1. Re: copy filename to iptc description
Paul Riggott May 6, 2010 8:26 AM (in response to 1ewis)This should do selected documents...
#target bridge if( BridgeTalk.appName == "bridge" ) { addFileName = MenuElement.create("command", "Add FileName to Description", "at the end of Thumbnail"); } addFileName.onSelect = function () { addFileNameToDescription(); } function addFileNameToDescription(){ var Prefix = "CMS:"; var sels = app.document.selections; for (var i = 0; i < sels.length; i++){ var md = sels[i].synchronousMetadata; md.namespace = "http://purl.org/dc/elements/1.1/"; var Name = decodeURI(sels[i].name).replace(/\.[^\.]+$/, ''); Name = Prefix + Name.replace(/\=/g,':'); md.description = Name; } } -
2. Re: copy filename to iptc description
Paul Riggott May 6, 2010 8:37 AM (in response to Paul Riggott)Yet another version..
#target bridge if( BridgeTalk.appName == "bridge" ) { FileNameToDesc = MenuElement.create("command", "Add FileName to Description", "at the end of Thumbnail"); } FileNameToDesc.onSelect = function () { updateFileName(); } function updateFileName(){ loadXMPLib(); var Prefix = "CMS:"; var sels = app.document.selections; for(var a in sels){ var thumb = new Thumbnail(sels[a]); if(thumb.hasMetadata){ var selectedFile = thumb.spec; var myXmpFile = new XMPFile( selectedFile.fsName, XMPConst.UNKNOWN, XMPConst.OPEN_FOR_UPDATE); var myXmp = myXmpFile.getXMP(); var Name = decodeURI(sels[a].name).replace(/\.[^\.]+$/, ''); Name = Prefix + Name.replace(/\=/g,':'); myXmp.deleteProperty(XMPConst.NS_DC, "description"); myXmp.setLocalizedText( XMPConst.NS_DC, "description", null, "x-default",Name ); if (myXmpFile.canPutXMP(myXmp)) { myXmpFile.putXMP(myXmp); myXmpFile.closeFile(XMPConst.CLOSE_UPDATE_SAFELY); } } } unloadXMPLib(); } function loadXMPLib(){ if (ExternalObject.AdobeXMPScript == undefined) { ExternalObject.AdobeXMPScript = new ExternalObject("lib:AdobeXMPScript"); } } function unloadXMPLib(){ if( ExternalObject.AdobeXMPScript ) { try{ ExternalObject.AdobeXMPScript.unload(); ExternalObject.AdobeXMPScript = undefined; }catch (e){ } } } -
3. Re: copy filename to iptc description
1ewis May 6, 2010 9:20 AM (in response to Paul Riggott)Brilliant, thanks Paul!
The first one reported an error, but the second works perfectly.
Lewis
4. Re: copy filename to iptc description
Beth Coller Jun 23, 2011 12:22 PM (in response to Paul Riggott)Hi,
I am looking to do this same thing. I don't want to change anything in the file name, however. Just want to copy the filename to the iptc description. I don't know anything about scripting. Can you tell me in layman's terms what I need to do?
Thanks!
5. Re: copy filename to iptc description
Muppet Mark Jun 23, 2011 1:07 PM (in response to Beth Coller)Beth, I just made you a quick edit to Paul's Script… It should now just put the file name in the IPTC… As is it is with the extension too is that right? The script…
#target bridge if( BridgeTalk.appName == "bridge" ) { FileNameToDesc = MenuElement.create("command", "Add FileName to Description", "at the end of Thumbnail"); }; FileNameToDesc.onSelect = function () { updateFileName(); }; function updateFileName() { loadXMPLib(); var sels = app.document.selections; for ( a in sels ) { var thumb = new Thumbnail( sels[a] ); if ( thumb.hasMetadata ) { var selectedFile = thumb.spec; var myXmpFile = new XMPFile( selectedFile.fsName, XMPConst.UNKNOWN, XMPConst.OPEN_FOR_UPDATE ); var myXmp = myXmpFile.getXMP(); var Name = decodeURI( sels[a].name ); myXmp.deleteProperty( XMPConst.NS_DC, "description" ); myXmp.setLocalizedText( XMPConst.NS_DC, "description", null, "x-default", Name ); if ( myXmpFile.canPutXMP( myXmp ) ) { myXmpFile.putXMP( myXmp ); myXmpFile.closeFile( XMPConst.CLOSE_UPDATE_SAFELY ); } } } unloadXMPLib(); }; function loadXMPLib() { if ( ExternalObject.AdobeXMPScript == undefined ) { ExternalObject.AdobeXMPScript = new ExternalObject( "lib:AdobeXMPScript" ); } }; function unloadXMPLib() { if( ExternalObject.AdobeXMPScript ) { try { ExternalObject.AdobeXMPScript.unload(); ExternalObject.AdobeXMPScript = undefined; } catch (e) { } } };Now to use this there are a couple of things to do.
