9 Replies Latest reply on Mar 13, 2011 4:06 AM by Maria Pieroszkiewicz
    Upload files
    athiroy Level 1
      hi
      i want to upload file using flex 4. if any idea pls suggest me.
      regards
      athi
        • 1. Re: Upload files
          Matt Le Fevre Level 4
          you'll have to use a FileReference()
          http://livedocs.adobe.com/flex/3/langref/flash/net/FileReference.html
          unless you want to upload multiple files at a time, in which case you'll need to use a FileReferenceList()
          and you'll need a server-side script to handle the uploaded data.
          • 2. Re: Upload files
            athiroy Level 1
            hi
                  i folowed this url http://livedocs.adobe.com/flex/3/langref/flash/net/FileReference.html
              but i don't know why the cfm is in the following line
              uploadURL.url = "http://www.[yourDomain].com/yourUploadHandlerScript.cfm";
            could u explain me
            regards
            athi
            • 3. Re: Upload files
              It's a coldfusion script, it handles the POST'd file data from the application.
              Flash player cannot directly upload files, so it just references file information to a script, which then handles the uploading.
              your upload script doesn't necessarily have to be coldfusion, it could be php or even asp i believe.
              an example of PHP handling POST'd file information can be found here
              http://www.w3schools.com/PHP/php_file_upload.asp
              • 4. Re: Upload files
                athiroy Level 1
                hi
                thank u for your response.
                i don't know php or asp. but i know java.
                i developed my project using flex and java.
                could u suggest me to handle upload a file in flex with java.
                regards
                athi
                • 5. Re: Upload files
                  I imagine it would be exactly the same type of concept. I don't know enough java to give you an exact coding example, but luckily a 2 second search on google for
                  "uploading files flex java"
                  returned a pretty promising article titled "Uploading a file with Flex and Java"
                  http://www.adobe.com/devnet/flex/articles/file_upload.html
                  i'd recommend starting there
                  • 6. Re: Upload files
                    athiroy Level 1
                    hi
                    thank u for your help
                    regards
                    athi
                    • 7. Re: Upload files
                      Karl_Sigiscar_1971 Level 3
                      One of the JSP implementations for file upload:
                      <%@page import="org.apache.commons.fileupload.FileItemFactory"%>
                      <%@page import="org.apache.commons.fileupload.disk.DiskFileItemFactory"%>
                      <%@page import="org.apache.commons.fileupload.servlet.ServletFileUpload"%>
                      <%@page import="org.apache.commons.fileupload.FileItem"%>
                      <%@page import="java.util.List"%>
                      <%@page import="java.util.Iterator"%>
                      <%@page import="java.io.File"%>
                      <%@page import="java.io.FileOutputStream"%>
                      <%@page import="java.io.InputStream"%>
                      // Create a factory for disk-based file items
                      FileItemFactory factory = new DiskFileItemFactory();
                      // Create a new file upload handler
                      ServletFileUpload upload = new ServletFileUpload(factory);
                      // Parse the request
                      List /* FileItem */ items = upload.parseRequest(request);
                      // Process the uploaded items
                      Iterator iter = items.iterator();
                      final String BASE_PATH = "C:/Development/apache-tomcat-6.0.20/webapps/fileupload/uploads/";
                      String path = "temp/";
                      while (iter.hasNext()) {
                         FileItem item = (FileItem) iter.next();
                         //handling a normal form-field
                         if (item.isFormField()) {
                            System.out.println("Got a form field");
                            String name = item.getFieldName();
                            String value = item.getString();
                            System.out.println("Name:"+name+",Value:"+value);
                            if(name == "path")
                                path = value;
                         } else {//handling file loads
                            System.out.println("Not form field");
                            String fieldName = item.getFieldName();
                            String fileName = item.getName();
                            String contentType = item.getContentType();
                            boolean isInMemory = item.isInMemory();
                            long sizeInBytes = item.getSize();
                            System.out.println("Field Name:"+fieldName+",File Name:"+fileName);
                            System.out.println("Content Type:"+contentType+",Is In Memory:"+isInMemory+",Size:"+sizeInBytes);
                            byte[] data = item.get();
                            FileOutputStream fileOutSt = new FileOutputStream(BASE_PATH + path + fileName);
                            fileOutSt.write(data);
                            fileOutSt.close();
                            System.out.println(BASE_PATH + path + fileName);
                      • 8. Re: Upload files
                        mfriasv Level 1
                        I am looking the same but in ASP. I have my FileReference.upload but I need some directions to write a script to upload the file in the server in ASP (vb).
                        I have this. Can anyone tell me if that would work? When I execute the flex app I always get the 2038 i/o error.
                        Public Function importFile(ByVal f As Byte(), ByVal fileName As String) As String
                                Try
                                    Dim ms As New MemoryStream(f)
                                    Dim fs As New FileStream(System.Web.Hosting.HostingEnvironment.MapPath("C:\temp") & fileName, FileMode.Create)
                                    ms.WriteTo(fs)
                                    ms.Close()
                                    fs.Close()
                                    fs.Dispose()
                                    Return "ok"
                                Catch ex As Exception
                                    Return ex.Message.ToString()
                                End Try
                            End Function
                        • 9. Re: Upload files
                          I need in my application.
                          How to use ColdFusion and Flex upload pictures to the server
                          I don't know so well the CF to deal with it.
