 15:37:10 [2438]  apf: current config file path is: /Applications/Adobe InDesign CS5/Adobe InDesign CS5.app/Contents/Resources/AMT/application.xml
                              2010-08-30 15:37:10 [2438]  AMT: config: Finding license info for payload: {D348C659-234A-497E-9E75-92D1AB019C8C}
                              2010-08-30 15:37:10 [2438]  AMT: config: PayloadCode: {9EEF9016-4356-11DF-9781-28A32C404F28}
                              2010-08-30 15:37:10 [2438]  AMT: config: Driver PayloadCode: {D348C659-234A-497E-9E75-92D1AB019C8C}
                              2010-08-30 15:37:10 [2438]  AMT: config: Installed LicensingCode: MasterCollection-CS5-Mac-GM
                              2010-08-30 15:37:10 [2438]  PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{9EEF9016-4356-11DF-9781-28A32C404F28}] in master.
                              2010-08-30 15:37:10 [2438]  PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 15:37:10 [2438]  PCDService: No value for key [BridgeTalkCode] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 15:37:10 [2438]  PCDService: No value for key [ISO_TAGGING_DISABLED] in hive [InDesign-CS5-Mac-GM] in master.
                              2010-08-30 15:37:10 [2438]  PCDService: No value for key [EULA] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 15:37:10 [2438]  PCDService: No value for key [Registration] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 15:37:10 [2438]  PCDService: No value for key [Registration] in hive [{9EEF9016-4356-11DF-9781-28A32C404F28}] in master.
                              2010-08-30 15:37:10 [2438]  PCDService: No value for key [Updates] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 15:37:10 [2438]  PCDService: No value for key [Updates] in hive [{9EEF9016-4356-11DF-9781-28A32C404F28}] in master.
                              2010-08-30 15:37:10 [2438]  AMT: Application can be serialized (sif file found).
                              2010-08-30 15:37:10 [2438]  config: Setting current license to MasterCollection-CS5-Mac-GM [en_GB]
                              2010-08-30 15:37:10 [2438]  PCDService: No value for key [AMTConfigPath] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in cache.
                              2010-08-30 15:37:10 [2438]  PCDService: No value for key [ExpirationDate] in hive [InDesign-CS5-Mac-GM] in master.
                              2010-08-30 15:37:10 [2438]  AMT: Subsequent launch (serial [92299707061434977111]).
                              2010-08-30 15:37:10 [2438]  AMT: Application state initialized.  Obtaining Product License.
                              2010-08-30 15:37:10 [2438]  AMT: Obtaining client features from cache.
                              2010-08-30 15:37:10 [2438]  AMT: Obtaining client product info from cache.
                              2010-08-30 15:37:10 [2438]  AMT: Running in PROV_APP
                              2010-08-30 15:37:10 [2438]  PCDService: No value for key [EULADelay] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 15:37:10 [2438]  PCDService: No value for key [MediaTag] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 15:37:10 [2438]  config: No media tag found for payload {D348C659-234A-497E-9E75-92D1AB019C8C}
                              2010-08-30 15:37:10 [2438]  config: Using default media policy RET
                              2010-08-30 15:37:10 [2438]  uiswitch: EULA has already been accepted.
                              2010-08-30 15:37:10 [2438]  AMT: This is a subsequent launch. Deferring services.
                              2010-08-30 15:37:10 [2438]  performance: AMTObtainProductLicense took 1827.682983 ms
                              2010-08-30 15:37:10 [2438]  AMT: Pre-Validating Product License.
                              2010-08-30 15:37:10 [2438]  AMT: Services not yet loaded in this session.
                              2010-08-30 15:37:10 [2438]  AMT: Loading services in background to get ready for Validate call.
                              2010-08-30 15:37:10 [2438]  AMT: Spawning background thread to load services.
                              2010-08-30 15:37:10 [2438]  performance: AMTPreValidateProductLicense took 0.071000 ms
                              2010-08-30 15:37:10 [2438]  AMT: Starting work on prevalidate thread.
