I have a login system that works great when the application, userloginform, forceuserlogin, etc are in the same folder.
I would like to have the main page of a website, say sample.com have a login form. If the login is correct, that it redirects to
a subdomain, such as sample.com/members.
This is my current login form. I am assuming that the action needs to change, but I have no idea how to pass the username and password to the sample.com/members/forceuserlogin.cfm to log the user in.
Any thoughts? I am a beginner to CF, so any help would be MUCH appreciated. Thanks!!
<table width="239">
<cfform name="LoginForm" format="html" timeout="10000" method="POST" preservedata="Yes" action="#CGI.SCRIPT_NAME#" >
<tr>
<td width="26" rowspan="4"></td>
</tr>
<tr>
<td width="117"><p>Username</p></td>
<td width="80"><cfinput name="username" type="text" width="75"></td>
</tr>
<tr>
<td width="117"><p>Password</p></td>
<td><cfinput name="password" type="password" width="75"></td>
</tr>
<tr>
<td colspan="2" align="right"><cfinput name="Submit" type="Submit" value="Login" ></td>
</tr>
</cfform>
Under your CFForm tag the Action attributes should be calling the action page that process the UserID and Password.
From the action page you should have a query to verify username and Password something like this:
<CFQUERY name="UseridQuery" datasource="UserTable">
SELECT * FROM User
Where username='#Form.username#'
and Password='#Form.Password#'
</CFQUERY>
You then should have an if statement to check to see if the query return a record is this:
<CFIF UseridQuery.RecordCount is 0>
This section you do error checking to have them enter the correct username and Password.
<CFELSE>
Here is where you will let the user pass and display the page you want the users to see by using <CFLOCATION url="display.cfm">
</CFIF>
Hope this help!!
