2 Replies Latest reply on May 4, 2010 8:06 PM by lizard81288
    how do you put videos in?
    lizard81288
      I downloaded some FLVs and used the FLV video option, but when I checked it on an FTP (chnaged it to http to preview it), nothing but a big white line where the video is supposed to be. Which I can assume, it’s because its not supported in newer browsers, anyway since I Have all these FLVs, and the flash video IIRC doesn’t play them, is there another why to use the FLVs? (I’m using CS4)
        • 1. Re: how do you put videos in?
          1) Put FLV files into your local site folder.  I typically put mine into a MEDIA folder.
          2) In DW > Insert Media > Flash Video > Progressive Download.
          3) Browse to the Folder/FLV file in your local site.
          4) Choose a player skin and any other parameters.  When done, hit OK.
          5) Upload the player page, images, SWF, Scripts folder and FLVs to your web server.
          If it doesn't play as expected,
          Post a URL to your test page.
          Contact your host to confirm that FLV and SWF MIME-types are enabled on your server.
          Nancy O.
          Alt-Web Design & Publishing
          Web | Graphics | Print | Media  Specialists
          http://alt-web.com/
          http://twitter.com/altweb
          http://alt-web.blogspot.com
          • 2. Re: how do you put videos in?
            lizard81288 Level 1
            here is my code. do i need to change any of it when i upload it?
            <object classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" width="422" height="351" id="FLVPlayer">
                    <param name="movie" value="FLVPlayer_Progressive.swf" />
                    <param name="quality" value="high" />
                    <param name="wmode" value="opaque" />
                    <param name="scale" value="noscale" />
                    <param name="salign" value="lt" />
                    <param name="FlashVars" value="&amp;MM_ComponentVersion=1&amp;skinName=Halo_Skin_3&amp;streamName=../../assets/mo vies/Bootfighter_Windom_XP_sp-2&amp;autoPlay=false&amp;autoRewind=true" />
                    <param name="swfversion" value="8,0,0,0" />
                    <!-- This param tag prompts users with Flash Player 6.0 r65 and higher to download the latest version of Flash Player. Delete it if you don’t want users to see the prompt. -->
                    <param name="expressinstall" value="../../../Scripts/expressInstall.swf" />
                    <!-- Next object tag is for non-IE browsers. So hide it from IE using IECC. -->
                    <!--[if !IE]>-->
                    <object type="application/x-shockwave-flash" data="FLVPlayer_Progressive.swf" width="422" height="351">
                      <!--<![endif]-->
                      <!-- The browser displays the following alternative content for users with Flash Player 6.0 and older. -->
                      <div>
                        <h4>Content on this page requires a newer version of Adobe Flash Player.</h4>
                        <p><a href="http://www.adobe.com/go/getflashplayer"><img src="http://www.adobe.com/images/shared/download_buttons/get_flash_player.gif" alt="Get Adobe Flash player" /></a></p>
                      </div>
                      <!--[if !IE]>-->
                    </object>
                    <!--<![endif]-->
                  </object>