                              2010-08-30 15:37:10 [2438]  AMT: AMT: PreValidating Product License.
                              2010-08-30 15:37:10 [2438]  AMT: Launch Workflow not yet done in this session.
                              2010-08-30 15:37:10 [2438]  AMT: Starting Background Subsequent Launch Workflow
                              2010-08-30 15:37:10 [2438]  AMT: Starting ALM workflow.
                              2010-08-30 15:37:10 [2438]  AMT: Initializing ALM for serialized activation.
                              2010-08-30 15:37:10 [2438]  ALMService: Initializing as licensed app
                              2010-08-30 15:37:10 [2438]  ALM: _info_: Start ALM 3.2 Release (build 3.2.64.0)
                              2010-08-30 15:37:10 [2438]  SLCoreService: Starting up SLCore 1.0 Release (build 1.0.13.199023).
                              2010-08-30 15:37:10 [2438]  SLCoreService: Service construction took 0.1 ms and succeed.
                              2010-08-30 15:37:10 [2438]  ALM: _info_: LEID passed MasterCollection-CS5-Mac-GM is used to configure SLCore = 0
                              2010-08-30 15:37:10 [2438]  ALM: _info_: Host app is Licensable App
                              2010-08-30 15:37:10 [2438]  PCDService: No value for key [InDesign-CS5-Mac-GM{|}3] in hive [SSC-CS5-LE-Dominance] in master.
                              2010-08-30 15:37:11 [2438]  performance: AMTGetProductClearSerialNumber took 0.087000 ms
                              2010-08-30 15:37:11 [2438]  ALM: _info_: Found LEID InDesign-CS5-Mac-GM with AMT Path /Applications/Adobe InDesign CS5/Adobe InDesign CS5.app/Contents/Resources/AMT
                              2010-08-30 15:37:11 [2438]  ALM: _info_: Found LEID DesignSuiteStandard-CS5-Mac-GM with AMT Path /Library/Application Support/Adobe/ssc/DesignSuiteStandard-CS5-Mac-GM
                              2010-08-30 15:37:11 [2438]  ALM: _info_: Found LEID DesignSuitePremium-CS5-Mac-GM with AMT Path /Library/Application Support/Adobe/ssc/DesignSuitePremium-CS5-Mac-GM
                              2010-08-30 15:37:11 [2438]  ALM: _info_: Found LEID MasterCollection-CS5-Mac-GM with AMT Path /Library/Application Support/Adobe/Adobe Creative Suite 5 Master Collection/AMT
                              2010-08-30 15:37:11 [2438]  PCDService: No value for key [MediaTag] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 15:37:11 [2438]  config: No media tag found for payload {D348C659-234A-497E-9E75-92D1AB019C8C}
                              2010-08-30 15:37:11 [2438]  config: Using default media policy RET
                              2010-08-30 15:37:11 [2438]  ALM: _info_: MediaTagPolicy is RET
                              2010-08-30 15:37:11 [2438]  PCDService: No value for key [NTL_WO_SN] in hive [MasterCollection-CS5-Mac-GM] in master.
                              2010-08-30 15:37:11 [2438]  ALM: _info_: Canonical LEID is InDesign-CS5-Mac-GM
                              2010-08-30 15:37:11 [2438]  ALM: _info_: Driver LEID is MasterCollection-CS5-Mac-GM
                              2010-08-30 15:37:11 [2438]  PCDService: No value for key [922997097461591857680129] in hive [RejectedSNDomain_CS5] in cache.
