1 Reply Latest reply on May 6, 2010 1:48 AM by Ferfibon
    We have two questions about HTTPS and ActionScript 3.0 in FLEX 3.0
    Ferfibon
      Hello
      I am a newcomer in using Adobe Forum.
      1) Are the classes in Actionscript 3.0 for sending DIGEST AUTHENTICAION requests? We have the following situation:
      We want to send TR064 requests (HTTPS) using SOAP to a server. In order to access the protected resources, a username and password need to be provided. In our case this is done with the DIGEST AUTHENTICATION.  If we use the URLLoader class, we can drop use of the command "load (request), since there is Handshaking in the DIGEST AUTHENTICATION,
      Then there appears a box requesting Username and Password. The Resources are accessible only after this query is satisfied.  We want to prevent the appearance of precisely this pop up box by imbedding Username and Password in the TR064 HTTPS Request.
      Is there a command such as the SetCredentials ("username", "passwd") or an alternative solution we could use with Actionscript 3.0?
      2) Similar to the solution for this with Trustmanager in Java, is there something similar we can use to avoid browser requests occuring with HTTPS requests after the installation of a certificate?
      Ferfibon
        • 1. Re: We have two questions about HTTPS and ActionScript 3.0 in FLEX 3.0 ?
          Ferfibon Level 1
          Hello
