2 Replies Latest reply on May 4, 2010 4:56 AM by awstam
    Recordsert not working using the GET method
    Brachole
      I'm trying to create a recordset that will retrieve a record from MSSQL.
      My recordset is like this:
      Dim rsAssets__MMColParam2
      rsAssets__MMColParam2 = "1"
      If (Request.QueryString("type") <> "") Then
        rsAssets__MMColParam2 = Request.QueryString("type")
      End If
      rsAssets__MMColParam = "1"
      If (Request.QueryString("number") <> "") Then
        rsAssets__MMColParam = Request.QueryString("number")
      End If
      Dim rsAssets
      Dim rsAssets_cmd
      Dim rsAssets_numRows
      Set rsAssets_cmd = Server.CreateObject ("ADODB.Command")
      rsAssets_cmd.ActiveConnection = MM_ezcaldatasource_STRING
      rsAssets_cmd.CommandText = "SELECT * FROM dbo.assets WHERE ? = ?"
      rsAssets_cmd.Prepared = true
      rsAssets_cmd.Parameters.Append rsAssets_cmd.CreateParameter("param1", 200, 1, 255, rsAssets__MMColParam2) ' adVarChar
      rsAssets_cmd.Parameters.Append rsAssets_cmd.CreateParameter("param2", 200, 1, 255, rsAssets__MMColParam) ' adVarChar
      Set rsAssets = rsAssets_cmd.Execute
      rsAssets_numRows = 0
      Thi s gives me a Server 500 error...if I just I only use 1 parameter, it works fine. Basically, MMColParam2 is a column in the database (either Asset or Serial) which comes from a field on my form.
        • 1. Re: Recordsert not working using the GET method
          bregent Most Valuable Participant
          Enable error reporting on your server to see details. Ask your host if you don't know how. Also be sure friendly error messages is disabled in your browser.
          • 2. Re: Recordsert not working using the GET method
            awstam
            try this
            Dim rsAssets
            Dim  rsAssets_cmd
            rsAssets_cmd.CommandText = "SELECT * FROM  dbo.assets WHERE '"&request.querystring("type")&"' = '"&request.querystring("number")&"'"
            im thinking it has to do with either there being a blank value passed... or.. the "content type" is wrong
