3. Re: Gradient fill is not smooth
Wade_Zimmerman May 5, 2010 9:02 AM (in response to avpromedia)Well… I do not know how to evaluate this…performing an unsharp mask on a screenshot is kind of puzzling?
But I clearly cannot be of help to you.
4. Re: Gradient fill is not smooth
Jacob Bugge May 5, 2010 9:17 AM (in response to avpromedia)av,
The question is whether this is a matter of screen representation only, or real banding.
What happens if you Save As PDF (with the highest possible File Compatibility) and view it in Acrobat/Reader?
5. Re: Gradient fill is not smooth
Mylenium May 5, 2010 9:24 AM (in response to avpromedia)Check the document color mode and color profile settings, both on the doc and for proofing on the monitor. If the gradient is quantized, then clearly AI thinks it is necessary to avoid out of gamut issues of some sort. Otehr than that - yeah, probably a screen issue. Also keep in mind, that AI does not recalculate stuff just when zooming. This may actually be what happens in program X, so it would actually be giving you an incorrect representation of the final result...
Mylenium
6. Re: Gradient fill is not smooth
JETalmage-71mYin May 5, 2010 9:43 AM (in response to avpromedia)function(){return A.apply(null,[this].concat($A(arguments)))}
function(){return A.apply(null,[this].concat($A(arguments)))}To be sure, copy the image into photoshop and perform an unsharp mask. Set the amount to max and keep increaseing the radius. Eventually you will see many vertical stripes...??
Well, of course you would. That's what Unsharp Mask does: increases ("sharpens") the difference in color values between adjacent pixels which its algorithm considers "different." So given a linear gradient, when would you not expect Unsharp Mask to result in visible bands at high settings?
What is "the other vector program"? (No one is going to ban you from stating the name of a non-Adobe software.) What platform are you on?
JET
