2 Replies Latest reply on May 5, 2010 8:23 PM by PankChat
    getting geometric bounds of each textframe of each page
    PankChat
      Hi all,
      I am trying to get the geometric bounds of each text frame of each page on whole document. Below is the snippet of my script. All seems to be fine earlier but as soon as I did some changes (and why I did) it seems I cannot iterate frames page by page and it stricts to 1st page instead of going on each page. Can anybody tell me what could possibly wrong:
      // Error here var top_Bound = Text_FRAME.geometricBounds[0];
      var myTotalPage = myDoc.pages.length;
      //alert("Total Pages in current document is " +myTotalPage);
      //var pageItems = myDoc.pages[k].allPageItems;
      //alert ("All Page Items is "+ pageItems)
      for (var i=0;i<=myTotalPage;i++)
      var totalTextFrames = myDoc.pages[i].textFrames.length;
      //alert ("Total Text Frames on page are "+ totalTextFrames)
      for (var t=0;t<=totalTextFrames;t++)
      var Text_FRAME = myDoc.pages[i].textFrames[t];
      //getting error here
      var left_Bound = Text_FRAME.geometricBounds[1];
      var bottom_Bound = Text_FRAME.geometricBounds[2];
      var right_Bound = Text_FRAME.geometricBounds[3];
      //alert ("My Top Bound is " +top_Bound);
      //alert ("My left Bound is " +left_Bound);
      //alert ("My Bottom Bound is " +bottom_Bound);
      //alert ("My right Bound is " +right_Bound);
        • 1. Re: getting geometric bounds of each textframe of each page
          Techi Panda Level 2
          Hi Pank this will do your work
          myDoc= app.activeDocument;
          var myTotalPage = myDoc.pages;
          for (var i=0;i<myTotalPage.length;i++)
          var totalTextFrames = myDoc.pages[i].textFrames;
          for (var t=totalTextFrames.length-1; t>=0;t--)
          app.selection=myDoc.pages[i].textFrames[t];
          • 2. Re: getting geometric bounds of each textframe of each page
            PankChat Level 1
            Thanks Arul.
            Any Ideas you can share.
            I think I am stuck in my script. All I am trying to do
            is to find out the position of the textframes on each page and cases are :
            1. If any of the text frame lies at the bottom (ideally at the page end) I
            need to insert some text (marker) at the end of the story of text frame
            with label "sections" (which is actually is my main non-floating frame).
            2. If there is no text frame apart from the "sections" or frames are at
            the bottom of page end insert something else at the end of story of
            "sections" text frame.
            well in short I need to add text at the end of the "sections" TF on each
            page while looking at the positions of other (floats) frame. I am just
            worried whether I did it write or should re-write my whole code:I am using
            two scripts for this one which splits the story of pages (ideally
            "sections" Threaded textframe) and another one is looks something like
            below. I am stuck in comparing the Geometric bounds of frames with
            "sections" one and I think something I've to do with my loops. Hope I make
            myself clear.
            Below is snippet what it looks like:
            if(app.documents.count==0)
            alert ("Please open a document for PageBreak");
            else
                    var myDoc=app.activeDocument;
            for (var i=0; i<=myTotalPage-1; i++)
            alert ("Total Text Frames on page " +myDoc.pages[i].name " are "
            totalTextFrames)
            for (var t=0;t<=totalTextFrames-1;t++)
                                            var Text_FRAME =
            //                              alert ("Text Frame is "+Text_FRAME);
            // Is actually
                                    if (Text_FRAME.label!="sections")
                                                            alert ("Not sections")
                                                            var bottom_Bound_float =
                                                            var right_Bound_float =
                    //                                      alert ("My right Bound of
            Not Sections is " +right_Bound);
                    //                                      alert ("My bottom Bound of
            Not Sections is " +bottom_Bound);
                //                                  alert ("My Geometric bounds are "
            +Text_FRAME.geometricBounds);
            else
            //                      var frame_id = Text_FRAME.id;
            alert ("My Frame id is " +frame_id);
            if(bottom_Bound_float==bottom_Bound && right_Bound_float==right_Bound)
            alert("My Bottom Bound Float is "+bottom_Bound_float);
            alert("My Bottom Bound sec is "+bottom_Bound);
            //Insert some marker
            //else some thing else
