3 Replies Latest reply on May 4, 2010 12:12 AM by Vikash.kumar29
    i need array within array?
    welcomecan Level 1
      hai friends,
          i need array within array?  if u know let me know.
      regards,
      welcome can
        • 1. Re: i need array within array?
          Vikash.kumar29 Level 3
          You can always add array as child within array like:
          var array:Array = new Array();
          var childArray:Array = ["Data 1","Data 2"];
          array.push(childArray);
          and you can check the elements like
          trace(array[0][0]); //outputs Data 1
          trace(array[0][1]);//outputs Data 2
          Hope this helps you
          Cheers
          -Vikash
          • 2. Re: i need array within array?
            welcomecan Level 1
            how to use in menu bar.
            give example
            regards,
            welcomecan
            • 3. Re: i need array within array?
              Hi You can use the following code for menu bar :
              <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="onCC()">
                    <mx:Script>
                         <![CDATA[
                              import mx.controls.Alert;
                              [Bindable]public var menuCollection:Array;
                              private function onCC():void
                                   menuCollection = [{label:"Menu 1",children:[{label:"Item 1"},{label:"Item 2",children:["Sub Menu 1","Sub Menu 2"]}]}
                                                         ,{label:"Menu 2",children:["Item 3","Item 4"]}];
                    </mx:Script>
                    <mx:ApplicationControlBar>
                         <mx:MenuBar id="menu" dataProvider="{menuCollection}"/>
                    </mx:ApplicationControlBar>
              </mx:Application>
              Cheers
              -Vikash
