4 Replies Latest reply on May 14, 2010 4:25 AM by kesasar
    RSL Error 2046 when using runtime-shared-library-path in ant mxmlc
    kesasar Level 1
      I am building my project using the mxmlc ant target with 3.4 SDK
      If I do <flex:mxmlc  ... static-link-runtime-shared-libraries="false" static-rsls="false"  ...>
      It is working fine. My SWF is a little bit lighter but not enough !
      If in my mxmlc I add the following nodes (all of them or only one of them)
      <runtime-shared-library-path
           path-element="${FLEX_HOME}/frameworks/libs/framework.swc">
           <url rsl-url="${contextroot}/client/framework_3.4.0.6955.swz" />
           <url rsl-url="${contextroot}/client/framework_3.4.0.6955.swf" />
      </runtime-shared-library-path>
           path-element="${FLEX_HOME}/frameworks/libs/rpc.swc">
           <url rsl-url="${contextroot}/client/rpc_3.4.0.6955.swz" />
           <url rsl-url="${contextroot}/client/rpc_3.4.0.6955.swf" />
           path-element="${FLEX_HOME}/frameworks/libs/datavisualization.swc">
           <url rsl-url="${contextroot}/client/datavisualization_3.4.0.9271.swz" />
           <url rsl-url="${contextroot}/client/datavisualization_3.4.0.9271.swf" />
      I have an : Error #2046: the loaded file did not have a valid signature
      I thought : why not adding verify-digests=false to my mxmlx target ???
      => Unfortunately the ant task doesn't support this option
      I have read also somewhere that this may be caused by library order.
      It is true that if in the flex plug-in for eclipse
      I Put the framwork.swc first
      Configure rpc.swc and datavisualization.swc
      the resulting swc works
      => This makes me think that my swz are properly signed
      => I just can't find a way to do the swz ordering in the ant target
      So is my only solution to use the commed-line mxmlc within ant ?
      What can be possibly wrong ?
