5 Replies Latest reply on May 7, 2010 6:11 AM by Chris Callaghan
    How do I convert a string, and use a string as a property?
    Chris Callaghan Level 2
      I have an array in the following format:
      {ownsCar: 'true', ownsBike: 'true', ownsHouse: 'true'}
      {ownsCar: 'false', ownsBike: 'true', ownsHouse: 'true'}
      {ownsCar: 'true', ownsBike: 'false', ownsHouse: 'true'}
      etc ............
      And I need to test against each item e.g.
      if...
      myDataGrid[myItem].ownsCar == Object(myCheckbox).label
      ... then
      if...
      myDataGrid[myItem].ownsBike == Object(myCheckbox).label
      ... then
      if...
      myDataGrid[myItem].ownsHouse == Object(myCheckbox).label
      ... then
      But I need to build my application where the property (e.g. "ownsCar", "ownsBike", "ownsHouse") is a variable such as:
      if...
      myDataGrid[myItem].myProperty == Object(myCheckbox).label
      ... then
      I would like to loop through my Array, counting the number of items, and then use each item as a property.
      How would I convert the string (e.g. "ownsCar") into a property "myProperty" ???
      Many thanks in advance
      Chris
