5 Replies Latest reply on May 6, 2010 6:57 AM by CraigOverman
    Layers to Files
    CraigOverman
      I'm looking for altered versions of the 'Layers to Files' script that will export jpegs that are named by group & layer names.
      For example, if I have a group/layer structure like this:
      ('>' are groups and '*' are layers)
      > Phones
            > Blackberry
                  * Storm
            > Apple
                  * iPhone
            > HTC
                  * NexusOne
      Is there a way to export the layers to files so that the files are named something similar to:
      I have a very large psd with many nested groups and layers that need to be exported individually with a very specific naming scheme. Is there a script anywhere that will achieve this?  Or is there a work-around that I've not been able to find? I've looked everywhere and have only been able to find script alterations that remove the group/layer numbers.
      Any help is appreciated.
        • 1. Re: Layers to Files
          jugenjury Level 2
          I have some code that is close to what you would be needing, though it's used for a different purpose. I could adapt it, I guess.
          Are your document layers all NORMAL layers? Are there any adjustment layers? Smart Objects?
          • 2. Re: Layers to Files
            Paul Riggott Level 6
            This should be close....
            #target Photoshop
            main();
            function main(){
            if(!documents.length) return;
            selectAllLayers();
            var Lrs =  getSelectedLayersIdx();
            var Path = decodeURI(activeDocument.path);
            for(var a in Lrs){
               makeActiveByIndex( Lrs[a], false );
                if(app.activeDocument.activeLayer.kind == LayerKind.NORMAL){
                    var APPN = app.activeDocument.activeLayer.parent.parent.name
                    var APN = app.activeDocument.activeLayer.parent.name
                    var AL = app.activeDocument.activeLayer.name;
                    var Name = APPN + "_" +APN+"_"+AL+".jpg";
                    dupLayers(Name);
                    var saveFile = File(Path +"/" + Name);
                    SaveJPEG(saveFile, 12);
                    app.activeDocument.close(SaveOptions.DONOTSAVECHANGES);
            function selectAllLayers(){
               var desc = new ActionDescriptor();
                    var ref = new ActionReference();
                    ref.putEnumerated( charIDToTypeID( "Lyr " ), charIDToTypeID( "Ordn" ), charIDToTypeID( "Trgt" ) );
                desc.putReference( charIDToTypeID( "null" ), ref );
            executeAction( stringIDToTypeID( "selectAllLayers" ), desc, DialogModes.NO );
            function getSelectedLayersIdx(){
               var selectedLayers = new Array;
               ref.putEnumerated( charIDToTypeID("Dcmn"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
               var desc = executeActionGet(ref);
               if( desc.hasKey( stringIDToTypeID( 'targetLayers' ) ) ){
                  desc = desc.getList( stringIDToTypeID( 'targetLayers' ));
                  var c = desc.count
                  var selectedLayers = new Array();
                  for(var i=0;i<c;i++){
                     selectedLayers.push(  desc.getReference( i ).getIndex() );
               }else{
                  try{
                  activeDocument.backgroundLayer;
                  var mod = 1;
               }catch(e){
                  var mod = 0
                  ref.putProperty( charIDToTypeID("Prpr") , charIDToTypeID( "ItmI" ));
                  ref.putEnumerated( charIDToTypeID("Lyr "), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
                  selectedLayers.push( executeActionGet(ref).getInteger(charIDToTypeID( "ItmI" ))-mod);
               return selectedLayers;
            function makeActiveByIndex( idx, forceVisible ){
                 try{
                      ref.putIndex(charIDToTypeID( "Lyr " ), idx)
                      desc.putBoolean( charIDToTypeID( "MkVs" ), forceVisible );
                      executeAction( charIDToTypeID( "slct" ), desc, DialogModes.NO );
                 }catch(e){ return -1;}
            function dupLayers(NewDocName) {
                var desc143 = new ActionDescriptor();
                    var ref73 = new ActionReference();
                    ref73.putClass( charIDToTypeID('Dcmn') );
                desc143.putReference( charIDToTypeID('null'), ref73 );
                desc143.putString( charIDToTypeID('Nm  '), NewDocName );
                    var ref74 = new ActionReference();
                    ref74.putEnumerated( charIDToTypeID('Lyr '), charIDToTypeID('Ordn'), charIDToTypeID('Trgt') );
                desc143.putReference( charIDToTypeID('Usng'), ref74 );
                executeAction( charIDToTypeID('Mk  '), desc143, DialogModes.NO );
            function SaveJPEG(saveFile, jpegQuality){
            jpgSaveOptions = new JPEGSaveOptions();
            jpgSaveOptions.embedColorProfile = true;
            jpgSaveOptions.formatOptions = FormatOptions.STANDARDBASELINE;
            jpgSaveOptions.matte = MatteType.NONE;
            jpgSaveOptions.quality = jpegQuality;
            activeDocument.saveAs(saveFile, jpgSaveOptions, true,Extension.LOWERCASE);
            • 3. Re: Layers to Files
              Michael L Hale Level 5
              I think that I have modified 'Export Layers to Files' to meet your request. Because it is such a long script I have posted the new version here http://ps-scripts.com/bb/viewtopic.php?p=15029
              • 4. Re: Layers to Files
                CraigOverman Level 1
                They are all normal layers.  No effects or anything fancy at all.
                • 5. Re: Layers to Files
                  Thank you VERY much!!  Your code worked, mostly.  It kept throwing me weird errors, so I just commented out those lines. (They didn't seem to add anything to the end result I was looking for, anyway)  I also tweaked the file name output to be specifically what I need.
                  I really appreciate the help.
