1 Reply Latest reply on May 25, 2010 4:39 AM by MNishad
    how do i set spark list selected item's color??
    cyber0897 Level 1
      hey guys... so got a little problem... i have a spark list which gets populated from a array collection that looks likda like this
      [0] = "name1"
      [1] = "name 2"
      [2] = "name 3"
      when i click on say "name 1" i  need the color of "name 1" to change to say red...
      and when i click on another item i need that color to stay... red on "name 1"...
      oh and... i need to do the color change in actionscript rather than the mxml file...
      any ideas???
        • 1. Re: how do i set spark list selected item's color??
          MNishad
          I'm not sure if this is exactly what you are looking for. What I did was created an itemRender for the list and assigned it like so
          <s:List dataProvider="{ listDataProvider}" itemRenderer="listItemRenderer"/>
          And the listItemRenderer will look some
          //Code Begins
          <s:ItemRenderer xmlns:fx="http://ns.adobe.com/mxml/2009"
                                    xmlns:mx="library://ns.adobe.com/flex/mx"
                                    focusEnabled="true" >
              <fx:Script>
                  <![CDATA[
                      var clicked:Boolean=true;
                      protected function clickHandler(event:MouseEvent):void
                              clicked?labelRender.setStyle("color","0x00FF00"):labelRender.setStyle("color","0xFF0000") ;
                              clicked=!clicked;
              </fx:Script>
              <s:Label  id="labelRender" text="{data}" color="0xFF0000" click="clickHandler(event)"/>
          </s:ItemRenderer>
          //Code Ends
          In the above example the colour toggles on each click. So, you can apply anything. assume you have a property called color in your array collection, you can access it as data.color and then set the text to that color when it is clicked. I hope this helps. Do write back if you have any issues.
          Nishad
