9 Replies Latest reply: May 4, 2010 6:12 PM by kglad RSS
    Getting Information from ID3 tags from streamed mp3 files in Flash CS4 AS3.0
    Me2LoveIt2 Community Member
      Hi everyone:
      I have spend my whole day trying to find a good way to access ID3 tags in AS3.0; but didn't find anything helpful.
      In my project I am making a sound object and assigning it a URL:
      Then I stream the sound into a sound channel:
      var s:Sound = new Sound(new URLRequest('URL here"));
      var sc:SoundChannel;
      My problem:
            I want to read the ID3 tag somehow and display the artist name or anything in the ID3 tag, onto the screen.
      Complication:
           I Have the URL change through user input, and naturally I want to update all the information with the new ID3 tags information.
      var s:Sound = new Sound(new URLRequest('NEW URL here"));
      Thank you for any help!
        • 1. Re: Getting Information from ID3 tags from streamed mp3 files in Flash CS4 AS3.0
          kglad CommunityMVP
          use the id3 event to determine when id3 data are available and then parse your sound's id3 property.
          • 2. Re: Getting Information from ID3 tags from streamed mp3 files in Flash CS4 AS3.0
            Hey Kglad
            Thank you for the answer, but it didn't help me at all.
            Do you mean something like this? : http://www.socialvitamin.com/2009/04/03/reading-id3-tags-with-as3/
            If so I tried it but failed. I tried so many things that I am really confused.
            I need more detail please, and don't hesitate to ask if more detail from me are needed.
            Thank you for trying to help me.
            • 3. Re: Getting Information from ID3 tags from streamed mp3 files in Flash CS4 AS3.0
              kglad CommunityMVP
              yes, exactly.
              now, show the code you're using and your policy file.
              • 4. Re: Getting Information from ID3 tags from streamed mp3 files in Flash CS4 AS3.0
                Here is my code:
                var music:Sound = new Sound(new URLRequest("URL #1 (from my server)"));
                var sc:SoundChannel;//sound channel
                var isPlaying:Boolean = false;//checks f music is playing or not
                var pausePoint:Number = 0.00;//this variable is for the pause function
                stop_btn.addEventListener(MouseEvent.CLICK, stopMusic);//stop function call
                function stopMusic(e:Event):void//stop function
                     if(sc != null)//if music is playing
                          sc.stop();//stops the music from playing
                          isPlaying = false;//sets it to false(off)
                          playPause_mc.gotoAndStop(1);//modifies graphic item on stage
                     pausePoint = 0.00;//resets pause value
                play_btn.addEventListener(MouseEvent.CLICK, playMusic);//pause / play function call
                function playMusic(e:Event):void//pause / play function
                     if (isPlaying) {// if it is playing
                          pausePoint = sc.position;pausePoint get curreny value (position of song)
                     } else if (!isPlaying){// if it is not playing
                          sc = music.play(pausePoint);//starts the music from the pausePoint value.
                          isPlaying = true;//sets it to true(on)
                          playPause_mc.gotoAndStop(2);//modifies graphic item on stage
                music2_btn.addEventListener(MouseEvent.CLICK, music2);//function call (if music is clicked)
                function music2(e:Event):void{//this function stops current playing music and resets graphics, assigns a new URL and starts playing it.
                     if(isPlaying || pausePoint != 0)
                          sc.stop();
                     music = new Sound(new URLRequest("URL #2 (from my server)"));
                     sc = music.play();
                     isPlaying = true;
                music1_btn.addEventListener(MouseEvent.CLICK, music1);
                function music1(e:Event):void{//this function stops current playing music and resets graphics, assigns a new URL and starts playing it. just like above only a different song.
                          sc.stop();
                     music = new Sound(new URLRequest("URL #1 (from my server)"));
                     sc = music.play();
                     isPlaying = true;
                It is a little player.
                With a Play/Pause and Stop function.
                and 2 song's to choose from.
                I do not have a policy file. What exactly is a policy file? do I need one?
                Thank you so much for your help!
                • 5. Re: Getting Information from ID3 tags from streamed mp3 files in Flash CS4 AS3.0
                  kglad CommunityMVP
                  you don't need a policy file if your loading mp3s from the same server as the swf.  but i don't see an id3 event listener/handler.
                  • 6. Re: Getting Information from ID3 tags from streamed mp3 files in Flash CS4 AS3.0
                    I know I took it out because it didn't work. I had something like this:
                    var soundLoaderContext:SoundLoaderContext = new SoundLoaderContext();
                    soundLoaderContext.checkPolicyFile = true;
                    music.addEventListener(Event.ID3, id3Handler);
                              sc.stop();
                         sc = music.play();
                         isPlaying = true;
                              sc.stop();
                         sc = music.play();
                         isPlaying = true;
                    function id3Handler(evt:Event):void {
                          var id3:ID3Info = evt.target.id3;
                          trace(id3.artist + ' - ' + id3.songName);
                          name_txt = id3.songName;
                          album_txt = id3.album;
                          artist_txt = id3.artist;
                    This is mostly just taking the exact code from the website I mentioned earlier.
                    When I run this it outputs the trace command 1 time and nothing more. Only the trace(trace(id3.artist + ' - ' + id3.songName);) gets triggered once.
                    No errors. No warning. Not working.
                    Thank you for helping me!
                    • 7. Re: Getting Information from ID3 tags from streamed mp3 files in Flash CS4 AS3.0
                      kglad CommunityMVP
                      save your current fla.
                      using that fla save with another name (eg, test.fla) and replace all your actionscript with the following (using appropriate mp3 names).  retest:
                      var music:Sound = new Sound(new URLRequest("mp3whatever"));
                      function music2(e:Event):void {
                          music = new Sound(new URLRequest("mp32"));
                      function music1(e:Event):void {
                          music = new Sound(new URLRequest("mp31"));
                      • 8. Re: Getting Information from ID3 tags from streamed mp3 files in Flash CS4 AS3.0
                        Yes It works.
                        I get two trace outputs each time the selected song changes.
                        I cannot really tell the difference, between this and what i had in my project.
                        I went ahead and copied that function into my project and it works now.(event listener after every newly assigned URL, and the function at the bottom);
                        I would be interested to know what the difference was or the problem, but for all I know My Project works now! I can read the id3 tags just fine!
                        Thank you for helping me through this! If your interested I can post the working code.
                        • 9. Re: Getting Information from ID3 tags from streamed mp3 files in Flash CS4 AS3.0
                          kglad CommunityMVP
                          you're welcome.
                          please mark this thread as answered, if you can.
