0 Replies Latest reply on May 5, 2010 11:52 PM by MrRikard
    Generated code from wsdl with Inheritance
    MrRikard
      We are running webservices and are generating code in flashbuilder from the wsdl for these webservices.
      We had a problem with flexbuilder 3 which is described here:
      http://forums.adobe.com/message/2767735#2767735
      We were recomended to upgrade to flashbuilder 4 which was gonna solve our problem, so we did.
      We generated new code in flashbuilder and everything works fine until we added inheritance to the services:
      Our xsd looks like this (stripped), its very simple:
      xsd:element name="TSLCQueueResponse">
           <xsd:complexType>
                <xsd:sequence>
                     <xsd:element name="QueueResponse" type="tslc:QueueResponses" minOccurs="0" maxOccurs="unbounded" />
                </xsd:sequence>
           </xsd:complexType>
      </xsd:element>
      <xsd:complexType name="QueueResponses">
           <xsd:sequence>
                <xsd:element name="FXEntity" type="tslc:FXEntity" nillable="true" minOccurs="0" maxOccurs="unbounded"
             </xsd:sequence>
      </xsd:complexType>
      <xsd:complexType name="FXEntity">
           <xsd:sequence>
                <xsd:element name="ReqId" type="xsd:string" />
                <xsd:element name="DealType" type="xsd:string"/>
           </xsd:sequence>
      </xsd:complexType>
      <xsd:complexType name="Quote">
           <xsd:complexContent>
                <xsd:extension base="tslc:FXEntity">
                     <xsd:sequence>
                          <xsd:element name="TimeToLive" type="xsd:string" minOccurs="0"/>
                     </xsd:sequence>
                </xsd:extension>
           </xsd:complexContent>
      </xsd:complexType>
      The code generated from the wsdl based on this xsd didnt generate a class for "Quote".
      We tried to add a dummy which "reference" to a Quote, like this
      <xsd:element name="DummyResponse">
           <xsd:complexType>
                <xsd:sequence>
                     <xsd:element name="Quote" type="tslc:Quote" nillable="true" minOccurs="0" maxOccurs="unbounded"/
                </xsd:sequence>
           </xsd:complexType>
      </xsd:element>
      The code genereated from this xsd (wsdl) now generates a class for "Quote".
      The Quote class does not extend the generated class FXEntity as expected. The Quote has all variables from FXEntity though. But i need to extend FXEntity. I cant be asked to modify it myself after every time I regenerate the code.
      Doesnt inheritance work properly for flashbuilder generated code or have i missed something ?
      Thankful for all kind of help with this.
      /MR