First you need to find where the Adobe 'ExtendScript Toolkit' app is located on your machine? Im on a mac so its down in 'Utilites' folder. If you open that you can cut and paste the above code. Then save it giving it a name and the file extension '.jsx' you can then press the play/run arrow up at the top menu… In Bridge you select the files that you want to do this too. Then use the control key and pick the bottom option…
6. Re: copy filename to iptc description
Paul Riggott Jun 23, 2011 1:13 PM (in response to Beth Coller)Open ExtendScript Toolkit and paste the following code into the new window.
This utility can be found in the relevant folder:-
PC: C:\Program Files\Adobe\Adobe Utilities
MAC: <hard drive>/Applications/Utilities/Adobe UtilitiesThe script will then be saved to :
Open Bridge
Edit - Preferences - Startup Scripts
At the bottom click the "Reveal Button" this will open the folder where the script should be saved.
Close and restart Bridge.
Accept the new script.
To Use :-
Select your documents
Mouse right mouse click menu and select "Add FileName to Description"
#target bridge if( BridgeTalk.appName == "bridge" ) { FileNameToDesc = MenuElement.create("command", "Add FileName to Description", "at the end of Thumbnail"); } FileNameToDesc.onSelect = function () { updateFileName(); } function updateFileName(){ loadXMPLib(); var sels = app.document.selections; for(var a in sels){ var thumb = new Thumbnail(sels[a]); if(thumb.hasMetadata){ var selectedFile = thumb.spec; var myXmpFile = new XMPFile( selectedFile.fsName, XMPConst.UNKNOWN, XMPConst.OPEN_FOR_UPDATE); var myXmp = myXmpFile.getXMP(); var Name = decodeURI(sels[a].name).replace(/\.[^\.]+$/, ''); myXmp.deleteProperty(XMPConst.NS_DC, "description"); myXmp.setLocalizedText( XMPConst.NS_DC, "description", null, "x-default",Name ); if (myXmpFile.canPutXMP(myXmp)) { myXmpFile.putXMP(myXmp); myXmpFile.closeFile(XMPConst.CLOSE_UPDATE_SAFELY); } } } unloadXMPLib(); } function loadXMPLib(){ if (ExternalObject.AdobeXMPScript == undefined) { ExternalObject.AdobeXMPScript = new ExternalObject("lib:AdobeXMPScript"); } } function unloadXMPLib(){ if( ExternalObject.AdobeXMPScript ) { try{ ExternalObject.AdobeXMPScript.unload(); ExternalObject.AdobeXMPScript = undefined; }catch (e){ } } } -
7. Re: copy filename to iptc description
Muppet Mark Jun 23, 2011 1:23 PM (in response to Paul Riggott)And as if by magic the shopkeeper appeared…
8. Re: copy filename to iptc description
Paul Riggott Jun 23, 2011 1:28 PM (in response to Muppet Mark)Hi Mark, disaster here my wonderful laptop has died and I'm having to use the dreaded ghostly coloured laptop with an apple on it! I get a new laptop tomorrow though
9. Re: copy filename to iptc description
Beth Coller Jun 23, 2011 1:39 PM (in response to Paul Riggott)Hi Paul and Mark,
Thanks so much for you replies. Neither is quite working for me yet. I was able to open extendscript tool. I saved to adobe scripts as that is the default. The files show up in the extend script app but I'm not sure how to get them into Bridge. When I click the reveal button in the start up scripts utility nothing happens
Thanks for your help!!