                              2010-08-30 15:37:11 [2438]  SLCoreService: Reading product config [/Library/Application Support/Adobe/Adobe Creative Suite 5 Master Collection/AMT/SLConfig.xml]
                              2010-08-30 15:37:11 [2438]  ALM: _info_: alm::IsLangPackForLocaleInstalled - Checking if lang pack is installed for ALL
                              2010-08-30 15:37:11 [2438]  ALM: _info_: alm::IsLangPackForLocaleInstalled - Lang pack is not installed
                              2010-08-30 15:37:11 [2438]  ALM: _info_: Set Running Locale to en_GB
                              2010-08-30 15:37:11 [2438]  ALM: _time_: (func: ALM_Initialize, duration: 0.833 sec)
                              2010-08-30 15:37:11 [2438]  AMT: Performing ALM silent license verification.
                              2010-08-30 15:37:11 [2438]  PCDService: No value for key [EncryptedSerial] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in cache.
                              2010-08-30 15:37:11 [2438]  PCDService: No value for key [Serial] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in cache.
                              2010-08-30 15:37:11 [2438]  config: No pre-serial number found in {D348C659-234A-497E-9E75-92D1AB019C8C}
                              2010-08-30 15:37:11 [2438]  PCDService: No value for key [PSN] in hive [MasterCollection-CS5-Mac-GM{|}en_GB] in cache.
                              2010-08-30 15:37:11 [2438]  config: No en_GB provisional serial number found in MasterCollection-CS5-Mac-GM
                              2010-08-30 15:37:11 [2438]  PCDService: No value for key [PSN] in hive [MasterCollection-CS5-Mac-GM{|}ALL] in cache.
                              2010-08-30 15:37:11 [2438]  config: No ALL provisional serial number found in MasterCollection-CS5-Mac-GM
                              2010-08-30 15:37:11 [2438]  ALM: _info_: Validate license at Post-Chrome time, running locale is en_GB
                              2010-08-30 15:37:11 [2438]  ALM: _info_: Searching license for locale en_GB ...
                              2010-08-30 15:37:11 [2438]  PCDService: No value for key [922997070614349771111224] in hive [RejectedSNDomain_CS5] in cache.
                              2010-08-30 15:37:11 [2438]  ALM: _info_: alm::IsLangPackForLocaleInstalled - Checking if lang pack is installed for en_GB
                              2010-08-30 15:37:11 [2438]  ALM: _info_: alm::IsLangPackForLocaleInstalled - Lang pack is installed
                              2010-08-30 15:37:11 [2438]  ALM: _info_: Found existing serialization under LEID MasterCollection-CS5-Mac-GM, the serial number locale is en_GB
                              2010-08-30 15:37:11 [2438]  ALM: _info_: This is the running locale, stop the search
                              2010-08-30 15:37:11 [2438]  config: Setting current license to MasterCollection-CS5-Mac-GM [en_GB]
                              2010-08-30 15:37:11 [2438]  SLCoreService: Syncing to license store...
                              2010-08-30 15:37:11 [2438]  SLCoreService: Found server mkey.
                              2010-08-30 15:37:11 [2438]  SLCoreService: Found 1 license file(s)
                              2010-08-30 15:37:11 [2438]  SLCoreService: Parsing license file [49986045.lic] succeed.
                              2010-08-30 15:37:11 [2438]  SLCoreService: License store synchronization took 315.1 ms and succeed.
                              2010-08-30 15:37:11 [2438]  SLCoreService: Query license: type = 3, duration = permanent, remaining = permanent.
                              2010-08-30 15:37:11 [2438]  PCDService: No value for key [PDApp_WF] in hive [MasterCollection-CS5-Mac-GM] in cache.
                              2010-08-30 15:37:11 [2438]  SLCoreService: Feature ALM_CS5MasterCollectionGM_5.0 is enabled.
                              2010-08-30 15:37:11 [2438]  SLCoreService: Feature AfterEffects_10.0 is enabled.
                              2010-08-30 15:37:11 [2438]  SLCoreService: Feature AfterEffects_Base_10.0 is enabled.
                              2010-08-30 15:37:11 [2438]  SLCoreService: Feature Bridge_Base_4.0 is enabled.
                              2010-08-30 15:37:11 [2438]  SLCoreService: Feature Bridge_CameraRaw_4.0 is enabled.
