3 Replies Latest reply on May 6, 2010 9:06 AM by CannotCompute
    Problems with Element.depth and Element.x/Element.y
    CannotCompute
      Basically my issue is this --
      I wanted to use depth as a tool to bring something to the front -- which it does properly.
      But then if I drag that element around on the screen, and checks its x and y values, the elements x and y do not change, but the element will move on the screen without any problems.
      ** A side note -- I can manual set the x and y values of the element and it will move on the screen at any depth level I set.**
      If I drag the same element, but keep the depth at a default of 0, x and y properties change to represent the element's corresponding location with a problem.
      I am not saying it is a bug, but maybe I don't quite understand how to use the depth property properly.
      If someone could point me in the right direction that would be great.
      Thanks in Advance!