10. Re: copy filename to iptc description
Paul Riggott Jun 23, 2011 1:47 PM (in response to Beth Coller)When you click the reveal button it should open a new Finder window on a Mac or Explorer window on a PC, I haven't known this to fail before.
11. Re: copy filename to iptc description
Muppet Mark Jun 23, 2011 1:54 PM (in response to Paul Riggott)I knew there had to be some reason behind me beating you to a reply… It's not often I get the chance… although Im getting further in the % I get done before you beat me… You know you secretly loves the Apple… What tempted Eve n all that… If you can't find anything on it just use spotlight… Do you know where that is? Does the new one come with Windoz 7 because that was my idea… And Im not great on ideas… Im now having to run a second monitor on the imac with CS5 bloody palettes eat loads of desktop… ESTK is now on the second monitor so I can see what Im doing wrong…
12. Re: copy filename to iptc description
Beth Coller Jun 23, 2011 2:06 PM (in response to Paul Riggott)I figured it out and it works perfectly!
Thanks again!!!
13. Re: copy filename to iptc description
Paul Riggott Jun 23, 2011 2:31 PM (in response to Beth Coller)Glad it worked for you Beth!
Mark, yes I know where spotlight are, have two of them on the front of my car!
14. Re: copy filename to iptc description
DonJohnston Jun 28, 2011 4:41 AM (in response to Paul Riggott)Hi Paul
I too am an absolute newbie on this topic but it appears to be right up my alley as a solution for automating a lengthy repetitive task I face.
Would it be possible for you to modify and post your script so that it enables the filename in the Bridge window to be copied to the Document Title field in IPTC.
Many thanks
Don
15. Re: copy filename to iptc description
Paul Riggott Jun 28, 2011 5:43 AM (in response to DonJohnston)No problem, here you are...
#target bridge if( BridgeTalk.appName == "bridge" ) { FileNameToDesc = MenuElement.create("command", "Add FileName to Title", "at the end of Thumbnail"); } FileNameToDesc.onSelect = function () { updateFileName(); } function updateFileName(){ loadXMPLib(); var sels = app.document.selections; for(var a in sels){ var thumb = new Thumbnail(sels[a]); if(thumb.hasMetadata){ var selectedFile = thumb.spec; var myXmpFile = new XMPFile( selectedFile.fsName, XMPConst.UNKNOWN, XMPConst.OPEN_FOR_UPDATE); var myXmp = myXmpFile.getXMP(); var Name = decodeURI(sels[a].name).replace(/\.[^\.]+$/, ''); myXmp.deleteProperty(XMPConst.NS_DC, "title"); myXmp.appendArrayItem(XMPConst.NS_DC, "title", Name, 0, XMPConst.ALIAS_TO_ALT_TEXT); myXmp.setQualifier(XMPConst.NS_DC, "title[1]", "http://www.w3.org/XML/1998/namespace", "lang", "x-default"); if (myXmpFile.canPutXMP(myXmp)) { myXmpFile.putXMP(myXmp); myXmpFile.closeFile(XMPConst.CLOSE_UPDATE_SAFELY); } } } unloadXMPLib(); } function loadXMPLib(){ if (ExternalObject.AdobeXMPScript == undefined) { ExternalObject.AdobeXMPScript = new ExternalObject("lib:AdobeXMPScript"); } } function unloadXMPLib(){ if( ExternalObject.AdobeXMPScript ) { try{ ExternalObject.AdobeXMPScript.unload(); ExternalObject.AdobeXMPScript = undefined; }catch (e){ } } } -
16. Re: copy filename to iptc description
DonJohnston Jun 28, 2011 6:47 AM (in response to Paul Riggott)Wow Paul, thanks a ton for sharing. It works great! This saves so much time, and eliminates cut and paste mistakes.
I am very grateful!
Don
17. Re: copy filename to iptc description
Pedro Marques Jul 4, 2011 4:17 AM (in response to Paul Riggott)All scripts activated in bridge script folder are not beeing activated in windows7.
I want this so bad, but I only manage to deal with bridge scripting capabilities from spripting photoshop (BridgeTalk) or from ExtendScript toolkit.
I can't figure what is blocking bridge to manage scripts.
I am a windows7 system administrator.