                              2010-08-30 15:37:11 [2438]  SLCoreService: Feature Bridge_ColorSettings_4.0 is enabled.
                              2010-08-30 15:37:11 [2438]  SLCoreService: Feature Bridge_MiniBridge_1.0 is enabled.
                              2010-08-30 15:37:11 [2438]  SLCoreService: Feature Contribute_6.0 is enabled.
                              2010-08-30 15:37:11 [2438]  SLCoreService: Feature Contribute_Base_6.0 is enabled.
                              2010-08-30 15:37:11 [2438]  SLCoreService: Feature CreativeSuite_5.0 is enabled.
                              2010-08-30 15:37:11 [2438]  SLCoreService: Feature CreativeSuite_DVADynamicLink_4.0 is enabled.
                              2010-08-30 15:37:11 [2438]  SLCoreService: Feature CreativeSuite_MasterCollection_5.0 is enabled.
                              2010-08-30 15:37:11 [2438]  SLCoreService: Feature Dreamweaver_11.0 is enabled.
                              2010-08-30 15:37:11 [2438]  SLCoreService: Feature Dreamweaver_Base_11.0 is enabled.
                              2010-08-30 15:37:11 [2438]  SLCoreService: Feature Encore_Base_5.0 is enabled.
                              2010-08-30 15:37:11 [2438]  SLCoreService: Feature Fireworks_11.0 is enabled.
                              2010-08-30 15:37:11 [2438]  SLCoreService: Feature Fireworks_Base_11.0 is enabled.
                              2010-08-30 15:37:11 [2438]  SLCoreService: Feature FlashBuilder_4.0 is enabled.
                              2010-08-30 15:37:11 [2438]  SLCoreService: Feature FlashBuilder_Base_4.0 is enabled.
                              2010-08-30 15:37:11 [2438]  SLCoreService: Feature FlashCatalyst_1.0 is enabled.
                              2010-08-30 15:37:11 [2438]  SLCoreService: Feature FlashCatalyst_Base_1.0 is enabled.
                              2010-08-30 15:37:11 [2438] SLCoreService: Feature Flash_11.0 is enabled.
                              2010-08-30 15:37:11 [2438]  SLCoreService: Feature Flash_Base_11.0 is enabled.
                              2010-08-30 15:37:11 [2438]  SLCoreService: Feature Flash_Pro_11.0 is enabled.
                              2010-08-30 15:37:11 [2438]  SLCoreService: Feature Illustrator_15.0 is enabled.
                              2010-08-30 15:37:11 [2438]  SLCoreService: Feature Illustrator_Base_15.0 is enabled.
                              2010-08-30 15:37:11 [2438]  SLCoreService: Feature InDesign_7.0 is enabled.
                              2010-08-30 15:37:11 [2438]  SLCoreService: Feature InDesign_Base_7.0 is enabled.
                              2010-08-30 15:37:11 [2438]  SLCoreService: Feature MediaEncoder_Addtnl_Exporter_2.0 is enabled.
                              2010-08-30 15:37:11 [2438]  SLCoreService: Feature MediaEncoder_Base_2.0 is enabled.
                              2010-08-30 15:37:11 [2438]  SLCoreService: Feature MobileCenter_Base_3.0 is enabled.
                              2010-08-30 15:37:11 [2438]  SLCoreService: Feature OnLocation_Base_5.0 is enabled.
                              2010-08-30 15:37:11 [2438]  SLCoreService: Feature Photoshop_12.0 is enabled.
                              2010-08-30 15:37:11 [2438]  SLCoreService: Feature Photoshop_Base_12.0 is enabled.
                              2010-08-30 15:37:11 [2438]  SLCoreService: Feature Photoshop_Premium_12.0 is enabled.
                              2010-08-30 15:37:11 [2438]  SLCoreService: Feature Premiere_5.0 is enabled.
                              2010-08-30 15:37:11 [2438]  SLCoreService: Feature Premiere_Base_5.0 is enabled.
