1 Reply Latest reply on May 5, 2010 4:08 AM by Emanuele Radaelli
    [JS - CS4] Table recompose...
    Emanuele Radaelli Level 1
      I import a table in ID within XML structure using a JavaScript.
      I expect the table to flow from its starting point (in a text frame) through the following empty text frames but this doesn't happen.
      The table seems to ignore the existing text frames (correctly connected) and add other text frames at the end of the document (smart text reflow is enabled...) only when the script is over.
      I tried using document.recompose() function to force this operation when the script is running but it doesn't work.
      Is it a bug or something?
