2 Replies Latest reply on Jun 4, 2010 3:14 AM by BuckyTheKatt
    Flash CS5: unable to drag component to stage or library
    BuckyTheKatt
      We are the developers of a complex Flash component (http://www.openspace-engine.com) which worked without issues on Flash CS3 and CS4. Now, in Flash CS5 (both Mac and Windows versions) we have found a couple of problems at author-time, so any help would be appreciated.
      -1-
      After installing the mxp file containing the component, when trying to drag the component from the Components panel to the stage, or to the Library panel, it doesn't work. There's no way to import the component!
      -2-
      If we open an existing FLA (created with Flash CS4), the component doesn't show correctly at author-time: you only get a black frame, instead of the expected result (it should show a white background with a logo in the middle). When compiling, everything works fine.
      Any ideas? Thank you.