                              2010-08-30 15:37:11 [2438]  SLCoreService: Feature Soundbooth_3.0 is enabled.
                              2010-08-30 15:37:11 [2438]  SLCoreService: Feature Soundbooth_Base_3.0 is enabled.
                              2010-08-30 15:37:11 [2438]  PCDService: No value for key [ALM_Info_S1] in hive [MasterCollection-CS5-Mac-GM{|}en_GB] in cache.
                              2010-08-30 15:37:11 [2438]  ALM: _info_: Performing Block Check
                              2010-08-30 15:37:11 [2438]  ALM: _info_: Block Check ByPassed
                              2010-08-30 15:37:11 [2438]  ALM: _time_: (func: ALM_License_SilentValidate, duration: 0.350 sec)
                              2010-08-30 15:37:11 [2438]  ALM: _info_: ALM_License_SilentValidate return license status: Valid And Activated
                              2010-08-30 15:37:11 [2438]  AMT: License check shows serialized product is already activated.
                              2010-08-30 15:37:11 [2438]  ALM: _info_: Entered ALM_NeedANAG
                              2010-08-30 15:37:11 [2438]  PCDService: No value for key [ADOBEID_EXT_PROFILE] in hive [922997070614349771111224] in cache.
                              2010-08-30 15:37:11 [2438]  ALM: _info_: Exiting ALM_NeedANAG
                              2010-08-30 15:37:11 [2438]  PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 15:37:11 [2438]  PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{9EEF9016-4356-11DF-9781-28A32C404F28}] in master.
                              2010-08-30 15:37:11 [2438]  PCDService: No value for key [Updates] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 15:37:11 [2438]  PCDService: No value for key [Updates] in hive [{9EEF9016-4356-11DF-9781-28A32C404F28}] in master.
                              2010-08-30 15:37:11 [2438]  AUMService: config: No AdobeUpdaterCode found in configuration; AUM will be disabled.
                              2010-08-30 15:37:11 [2438]  ServiceLoader: looking for library /Applications/Adobe InDesign CS5/Adobe InDesign CS5.app/Contents/Frameworks/amtservices.framework/Versions/A/UpdaterNotifications.framewo rk/UpdaterNotifications
                              2010-08-30 15:37:11 [2438]  ServiceLoader: looking for library /Applications/Adobe InDesign CS5/Adobe InDesign CS5.app/Contents/Frameworks/amtservices.framework/Versions/UpdaterNotifications.framework /UpdaterNotifications
                              2010-08-30 15:37:11 [2438]  ServiceLoader: looking for library /Applications/Adobe InDesign CS5/Adobe InDesign CS5.app/Contents/Frameworks/UpdaterNotifications.framework/UpdaterNotifications
                              2010-08-30 15:37:11 [2438]  ServiceLoader: Found library /Applications/Adobe InDesign CS5/Adobe InDesign CS5.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotification s
                              2010-08-30 15:37:11 [2438]  AUMService: IsUpdaterEnabled call
                              2010-08-30 15:37:12 [2438]  AUMService: IsUpdaterEnabled call succeeded
                              2010-08-30 15:37:12 [2438]  ALM: _info_: Deactivation menu is enabled
                              2010-08-30 15:37:12 [2438]  AMT: Completed Launch Workflow successfully.
                              2010-08-30 15:37:12 [2438]  AMT: Calling AUM API to create scheduler entry to be used by updater.
                              2010-08-30 15:37:12 [2438]  PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 15:37:12 [2438]  PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{9EEF9016-4356-11DF-9781-28A32C404F28}] in master.
                              2010-08-30 15:37:12 [2438]  PCDService: No value for key [Updates] in hive [{D348C659-234A-497E-9E75-92D1AB019C8C}] in master.
                              2010-08-30 15:37:12 [2438]  PCDService: No value for key [Updates] in hive [{9EEF9016-4356-11DF-9781-28A32C404F28}] in master.
