0 Replies Latest reply on Jan 21, 2008 4:06 AM by SharedDynamics
    BUG - Installing Flex SDK with Sonic Wall VPN adapter
    SharedDynamics
      I tested the following scenario on 2 different laptops each connected to a clients tunnel using Sonic Wall's VPN client.
      Laptop 1 - Windows XP Professional running ColdFusion 8 developer, IIS 6 and Sonic Wall VPN actively connected
      Laptop 2 - Windows Vista Home Pro running ColdFusion 8 developer, IIS 7 and Sonic Wall VPN actively connected
      I install Flex SDK in the following location c:\program files\flex sdk
      I install Flex WEB-INF files in the following location c:\inetpub\wwwroot\WEB-INF
      Reboot
      I do exactly the same on each laptop. BTW the laptops have the same software installed as laptop 2 is a Ghost of 1 with the Vista Home Pro upgrade
      When attempting to compile and run the samples I get this error:
      An error occured on the server. Server error is: 'Connection refused to host: 223.1.1.128; nested
      exception is: java.net.ConnectException: Connection timed out: connect'
      I remove the SDK and disable the VPN and reinstall the SDK, reboot and the sames (the first 3) run without issue.
