6 Replies Latest reply on May 6, 2010 9:36 AM by aroy@eagle.org
    Urgent - Commenting tool bar doesn't appear
    aroy@eagle.org
           I am using a below mentioned code to render a form and apply usage rights - setReCommenting(true). But generated PDF form does not show commenting tool bar
      Document properties shows commenting "Not Allowed".
      We are using Adobe LC ES2, Adobe Reader 7 & 9  and Designer 7.1 or 9
      try{
              FormsServiceClient fm=new FormsServiceClient(scfFactory);
              PDFFormRenderSpec pdfFormRenderSpec                 = new PDFFormRenderSpec();
              pdfFormRenderSpec.setCacheEnabled(new Boolean(false));
              pdfFormRenderSpec.setRenderAtClient(RenderAtClient.Yes);
              pdfFormRenderSpec.setAcrobatVersion(AcrobatVersion.Acrobat_7_0_5 );
              //Set usage-rights run-time options
              ReaderExtensionSpec reOptions                         = new ReaderExtensionSpec();
              reOptions.setReCredentialAlias("READER EXTENSIONS");
              reOptions.setReCredentialPassword("jC98zZ2Kg8");
              reOptions.setReCommenting(true);
              reOptions.setReFillIn(true);
              reOptions.setReFormFieldMod(true);
              reOptions.setReCreatePages(true);
              reOptions.setReEmbeddedAttachments(true);
              reOptions.setReReaderMessage("You may fill in forms");
              URLSpec    uriValues                         = new URLSpec();
              uriValues.setApplicationWebRoot("http://talamdt02:7778/o2k");
              uriValues.setContentRootURI("http://talamdt02:7778/o2k/jsp/");
              uriValues.setTargetURL("http://talamdt02:7778/o2k/jsp/");
              Document inDoc=new Document(new File("C:/Temp/CertificateData.xml"),true);
              FormsResult frs=fm.renderPDFFormWithUsageRights("ISM-SMC.xdp", inDoc, pdfFormRenderSpec, reOptions, uriValues);
              Document document=frs.getOutputContent();
              document.copyToFile(new File("C:/Temp/forserverTest.pdf"));
              }catch (Exception e) {
              e.printStackTrace();