                              2010-08-30 15:37:12 [2438]  AUMService: config: No AdobeUpdaterCode found in configuration; AUM will be disabled.
                              2010-08-30 15:37:12 [2438]  AUMService: Get LEID xml call
                              2010-08-30 15:37:12 [2438]  AUMService: Get LEID XML call succeeded
                              2010-08-30 15:37:12 [2438]  AMT: AUM GetLEID called with status =0.
                              2010-08-30 15:37:12 [2438]  AMT: Caching Suite Features.
                              2010-08-30 15:37:12 [2438]  AMT: Suite Feature AfterEffects_Base 10.0 is licensed.
                              2010-08-30 15:37:12 [2438]  AMT: Suite Feature Bridge_Base 4.0 is licensed.
                              2010-08-30 15:37:12 [2438]  AMT: Suite Feature Bridge_CameraRaw 4.0 is licensed.
                              2010-08-30 15:37:12 [2438]  AMT: Suite Feature Bridge_ColorSettings 4.0 is licensed.
                              2010-08-30 15:37:12 [2438]  AMT: Suite Feature Bridge_MiniBridge 1.0 is licensed.
                              2010-08-30 15:37:12 [2438]  AMT: Suite Feature Contribute_Base 6.0 is licensed.
                              2010-08-30 15:37:12 [2438]  AMT: Suite Feature Dreamweaver_Base 11.0 is licensed.
                              2010-08-30 15:37:12 [2438]  AMT: Suite Feature DynamicLink_Base 4.0 is unlicensed.
                              2010-08-30 15:37:12 [2438]  AMT: Suite Feature Encore_Base 5.0 is licensed.
                              2010-08-30 15:37:12 [2438]  AMT: Suite Feature Fireworks_Base 11.0 is licensed.
                              2010-08-30 15:37:12 [2438]  AMT: Suite Feature Flash_Base 11.0 is licensed.
                              2010-08-30 15:37:12 [2438]  AMT: Suite Feature Flash_Pro 11.0 is licensed.
                              2010-08-30 15:37:12 [2438]  AMT: Suite Feature FlashBuilder_Base 4.1 is unlicensed.
                              2010-08-30 15:37:12 [2438]  AMT: Suite Feature FlashCatalyst_Base 1.0 is licensed.
                              2010-08-30 15:37:12 [2438]  AMT: Suite Feature Illustrator_Base 15.0 is licensed.
                              2010-08-30 15:37:12 [2438]  AMT: Suite Feature InDesign_Base 7.0 is licensed.
                              2010-08-30 15:37:12 [2438]  AMT: Suite Feature MediaEncoder_Base 2.0 is licensed.
                              2010-08-30 15:37:12 [2438]  AMT: Suite Feature MobileCenter_Base 3.0 is licensed.
                              2010-08-30 15:37:12 [2438]  AMT: Suite Feature OnLocation_Base 5.0 is licensed.
                              2010-08-30 15:37:12 [2438]  AMT: Suite Feature Photoshop_Base 12.0 is licensed.
                              2010-08-30 15:37:12 [2438]  AMT: Suite Feature Photoshop_Premium 12.0 is licensed.
                              2010-08-30 15:37:12 [2438]  AMT: Suite Feature Premiere_Base 5.0 is licensed.
                              2010-08-30 15:37:12 [2438]  AMT: Suite Feature Soundbooth_Base 3.0 is licensed.
                              2010-08-30 15:37:12 [2438]  AMT: Checking client features against cache.
                              2010-08-30 15:37:12 [2438]  AMT: Feature InDesign_Base 7.0 is licensed (was licensed).
                              2010-08-30 15:37:12 [2438]  AMT: Feature InCopy_Base 7.0 is unlicensed (was unlicensed).
                              2010-08-30 15:37:12 [2438]  AMT: Validating client product info against cache.
                              2010-08-30 15:37:12 [2438]  PCDService: No value for key [ExpirationDate] in hive [InDesign-CS5-Mac-GM] in master.
