1 Reply Latest reply on May 3, 2010 1:18 AM by Mylenium
    A Problem With AFX CS5,Maybe A Bug?
    motioncrown
      When i use trial version of AFX cs5,I try to use mask to roto a guy.And i found out the anchor point has a problem when you change the position of your mask's anchor point.If you dont't change the anchor point position,The mask working fine.But when you change the anchor point position,Then you move your mask,you will found out the mask's anchor point is not moving.....
      Maybe a bug of CS5?Or a Update of CS5 AFX?
      I really don't think this is good for roto,most applcations has a control bar or control hand for maskshape.This is good,But a odd Mask's anchor point?It need more and more time to switch from CS4 to CS5...