18. Re: copy filename to iptc description
AndrewUSMC Jul 23, 2012 12:24 PM (in response to Paul Riggott)How do I change the script from Description to Document Title. I've tried a couple of things, name changes and what not, and I can't get it to work for me. Otherwise, the script you provided works great. I just need it to add to the Document Title, not the Description. Thanks for your help.
19. Re: copy filename to iptc description
Paul Riggott Jul 23, 2012 1:41 PM (in response to AndrewUSMC)This copy the filename the the title field..
#target bridge if( BridgeTalk.appName == "bridge" ) { FT = MenuElement.create("command", "Add FileName to Title", "at the end of Tools"); } FT.onSelect = function () { AddFilenameToTitle(); } function AddFilenameToTitle(){ var thumbs = app.document.selections; if(!thumbs.length) return; if (ExternalObject.AdobeXMPScript == undefined) ExternalObject.AdobeXMPScript = new ExternalObject("lib:AdobeXMPScript"); for(var a in thumbs){ var selectedFile = thumbs[a].spec; var Title = decodeURI(selectedFile.name).replace(/\.[^\.]+$/, '') var myXmpFile = new XMPFile( selectedFile.fsName, XMPConst.UNKNOWN, XMPConst.OPEN_FOR_UPDATE); var myXmp = myXmpFile.getXMP(); myXmp.deleteProperty(XMPConst.NS_DC, "title"); myXmp.appendArrayItem(XMPConst.NS_DC, "title", Title, 0, XMPConst.ALIAS_TO_ALT_TEXT); myXmp.setQualifier(XMPConst.NS_DC, "title[1]", "http://www.w3.org/XML/1998/namespace", "lang", "x-default"); if (myXmpFile.canPutXMP(myXmp)) { myXmpFile.putXMP(myXmp); myXmpFile.closeFile(XMPConst.CLOSE_UPDATE_SAFELY); } } } -
20. Re: copy filename to iptc description
AndrewUSMC Jul 24, 2012 9:22 AM (in response to Paul Riggott)Paul,
I had some troubles with the code above, so what I did was take the code you had put up with the instructions on how and where to save it and just changed Desc and Description to Title, and it worked! Thank you so much for your help, this script has just saved us a ton of time. Thank you and thank you everyone here for your help.
21. Re: copy filename to iptc description
AndrewUSMC Jul 27, 2012 1:31 PM (in response to AndrewUSMC)Ok, so I ran into an issue, the code I used won't work on Camera RAW (.CR2), any ideas on what I can do to fix this? Thanks again for any and all of your help.
22. Re: copy filename to iptc description
Paul Riggott Jul 27, 2012 2:05 PM (in response to AndrewUSMC)CR2 files are read only so all you can do is amend the xmp file (or create a new xmp if it does not exist) with the required information, as an example...
var sels = app.document.selections; for(var a in sels){ setTitle(sels[a].spec); } function setTitle(thumb){ var Name = decodeURI(thumb.name).replace(/\.[^\.]+$/, ''); var file = new File(thumb.path +"/" +Name +".xmp"); if (ExternalObject.AdobeXMPScript == undefined) ExternalObject.AdobeXMPScript = new ExternalObject("lib:AdobeXMPScript"); if(file.exists){ file.open('r'); file.encoding = "UTF8"; file.lineFeed = "unix"; file.open("r", "TEXT", "????"); var xmpStr = file.read(); file.close(); }else{ var xmpStr=''; } var xmp = new XMPMeta( xmpStr ); xmp.deleteProperty(XMPConst.NS_DC, "title"); xmp.appendArrayItem(XMPConst.NS_DC, "title", Name, 0, XMPConst.ALIAS_TO_ALT_TEXT); xmp.setQualifier(XMPConst.NS_DC, "title[1]", "http://www.w3.org/XML/1998/namespace", "lang", "x-default"); file.open('w'); file.encoding = "UTF8"; file.lineFeed = "unix"; file.write( xmp.serialize() ); file.close(); }; -
23. Re: copy filename to iptc description
cdblach Jun 30, 2014 1:10 PM (in response to Paul Riggott)Paul,
I found this script from you: Re: How to Batch copy filename to its metadata Title and used it with great success, but it inserts the filename into the end of the description. Is there a way to modify it to place the filename at the beginning of the description?
