3 Replies Latest reply on May 10, 2010 6:09 AM by GilbertYu
    Xpath expression to get multiple instances of a XML node in process
    Muni raj
      I am creating a form with a section for adress. Multiple instances of the section can be added dynamically.
      the xml corresponding to this section will be like
      <address>
           <street></street>
           <city></city>
           <zip></zip>
      </address>
      When multiple instances of the adress section are added, multiple sets of <address> node will be present. When this form is submitted, I am trying to get the values of all the address sections and assign them to a list process variable like one list for street,one for city and so on.
      I could not use any Xpath expression to fetch the values of all the instances. For example, xpath //address will return all the instances of adress nodes in the xml.. ./address//street will return all the instances of the street node. but when these xpath expressions were mapped to the process variable only the first instance of the node is returned. I tried with xpaths like address[*], but only one instance was returned. However when tried with appropriate index positions like address[1] or address[2] the corresponding address nodes are returned.
      Can we use any xpath query to get multiple instances of a node in adobe LC process. If yes please help me with the expression. If there are altenate ways also, please suggest.
      Muniyaraj
