2 Replies Latest reply on May 4, 2010 10:22 PM by cdub
    Selected index when sorting?
    cdub Level 1
      I have an app that makes modifications to an item in an array collection based on that item being selected in a datagrid. What I mean is that you select the row that you want to modify in the datagrid and then click a button to modify it. I was using the selected index to determine which index to add the mofified item. Here's where I determine which item in the array gets replaced:
                      var theIndex:Number = theGrid.selectedIndex;
                      theCollection.removeItemAt( theIndex );
                      theCollection.addItemAt( { stuff: theStuff }, theIndex );
      Which works great... until you sort the datagrid. Obviously this doesn't work when once sorted, since the indexes are no longer in sync but what do I need to do in order to fix this? Is there a way to determine what the what the index in the array is when you select the row in a datagrid?
        • 1. Re: Selected index when sorting?
          Vikash.kumar29 Level 3
          There are two ways through which you can accomplish this task.
          1.             var theIndex:Number = theGrid.selectedIndex;
                          (theGrid.dataProvider as ArrayCollection).removeItemAt( theIndex );
                          (theGrid.dataProvider as ArrayCollection).addItemAt( { stuff: theStuff }, theIndex );
          Another solution :
          2.             var theIndex:Number = theCollection.getItemIndex(theGrid.selectedItem);
          Hope this helps you.
          If this doesn't solves your problem, then please let me know
          Cheers
          -Vikash
          • 2. Re: Selected index when sorting?
            cdub Level 1
            Thanks!
