0 Replies Latest reply on May 3, 2010 3:41 PM by gbryu916
    Connection to Failed Service or Not Serializable Errors
    gbryu916
      Hi. I'm getting connection to failed service errors or not serializable errors when I run a production sized load for my project.  I'm trying to generate 100,000 PDFs one at a time on each thread against the Output web service.  I'm running custom code that makes the Output web service call on individual thread.  I run up to 40 threads against my vertical cluster and occasionally I see a not serializable error or connection to failed service on my code.  Any ideas on what could be the cause of the errors?  Thank you for any insight you can provide.
      I'm running a WebLogic vertical cluster on one box.  1 admin server of WebLogic 9.2 MP3 with 10 managed WebLogic servers on the same physical box in a cluster.  I have enough RAM to support all these JVMs and the GDS is on the local drive on the box.
      Environment details:
      Software: Windows 2003 R2 SP2 (32-bit), WebLogic 9.2 MP3, Adobe LC 8.2.1 SP3 + QF 3.19, Oracle 10.2.0.4, BEA Jrockit 1.5.0_12 (32-bit)
      Hardware: 2 CPU 2.8GHz * 4 cores * Hyper-Threading = makes it look like 16 CPUs in Task Manager, Performance tab, 16 GB RAM, 50+ GB HD space free
      Error Message:
      + com.adobe.idp.dsc.DSCNotSerializableException: Not Serializable
      IVS Error Message that happens randomly when the errors are occurring.  I can resubmit the same IVS test where this error shows up on the managed WL instance and it :
      java.lang.IllegalStateException: Connection to failed service. in com.adobe.livecycle.formsservice.exception.RenderFormException, cause: java.lang.IllegalStateException: Connection to failed service. in com.adobe.livecycle.formsservice.exception.FormServerException
      Exception in Output Service
      Stack Trace
      at com.adobe.formServer.FormServer.renderForm(FormServer.java:210)
      at com.adobe.formServer.FormServer.renderForm(FormServer.java:257)
      at com.adobe.formServer.docservice.FormsDocService.renderForm(FormsDocService.java:483)
      at com.adobe.printSubmitter.util.FormSubmitter.submit(FormSubmitter.java:157)
      at com.adobe.printSubmitter.util.FormSubmitter.submit(FormSubmitter.java:94)
      at com.adobe.printSubmitter.util.Splitter.endElementNoBatch(Splitter.java:175)
      at com.adobe.printSubmitter.util.Splitter.endElement(Splitter.java:155)
      at org.apache.xerces.parsers.AbstractSAXParser.endElement(Unknown Source)
      at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanEndElement(Unknown Source)
      at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$FragmentContentDispatcher.dispatch( Unknown Source)
      at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
      at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
      at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
      at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
      at org.apache.xerces.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
      at javax.xml.parsers.SAXParser.parse(SAXParser.java:375)
      at javax.xml.parsers.SAXParser.parse(SAXParser.java:176)
      at com.adobe.printSubmitter.PrintServer.execute(PrintServer.java:519)
      at com.adobe.printSubmitter.PrintServer.submit(PrintServer.java:223)
      at com.adobe.printSubmitter.service.OutputServiceImpl.generateOutputInTxn(OutputServiceImpl. java:247)
      at com.adobe.printSubmitter.service.OutputServiceImpl.generatePDFOutputInTxn(OutputServiceIm pl.java:347)
      at com.adobe.printSubmitter.service.OutputServiceImpl.access$100(OutputServiceImpl.java:79)
      at com.adobe.printSubmitter.service.OutputServiceImpl$2.doInTransaction(OutputServiceImpl.ja va:313)
      at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionBMTAdapterBean.doRequiresNew (EjbTransactionBMTAdapterBean.java:218)
      at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionBMTAdapter_jmbvky_ELOImpl.do RequiresNew(EjbTransactionBMTAdapter_jmbvky_ELOImpl.java:63)
      at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvi der.java:133)
      at com.adobe.idp.dsc.transaction.impl.DefaultTransactionTemplate.execute(DefaultTransactionT emplate.java:79)
      at com.adobe.printSubmitter.service.OutputServiceImpl.invokeGeneratePDFOutputWithSMT(OutputS erviceImpl.java:308)
      at com.adobe.printSubmitter.service.OutputServiceImpl.generatePDFOutput(OutputServiceImpl.ja va:289)
