1 Reply Latest reply on May 6, 2010 10:41 AM by johnqdaily
    Parse XML in Workbench Issue
    johnqdaily Level 1
      Running LC ES 8.2.1.3 on MS Server 2003 with MSSQL 2005 and JBoss
      I have a stored procedure call that I have set up in workbench using the queryMultipleToXml service.  I am able to connect fine and can get the data into an XML type output variable called xmlOutput.  Below is the xml schema.
      <Subordinates>
           <Subordinate>
                <full_name>Public, John</full_name>
                <id_nbr>123456</id_nbr>
           </Subordinate>
            <Subordinate>
                <full_name>Doe, Jane</full_name>
                <id_nbr>987654</id_nbr>
           </Subordinate>
           <Subordinate>
                <full_name>Doe, John</full_name>
                <id_nbr>654987</id_nbr>
           </Subordinate>
           <Subordinate>
                <full_name>Dandy, Jim</full_name>
                <id_nbr>123789</id_nbr>
           </Subordinate>
      </Subordinates>
      What I need to do in Designer is output all of the names into a drop-down list so that when the user selects a name it will populate the id number into a text field.
      I am sure this is simple but I haven't been able to get this figured out.
      Thank you in advance,
      John