                              2010-08-30 15:37:12 [2438]  AMT: Starting Data Collection for SWTag_Init()
                              2010-08-30 15:37:12 [2438]  AMT: DoISOTagging() productCanonicalLEID = InDesign-CS5-Mac-GM;outMappedLEID =  MasterCollection-CS5-Mac-GM, unused = MasterCollection-CS5-Mac-GM
                              2010-08-30 15:37:12 [2438]  AMT: DoISOTagging() productPayloadCode = {9EEF9016-4356-11DF-9781-28A32C404F28};driverPayloadCode =  {D348C659-234A-497E-9E75-92D1AB019C8C}
                              2010-08-30 15:37:12 [2438]  AMT: SWTag_Init() Tags Arguments Adobe Creative Suite 5 Master Collection; MasterCollection-CS5-Mac-GM; en_GB
                              2010-08-30 15:37:12 [2438]  AMT: DoISOTagging() License Status = activated
                              2010-08-30 15:37:12 [2438]  AMT: DoISOTagging() Tags 922997070614349771111224; 5.0; RETAIL
                              2010-08-30 15:37:12 [2438]  AMT: DoISOTagging() Product Version 5; 0
                              2010-08-30 15:37:12 [2438]  AMT: AMT: Product License PreValidated.
                              2010-08-30 15:37:12 [2438]  AMT: Prevalidate indicates license is good and no UI required.
                              2010-08-30 15:37:12 [2438]  performance: PreValidate thread took 1574.479980 ms
                              2010-08-30 15:38:04 [2438]  AMT: PlugPlug : AdobeId has been created or SN with no SaaS bit
                              2010-08-30 15:38:04 [2438]  AMT: PlugPlug : Can Go Online returned as true
                              2010-08-30 15:38:04 [2438]  performance: AMTPlugPlugRequest took 9.580000 ms
                              2010-08-30 15:38:04 [2438]  performance: AMTPlugPlugRequest took 0.666000 ms
                              2010-08-30 15:38:04 [2438]  performance: AMTPlugPlugRequest took 0.813000 ms
                              2010-08-30 15:38:08 [2438]  AMT: AMT: Validating Product License.
                              2010-08-30 15:38:08 [2438]  AMT: Launch Workflow already done in this session.
                              2010-08-30 15:38:08 [2438]  AMT: Caching Suite Features.
                              2010-08-30 15:38:08 [2438]  AMT: Suite Feature AfterEffects_Base 10.0 is licensed.
                              2010-08-30 15:38:08 [2438]  AMT: Suite Feature Bridge_Base 4.0 is licensed.
                              2010-08-30 15:38:08 [2438]  AMT: Suite Feature Bridge_CameraRaw 4.0 is licensed.
                              2010-08-30 15:38:08 [2438]  AMT: Suite Feature Bridge_ColorSettings 4.0 is licensed.
                              2010-08-30 15:38:08 [2438]  AMT: Suite Feature Bridge_MiniBridge 1.0 is licensed.
                              2010-08-30 15:38:08 [2438]  AMT: Suite Feature Contribute_Base 6.0 is licensed.
                              2010-08-30 15:38:08 [2438]  AMT: Suite Feature Dreamweaver_Base 11.0 is licensed.
                              2010-08-30 15:38:08 [2438]  AMT: Suite Feature DynamicLink_Base 4.0 is unlicensed.
                              2010-08-30 15:38:08 [2438]  AMT: Suite Feature Encore_Base 5.0 is licensed.
                              2010-08-30 15:38:08 [2438]  AMT: Suite Feature Fireworks_Base 11.0 is licensed.
                              2010-08-30 15:38:08 [2438]  AMT: Suite Feature Flash_Base 11.0 is licensed.
                              2010-08-30 15:38:08 [2438]  AMT: Suite Feature Flash_Pro 11.0 is licensed.
