2 Replies Latest reply on May 6, 2010 3:00 AM by Sanjay_Nathan
    Flash Builder 4 bug ?
    Sanjay_Nathan
                        xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
           <fx:Script><![CDATA[
           private function init():void {
                button3.addEventListener(MouseEvent.CLICK, handleClick);
           private function handleClick(event:MouseEvent):void {
                if (event.target == button3) {
                     label.text += 'Buton 3 Clicked\n';
           ]]></fx:Script>
           <s:VGroup width="100%">
                      <s:Button id="button3" label="Button 3"/>
                <s:Label id="label"/>
           </s:VGroup>
      </s:Application>
      The above code does not seem to work.
        • 1. Re: Flash Builder 4 bug ?
          cyber0897 Level 1
          you have a couple of problems with your code... you dont call the init function anywhere, so the addeventlistener never gets initialized...
          so you can either add init to the creation complete or initialize in the application tag
          and also, when you do event.target, you have to do event.target.id == "button3"
          id is a string...
          the modifications are as follows...
                            xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" creationComplete="init();">
               <fx:Declarations>
                    <!-- Place non-visual elements (e.g., services, value objects) here -->
               </fx:Declarations>
                         if (event.target.id == "button3") {
               ]]></fx:Script>
               </s:VGroup>
          </s:Application>
          • 2. Re: Flash Builder 4 bug ?
            Sanjay_Nathan Level 1
            The
            is what I needed.
            But I did not need:
            My code now works fine, thank you.
