0 Replies Latest reply: May 3, 2010 12:14 PM by Darrell Loverin RSS
    [svn:fx-trunk] 15871: Changes so modules and sub-applications will not load RSLs that are already loaded .
    Darrell Loverin Adobe Employee
      Revision: 15871
      Revision: 15871
      Author:   dloverin@adobe.com
      Date:     2010-05-03 12:14:33 -0700 (Mon, 03 May 2010)
      Log Message:
      Changes so modules and sub-applications will not load RSLs that are already loaded.
      Changes to support not loading RSLs that are already loaded.
      frameworks/projects/framework/src/mx/core/RSLData.as
                  New class to allow access to RSL properties in a structured way.
      frameworks/projects/framework/src/mx/core/CrossDomainRSLItem.as
                  Used new format of rsl data. Cleaned up  constructor.
      frameworks/projects/framework/src/mx/core/FlexModuleFactory.as
      frameworks/projects/framework/src/mx/managers/SystemManager.as
                  Checked if an RSL is already loaded before loading it. In the future this check could retrieve the module factory  of where the RSL should be loaded.
      frameworks/projects/framework/src/mx/utils/LoaderUtil.as
                  New method to check for loaded RSLs.
      modules/compiler/src/java/flex2/tools/PreLink.java
                  Generate RSL data in new format. Digests are now always present even when verify-digests is false. The value of verify digests is passed as an RSL property. Cache the value of info().
      QE notes: None.
      Doc notes: New feature.
      Bugs:
      Reviewer: Alex
      Tests run: checkintests, submitted patch to testing service.
      Is noteworthy for integration: No.
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/CrossDomainRSLItem.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/FlexModuleFactory.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/SystemManager.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/utils/LoaderUtil.as
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/PreLink.java
      Added Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/RSLData.as