                              2010-08-30 15:38:08 [2438]  AMT: Suite Feature FlashBuilder_Base 4.1 is unlicensed.
                              2010-08-30 15:38:08 [2438]  AMT: Suite Feature FlashCatalyst_Base 1.0 is licensed.
                              2010-08-30 15:38:08 [2438]  AMT: Suite Feature Illustrator_Base 15.0 is licensed.
                              2010-08-30 15:38:08 [2438]  AMT: Suite Feature InDesign_Base 7.0 is licensed.
                              2010-08-30 15:38:08 [2438]  AMT: Suite Feature MediaEncoder_Base 2.0 is licensed.
                              2010-08-30 15:38:08 [2438]  AMT: Suite Feature MobileCenter_Base 3.0 is licensed.
                              2010-08-30 15:38:08 [2438]  AMT: Suite Feature OnLocation_Base 5.0 is licensed.
                              2010-08-30 15:38:08 [2438]  AMT: Suite Feature Photoshop_Base 12.0 is licensed.
                              2010-08-30 15:38:08 [2438]  AMT: Suite Feature Photoshop_Premium 12.0 is licensed.
                              2010-08-30 15:38:08 [2438]  AMT: Suite Feature Premiere_Base 5.0 is licensed.
                              2010-08-30 15:38:08 [2438]  AMT: Suite Feature Soundbooth_Base 3.0 is licensed.
                              2010-08-30 15:38:08 [2438]  AMT: Checking client features against cache.
                              2010-08-30 15:38:08 [2438]  AMT: Feature InDesign_Base 7.0 is licensed (was licensed).
                              2010-08-30 15:38:08 [2438]  AMT: Feature InCopy_Base 7.0 is unlicensed (was unlicensed).
                              2010-08-30 15:38:08 [2438]  AMT: Validating client product info against cache.
                              2010-08-30 15:38:08 [2438]  PCDService: No value for key [ExpirationDate] in hive [InDesign-CS5-Mac-GM] in master.
                              2010-08-30 15:38:08 [2438]  AMT: Starting Data Collection for SWTag_Init()
                              2010-08-30 15:38:08 [2438]  AMT: DoISOTagging() productCanonicalLEID = InDesign-CS5-Mac-GM;outMappedLEID =  MasterCollection-CS5-Mac-GM, unused = MasterCollection-CS5-Mac-GM
                              2010-08-30 15:38:08 [2438]  AMT: DoISOTagging() productPayloadCode = {9EEF9016-4356-11DF-9781-28A32C404F28};driverPayloadCode =  {D348C659-234A-497E-9E75-92D1AB019C8C}
                              2010-08-30 15:38:08 [2438]  AMT: SWTag_Init() Tags Arguments Adobe Creative Suite 5 Master Collection; MasterCollection-CS5-Mac-GM; en_GB
                              2010-08-30 15:38:08 [2438]  AMT: DoISOTagging() License Status = activated
                              2010-08-30 15:38:08 [2438]  AMT: DoISOTagging() Tags 922997070614349771111224; 5.0; RETAIL
                              2010-08-30 15:38:08 [2438]  AMT: DoISOTagging() Product Version 5; 0
                              2010-08-30 15:38:08 [2438]  AMT: AMT: Product License Validated.
                              2010-08-30 15:38:08 [2438]  performance: AMTValidateProductLicense took 11.529000 ms
                              2010-08-30 15:38:10 [2438]  performance: AMTPlugPlugRequest took 0.808000 ms
                              • 12. Re: Flash builder 4 crash on start
                                dweb3d.com Level 1
                                Thanks for the information, i have a similar problem and this post help me with my problem
                                • 13. Re: Flash builder 4 crash on start
                                  hosting medellin
                                  As i expected someone to help me, thank you very much for the solution to the problem.
                                  http://mulatahosting.com/
                                  • 14. Re: Flash builder 4 crash on start
                                    Diseño Web Bogota
                                    finally i found help with my problem  thanks
                                    www.crearimagen.com.co
