1 Reply Latest reply on May 5, 2010 5:06 AM by David_F57
    How to Dynamically Display Different ViewStack component without using State?
    Gene Qian Level 1
      I have a type column in a datagrid record, when type = A, I want to display ViewStack A, when type = B, I want to display ViewStack B, any body can give me some clues? sample code is best. Thanks a lot. BTW, I don't want to use state to control them, as both ViewStacks are already within the same application state.
        • 1. Re: How to Dynamically Display Different ViewStack component without using State?
          David_F57 Level 5
          hi,
          you can try something like this.....
          David.
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" minWidth="955" minHeight="600">
          <mx:Script>
          <![CDATA[
          import mx.collections.ArrayCollection;
          import mx.events.ListEvent;
          [Bindable] private var arr:ArrayCollection = new ArrayCollection([
          {info:"record 1", type:"A"},
          {info:"record 2", type:"B"},
          {info:"record 3", type:"A"},
          {info:"record 4", type:"B"}
          protected function dg_changeHandler(event:ListEvent):void
          if (arr[dg.selectedIndex].type=="A") tn1.visible = true else tn1.visible = false;
          tn2.visible = !tn1.visible;
          </mx:Script>
          <mx:DataGrid id="dg" x="279" y="239" dataProvider="{arr}" change="dg_changeHandler(event)">
          <mx:columns>
          <mx:DataGridColumn headerText="Info" dataField="info"/>
          <mx:DataGridColumn headerText="Type" dataField="type"/>
          </mx:columns>
          </mx:DataGrid>
          <mx:TabNavigator x="279" y="408" width="200" height="200" id="tn1">
          <mx:Canvas label="Tab 1" width="100%" height="100%">
          </mx:Canvas>
          </mx:TabNavigator>
          <mx:TabNavigator x="507" y="408" width="200" height="200" id="tn2">
          </mx:Canvas>
          </mx:TabNavigator>
          </mx:Application>
