1 Reply Latest reply on Aug 29, 2007 1:45 PM by asm0d
    Presenter's Quiz Question Text
    Level 7
      The choices rendered in a Presenter quiz are in textboxes which I'd like to
      make wider.
      If I ungroup the choice, it breaks the question. If I widen the textbox
      without ungrouping, the radio button stretches into an oval.
      Is there a method to do what I need?
      KC
        • 1. Re: Presenter's Quiz Question Text
          asm0d Level 1
          Yes, but only if you're willing to give up some of the LMS functionality of the Breeze server:
          (1) Write your quiz like always.
          (2) After the quiz wizard finishes, go back into the slides with questions you want to modify, and delete the text from the answers (right click on the text box to text-edit, and use the backspace key).
          (3) Now you have a bunch of radio buttons grouped with empty text boxes. You can put in new text boxes with your answer text on top of them, aligning the radio buttons to them however you want.
          While Breeze will still score the test for you, when you try to call up grades by answers (or a similar report) the answers are, of course, blank. Not a problem if all you're looking for is their grade, or which problem they got wrong.
          v/r
          Marc B
